MQTT AD - Zigbee2MQTT
azonneveld
- Domoticz version: 2024.4
[edit]
I've made a short video, demonstrating the following steps:
1. Everything is running fine
2. MQTT AD hardware is restarted
3. Device cannot be controlled (even if I waited a longer time)
4. Name of device is altered in zigbee2mqtt gui (or another trigger, updating the description also works)
5. Device is working again
Here is the video: [offline]
[/edit]
Zigbee 1.33.2 + MQTT 1.5.7* + Domo 2023.2 worked fine.
Zigbee 1.33.2 + MQTT 1.5.7* + Domo 2024.x not fine
*mosquitto version 1.5.7 mosquitto is an MQTT v3.1.1 broker.
I have something weird going on.
After a (hot) reboot of the RPI most of the MQTT AD devices are not working anymore.
When I try to switch fi a lightbulb, domoticz gives the error: "zigbee2MQTT: Switch not found!?"
In the Zigbee2MQTT frontend, the device is present and can be controlled.
Only after renaming the devices, using the zigbee2mqtt frontend (just adding a 1 after its friendly name), it starts working in Domo again.
I don't know where to start to debug this problem.
Suggestions are very welcome!
(raspberry pi, domo 2024.4, zigbee2mqtt 133.2-135.1)
[/edit]
Last edited by azonneveld on Thursday 18 April 2024 21:47, edited 4 times in total.
rpi4 - zigbee2mqtt - roborock - espeasy - rfxcom - homewizard p1 - otgw - homebridge - surveillance station - egardia - goodwe - open weather map - wol - BBQ detection - rsync backup
solarboy
- Domoticz version: 2024.6
Re: MQTT AD - Zigbee2MQTT
You could try stopping Domoticz and clearing all data in your MQTT broker and rebooting.
azonneveld
I have 4 main topics in MQTT:solarboy wrote: Monday 05 February 2024 23:46 You could try stopping Domoticz and clearing all data in your MQTT broker and rebooting.
- zigbee2mqtt
domoticz
zigbee
$SYS
Do I clean them all or only 'zigbee' ? (or mabybe another one)
solarboy
If you clean them all and reboot they should be recreated automatically and this may solve your problem. May be to do with message retention.
azonneveld
Cleaned broker, and rebooted.solarboy wrote: Tuesday 06 February 2024 10:16 If you clean them all and reboot they should be recreated automatically and this may solve your problem. May be to do with message retention.
After reboot, no 'domoticz' topic was recreated, the rest returned as expected.
Almost everything works fine: switched, temperature sensors, push buttons, etc.
Except from dimmable devices (light bulbs), those devices start working after changing the friendly name in de z2m frontend.
Domoticz only gives an error when trying to switch on/off, when changing the dim-value, no error is given.
Also the powermeasurement from Tuya TS0121 stops working. Same applies for this device, renaming makes it work again
update:
It seems the non working devices are added in the 'zigbee2mqtt\bridge' topic after renaming.
update2:
After renaming the devices everything works fine, until restarting domoticz using: 'sudo service domoticz restart'
update3:
When I stop Z2M and Domoticz. Clear the broker and then start domo again, and after a while I start Z2M, it all works fine!
Is this any helpful?
solarboy
Glad you can get it working. It's a bit out of my league but I'd be sniffing around "retain" settings and "Auto Discovery".
azonneveld
I tried with and without retain on the affected devices, it seems to make no difference.
The best way so far seems to stop all, remove the AD topic, start Domo, followed by Zigbee2MQTT.
But this is not a very nice solution, since it requires manual actions after every reboot/restart/update/etc, or just a restart of the hardware device
After restarting the hardware device:
2024-02-06 19:36:58.711 Error: zigbee2MQTT: Switch not found!? (0x000b3cfffefad97e_light_zigbee2mqtt/Lamp Twee)
After changing friendly name in the Zigbee2MQTT GUI:
2024-02-06 19:37:49.693 Status: zigbee2MQTT: discovered: Lamp Twee_dimmer/Lamp Twee_dimmer (unique_id: 0x000b3cfffefad97e_light_zigbee2mqtt)
- Domoticz version: 2025.1
It seems your renumbering in the past mixes up the discovery.
What if you try the following:
1 be sure you have retained/cached discovery topics on in Zigbee2MQTT settings.
2. Delete the problem Zigbee2MQTT devices from Domoticz, make sure you delete them all from from the same ID eg 0x000b3cfffefad97e
3. Rediscover the devices by restarting the mqtt ad gateway in Domoticz menu setup-hardware (click on update) and trigger the switches in Zigbee2MQTT.
azonneveld
I have found some cache/retain options on device level, but not on mqtt topic level.
Where can I find/check those settings on topic level?
- 2024-02-06 20_55_09-Clipboard.png (21.88 KiB) Viewed 4269 times
In the Zigbee2MQTT manual there are retain/cache options mentioned in the MQTT section
https://www.zigbee2mqtt.io/guide/config ... /mqtt.html
azonneveld
Tried this with one of the problematic devices.waltervl wrote: Tuesday 06 February 2024 20:26 It seems your renumbering in the past mixes up the discovery.
After restarting the mqtt ad the device was not automatically added.
I had to stop zigbee2mqtt, stop mqtt gateway hardware, clear the AD topic, then start zigbee2mqtt, followed by the gateway hardware.
Then the device got added automatically again.
To test the fresh device, I restarted the mqtt gateway hardware. Again, the device was not working.
Getting a bit desperate.
There seems to be something wrong in your environment, some setting is incorrect. It is impossible for us to tell what you did wrong. Be sure the normal Zigbee2MQTT topic prefix (default zigbee2mqtt) is different than the discovery prefix (default homeassistant)
azonneveld
Yes, I also think something is wrong, but what is the million dollar question.
The AD topic is different from the zigbee2mqtt topic:
Kedi
Why change the defaults?
The defaults are: zigbee2mqtt (for status and activation of swithes and such) and homeassistant (for config of auto-discovery)
I suppose you changed homeassistant to zigbeeAD? In Domoticz this should be the 'Auto Discovery Prefix'
azonneveld
Correct, I have added ZigbeeAD as the prefix in the hardwareKedi wrote: Thursday 08 February 2024 14:16 Why change the defaults?
Kedi
Here you stated that the topic was zigbee. Did you change the topic in zigbee2mqtt?azonneveld wrote: Tuesday 06 February 2024 9:20I have 4 main topics in MQTT:solarboy wrote: Monday 05 February 2024 23:46 You could try stopping Domoticz and clearing all data in your MQTT broker and rebooting.
Zigbee is used in Domo MQTT AD.
- zigbee2mqtt
domoticz
zigbee
$SYS
The domoticz gives the error: "zigbee2MQTT: Switch not found!? as you stated above might come from the fact that the ID of the device changed. Is it possible to start over again? Leave the discovery topic default ( homeassistant ), clean the topics from the mosquitto server and then delete the MQTT-AD hardware and start over the discovery with new hardware (homeassistant).
azonneveld
Yes, I changed the zigbee to zigbeeAD, but that changed nothing.Kedi wrote: Thursday 08 February 2024 18:44 Here you stated that the topic was zigbee. Did you change the topic in zigbee2mqtt?
As per your advices, i changed to the defaults, the results are the same.
Somehow not everything is read correctly from the AD topic.
After I press the submit button in the zigbee2mqtt gui (device>settings>submit), some data seems to be refreshed in the AD topic, and then read correctly.
Next days I will try to isolate one of the devices that often fails (by removing them from the zigbee2mqtt database, this prevents devices from being published).
This is the content of the AD topic for one of the faulty devices (data fetched from the zigbee2mqtt log file).
When it was named 'Ikea_Drukker_031' it was not working, after renaming, it worked:
info 2024-02-08 21:46:35: MQTT publish: topic 'homeassistant/sensor/0x0c4314fffe4cbf9c/battery/config' payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"} {"topic":"zigbee2mqtt/Ikea_Drukker_031/availability"}] availability_mode:"all" device:{"identifiers":["zigbee2mqtt_0x0c4314fffe4cbf9c"] manufacturer:"IKEA" model:"TRADFRI ON/OFF switch (E1743)" name:"Ikea_Drukker_031" sw_version:"2.3.079"} device_class:"battery" enabled_by_default:true entity_category:"diagnostic" json_attributes_topic:"zigbee2mqtt/Ikea_Drukker_031" object_id:"ikea_drukker_031_battery" origin:{"name":"Zigbee2MQTT" sw:"1.33.2" url:"https://www.zigbee2mqtt.io"} state_class:"measurement" state_topic:"zigbee2mqtt/Ikea_Drukker_031" unique_id:"0x0c4314fffe4cbf9c_battery_zigbee2mqtt" unit_of_measurement:"%" value_template:"{{ value_json.battery }}"}'
info 2024-02-08 21:46:35: MQTT publish: topic 'homeassistant/sensor/0x0c4314fffe4cbf9c/action/config' payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"} {"topic":"zigbee2mqtt/Ikea_Drukker_031/availability"}] availability_mode:"all" device:{"identifiers":["zigbee2mqtt_0x0c4314fffe4cbf9c"] manufacturer:"IKEA" model:"TRADFRI ON/OFF switch (E1743)" name:"Ikea_Drukker_031" sw_version:"2.3.079"} enabled_by_default:true icon:"mdi:gesture-double-tap" json_attributes_topic:"zigbee2mqtt/Ikea_Drukker_031" name:"Action" object_id:"ikea_drukker_031_action" origin:{"name":"Zigbee2MQTT" sw:"1.33.2" url:"https://www.zigbee2mqtt.io"} state_topic:"zigbee2mqtt/Ikea_Drukker_031" unique_id:"0x0c4314fffe4cbf9c_action_zigbee2mqtt" value_template:"{{ value_json.action }}"}'
info 2024-02-08 21:46:35: MQTT publish: topic 'homeassistant/sensor/0x0c4314fffe4cbf9c/linkquality/config' payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"} {"topic":"zigbee2mqtt/Ikea_Drukker_031/availability"}] availability_mode:"all" device:{"identifiers":["zigbee2mqtt_0x0c4314fffe4cbf9c"] manufacturer:"IKEA" model:"TRADFRI ON/OFF switch (E1743)" name:"Ikea_Drukker_031" sw_version:"2.3.079"} enabled_by_default:false entity_category:"diagnostic" icon:"mdi:signal" json_attributes_topic:"zigbee2mqtt/Ikea_Drukker_031" name:"Linkquality" object_id:"ikea_drukker_031_linkquality" origin:{"name":"Zigbee2MQTT" sw:"1.33.2" url:"https://www.zigbee2mqtt.io"} state_class:"measurement" state_topic:"zigbee2mqtt/Ikea_Drukker_031" unique_id:"0x0c4314fffe4cbf9c_linkquality_zigbee2mqtt" unit_of_measurement:"lqi" value_template:"{{ value_json.linkquality }}"}'
info 2024-02-08 21:46:35: MQTT publish: topic 'homeassistant/sensor/0x0c4314fffe4cbf9c/click/config' payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"} {"topic":"zigbee2mqtt/Ikea_Drukker_031/availability"}] availability_mode:"all" device:{"identifiers":["zigbee2mqtt_0x0c4314fffe4cbf9c"] manufacturer:"IKEA" model:"TRADFRI ON/OFF switch (E1743)" name:"Ikea_Drukker_031" sw_version:"2.3.079"} icon:"mdi:toggle-switch" json_attributes_topic:"zigbee2mqtt/Ikea_Drukker_031" name:"Click" object_id:"ikea_drukker_031_click" origin:{"name":"Zigbee2MQTT" sw:"1.33.2" url:"https://www.zigbee2mqtt.io"} state_topic:"zigbee2mqtt/Ikea_Drukker_031" unique_id:"0x0c4314fffe4cbf9c_click_zigbee2mqtt" value_template:"{{ value_json.click }}"}'
info 2024-02-08 21:46:35: MQTT publish: topic 'homeassistant/sensor/0x0c4314fffe4cbf9c/update_state/config' payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"} {"topic":"zigbee2mqtt/Ikea_Drukker_031/availability"}] availability_mode:"all" device:{"identifiers":["zigbee2mqtt_0x0c4314fffe4cbf9c"] manufacturer:"IKEA" model:"TRADFRI ON/OFF switch (E1743)" name:"Ikea_Drukker_031" sw_version:"2.3.079"} enabled_by_default:false entity_category:"diagnostic" icon:"mdi:update" json_attributes_topic:"zigbee2mqtt/Ikea_Drukker_031" name:"Update state" object_id:"ikea_drukker_031_update_state" origin:{"name":"Zigbee2MQTT" sw:"1.33.2" url:"https://www.zigbee2mqtt.io"} state_topic:"zigbee2mqtt/Ikea_Drukker_031" unique_id:"0x0c4314fffe4cbf9c_update_state_zigbee2mqtt" value_template:"{{ value_json['update']['state'] }}"}'
info 2024-02-08 21:59:42: MQTT publish: topic 'homeassistant/sensor/0x0c4314fffe4cbf9c/battery/config' payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"} {"topic":"zigbee2mqtt/Ikea_Drukker_03/availability"}] availability_mode:"all" device:{"identifiers":["zigbee2mqtt_0x0c4314fffe4cbf9c"] manufacturer:"IKEA" model:"TRADFRI ON/OFF switch (E1743)" name:"Ikea_Drukker_03" sw_version:"2.3.079"} device_class:"battery" enabled_by_default:true entity_category:"diagnostic" json_attributes_topic:"zigbee2mqtt/Ikea_Drukker_03" object_id:"ikea_drukker_03_battery" origin:{"name":"Zigbee2MQTT" sw:"1.33.2" url:"https://www.zigbee2mqtt.io"} state_class:"measurement" state_topic:"zigbee2mqtt/Ikea_Drukker_03" unique_id:"0x0c4314fffe4cbf9c_battery_zigbee2mqtt" unit_of_measurement:"%" value_template:"{{ value_json.battery }}"}'
info 2024-02-08 21:59:42: MQTT publish: topic 'homeassistant/sensor/0x0c4314fffe4cbf9c/action/config' payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"} {"topic":"zigbee2mqtt/Ikea_Drukker_03/availability"}] availability_mode:"all" device:{"identifiers":["zigbee2mqtt_0x0c4314fffe4cbf9c"] manufacturer:"IKEA" model:"TRADFRI ON/OFF switch (E1743)" name:"Ikea_Drukker_03" sw_version:"2.3.079"} enabled_by_default:true icon:"mdi:gesture-double-tap" json_attributes_topic:"zigbee2mqtt/Ikea_Drukker_03" name:"Action" object_id:"ikea_drukker_03_action" origin:{"name":"Zigbee2MQTT" sw:"1.33.2" url:"https://www.zigbee2mqtt.io"} state_topic:"zigbee2mqtt/Ikea_Drukker_03" unique_id:"0x0c4314fffe4cbf9c_action_zigbee2mqtt" value_template:"{{ value_json.action }}"}'
info 2024-02-08 21:59:42: MQTT publish: topic 'homeassistant/sensor/0x0c4314fffe4cbf9c/linkquality/config' payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"} {"topic":"zigbee2mqtt/Ikea_Drukker_03/availability"}] availability_mode:"all" device:{"identifiers":["zigbee2mqtt_0x0c4314fffe4cbf9c"] manufacturer:"IKEA" model:"TRADFRI ON/OFF switch (E1743)" name:"Ikea_Drukker_03" sw_version:"2.3.079"} enabled_by_default:false entity_category:"diagnostic" icon:"mdi:signal" json_attributes_topic:"zigbee2mqtt/Ikea_Drukker_03" name:"Linkquality" object_id:"ikea_drukker_03_linkquality" origin:{"name":"Zigbee2MQTT" sw:"1.33.2" url:"https://www.zigbee2mqtt.io"} state_class:"measurement" state_topic:"zigbee2mqtt/Ikea_Drukker_03" unique_id:"0x0c4314fffe4cbf9c_linkquality_zigbee2mqtt" unit_of_measurement:"lqi" value_template:"{{ value_json.linkquality }}"}'
info 2024-02-08 21:59:42: MQTT publish: topic 'homeassistant/sensor/0x0c4314fffe4cbf9c/click/config' payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"} {"topic":"zigbee2mqtt/Ikea_Drukker_03/availability"}] availability_mode:"all" device:{"identifiers":["zigbee2mqtt_0x0c4314fffe4cbf9c"] manufacturer:"IKEA" model:"TRADFRI ON/OFF switch (E1743)" name:"Ikea_Drukker_03" sw_version:"2.3.079"} icon:"mdi:toggle-switch" json_attributes_topic:"zigbee2mqtt/Ikea_Drukker_03" name:"Click" object_id:"ikea_drukker_03_click" origin:{"name":"Zigbee2MQTT" sw:"1.33.2" url:"https://www.zigbee2mqtt.io"} state_topic:"zigbee2mqtt/Ikea_Drukker_03" unique_id:"0x0c4314fffe4cbf9c_click_zigbee2mqtt" value_template:"{{ value_json.click }}"}'
info 2024-02-08 21:59:42: MQTT publish: topic 'homeassistant/sensor/0x0c4314fffe4cbf9c/update_state/config' payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"} {"topic":"zigbee2mqtt/Ikea_Drukker_03/availability"}] availability_mode:"all" device:{"identifiers":["zigbee2mqtt_0x0c4314fffe4cbf9c"] manufacturer:"IKEA" model:"TRADFRI ON/OFF switch (E1743)" name:"Ikea_Drukker_03" sw_version:"2.3.079"} enabled_by_default:false entity_category:"diagnostic" icon:"mdi:update" json_attributes_topic:"zigbee2mqtt/Ikea_Drukker_03" name:"Update state" object_id:"ikea_drukker_03_update_state" origin:{"name":"Zigbee2MQTT" sw:"1.33.2" url:"https://www.zigbee2mqtt.io"} state_topic:"zigbee2mqtt/Ikea_Drukker_03" unique_id:"0x0c4314fffe4cbf9c_update_state_zigbee2mqtt" value_template:"{{ value_json['update']['state'] }}"}'
azonneveld
When it was named 'Ikea_Drukker_031' it was not working, after renaming, it worked.
Don't stare at the renaming, as far as I know now it is just the updated topic that counts, which probably triggers Domo to re-read that topic.
I don't see any other difference than the name (and time of course)
If you stop and start the mqtt broker are those topics in homeassistant still there? As they should be retained. If they are not then your renaming triggers Zigbee2MQTT to send new discovery topics and then Domoticz will create the devices again.
azonneveld
All topics remain when zigbee2mqtt is stopped:waltervl wrote: Friday 09 February 2024 0:05 If you stop and start the mqtt broker are those topics in homeassistant still there?
- zigbee2mqtt
- homeassistant (the AD topic)
- $SYS
