Yea I feel you, I have said about this breaking change what I wanted to say, but decision was made and guess it is an Fait Accompli.houk wrote: Saturday 25 November 2023 14:23 Simpler option is to maintain backward compatibility in domoticz itself and no disabling old format.
I already lost one way to access domoticz via old, not maintained from 2017 year app Imperihome because of changes in domoticz security.
Now another thing in next version will be lost. It shouldn't be like this.
15326 - [WebServer] Depricated RType Topic is solved
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Version: xxxx
Platform: xxxx
Description:
- jvdz
- Domoticz version: 4.107
Re: 15326 - [WebServer] Depricated RType
- madpatrick
- Domoticz version: 2025.2
Both Pilot and Domoticz app for IOS are given this error.
Not a big issue because they still are working, but i don’t expect this will be solved.
Both looks abandoned
- jvdz
Well the reverse proxy worked for me when the android app had issues.
- jvdz
This is the proxy definition for OLD requests to New Server which I didn't post in the other topic in case you like to support old API calls with new Domoticz versions:
server {
listen 8081;
server_name domoapi_Old1New;
access_log /var/log/nginx/domoapi1new.log;
error_log /var/log/nginx/domoapi1new.log;
location / {
if ($args ~ (^|.*&)type=settings(.*)) { set $args $1type=command¶m=getsettings$2; break;}
if ($args ~ (^|.*&)type=users(.*)) { set $args $1type=command¶m=getusers$2; break;}
if ($args ~ (^|.*&)type=devices(.*)) { set $args $1type=command¶m=getdevices$2; break;}
if ($args ~ (^|.*&)type=hardware(.*)) { set $args $1type=command¶m=gethardware$2; break;}
if ($args ~ (^|.*&)type=events(.*)) { set $args $1type=command¶m=events$2; break;}
if ($args ~ (^|.*&)type=notifications(.*)) { set $args $1type=command¶m=getnotifications$2; break;}
if ($args ~ (^|.*&)type=createdevice(.*)) { set $args $1type=command¶m=createdevice$2; break;}
if ($args ~ (^|.*&)type=scenes(.*)) { set $args $1type=command¶m=getscenes$2; break;}
if ($args ~ (^|.*&)type=plans(.*)) { set $args $1type=command¶m=getplans$2; break;}
if ($args ~ (^|.*&)type=graph(.*)) { set $args $1type=command¶m=graph$2; break;}
if ($args ~ (^|.*&)type=scenelog(.*)) { set $args $1type=command¶m=getscenelog$2; break;}
if ($args ~ (^|.*&)type=mobiles(.*)) { set $args $1type=command¶m=getmobiles$2; break;}
if ($args ~ (^|.*&)type=cameras(.*)) { set $args $1type=command¶m=getcameras$2; break;}
if ($args ~ (^|.*&)type=cameras_user(.*)) { set $args $1type=command¶m=getcameras_user$2; break;}
if ($args ~ (^|.*&)type=schedules(.*)) { set $args $1type=command¶m=getschedules$2; break;}
if ($args ~ (^|.*&)type=timers(.*)) { set $args $1type=command¶m=gettimers$2; break;}
if ($args ~ (^|.*&)type=scenetimers(.*)) { set $args $1type=command¶m=getscenetimers$2; break;}
if ($args ~ (^|.*&)type=setpointtimers(.*)) { set $args $1type=command¶m=getsetpointtimers$2; break;}
if ($args ~ (^|.*&)type=floorplans(.*)) { set $args $1type=command¶m=getfloorplans$2; break;}
if ($args ~ (^|.*&)type=lightlog(.*)) { set $args $1type=command¶m=getlightlog$2; break;}
if ($args ~ (^|.*&)type=textlog(.*)) { set $args $1type=command¶m=gettextlog$2; break;}
if ($args ~ (^|.*&)type=setused(.*)) { set $args $1type=command¶m=setused$2; break;}
proxy_http_version 1.1;
proxy_read_timeout 90;
proxy_set_header Host $host;
proxy_set_header X-Real-IP $remote_addr;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_set_header X-Forwarded-Proto $scheme;
proxy_set_header X-Scheme $scheme;
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection $connection_upgrade;
add_header X-Frame-Options SAMEORIGIN;
proxy_set_header Authorization "Basic";
proxy_pass http://localhost:8080/;
type=command¶m=switchscene&idx=55&switchcmd=on
switchscene from API not working
- Domoticz version: 2025.1
But with switchcmd=On (capital o) it is....rewil wrote: Thursday 30 November 2023 0:12 type=command¶m=switchscene&idx=55&switchcmd=on
See wiki https://www.domoticz.com/wiki/Domoticz_ ... .2F_Groups
- habahabahaba
- Domoticz version: 2024.4
Hi everybody.
Updated from 2022.2 version and see the same messages.
How can i find who is sending and what? And will it cause problems in the future?
Debug mode didnt help.
SystemName "windows"
UseUpdate true
build_time "2024-01-30 11:16:34"
dzvents_version "3.1.8"
hash "731719420"
python_version "3.8.2
status "OK"
title "GetVersion"
version "2024.4"
Only Domoticz and ZigbeeForDomoticz plugin
- Spoiler: show
UseUpdate true
hash "731719420"
status "OK"
title "GetVersion"
version "2024.4"
It is sometjing on your server. Could be scripts, a theme, Dashticz that needs to be updated etc.
- habahabahaba
Only native Theme, no Dashticz.waltervl wrote: Thursday 01 February 2024 13:59 It is sometjing on your server. Could be scripts, a theme, Dashticz that needs to be updated etc.
Scripts... disabled everything.. and the same
- Spoiler: show
How can i filter out the one?
Or may be the old plugin version? Im using 6.3.015
Yes could be the zigbee4Domoticz plugin sending these commands. Did you update it recently?
Edit: from Z4D stable 7 the plugin is compatible with the new API.
- habahabahaba
I tried but im on windows and its no so easywaltervl wrote: Thursday 01 February 2024 14:32 Yes could be the zigbee4Domoticz plugin sending these commands. Did you update it recently?
Gitcmd giving some errors, webUI updating gives nothing.
May be i can download the v.7 and just replace the folder?
Will it work and all devices on their places?
I dont now, better make a new topic for this in the Zigbee subforum.habahabahaba wrote: Thursday 01 February 2024 14:55I tried but im on windows and its no so easywaltervl wrote: Thursday 01 February 2024 14:32 Yes could be the zigbee4Domoticz plugin sending these commands. Did you update it recently?
ilex
I am affraid You are rightmadpatrick wrote: Saturday 25 November 2023 21:58 Both Pilot and Domoticz app for IOS are given this error.
Wrote an emil to Pilot developer with no reply at all.
arjan93
I get the "Deprecated RType (graph) for API request. Handled via fallback (graph), please use correct API Command!" error to. After some searching
I found that the problem was created by a script that shows my electricity consumption and cost.
This is the script what triggerd my error:
Could someone help me with the script? I dont know where the problem is created.
local scriptVar = 'ElectricityConsumptionAndCost'
return
on =
timer = {'every 2 minutes'}, -- Run this script every 2 minutes
httpResponses = {scriptVar .. '*'},
logging =
level = domoticz.LOG_ERROR, -- Change to LOG_DEBUG to debug / Change to LOG_ERROR if script is running properly
marker = scriptVar,
data =
electricity =
initial = {},
execute = function(dz, item)
-- Variables -------------------------------------------------------
local inputDevice = dz.devices('Electra') -- Input device (P1)
local outputDeviceConsumptionToday = dz.devices('Electriciteit Verbruik (vandaag)') -- Output device consumption today
local outputDeviceConsumptionMonth = dz.devices('Electriciteit Verbruik (maand)') -- Output device consumption month
local outputDeviceConsumptionYear = dz.devices('Electriciteit Verbruik (jaar)') -- Output device consumption year
local outputDeviceCostToday = dz.devices('Electriciteit Kosten (vandaag)') -- Output device cost today
local outputDeviceCostMonth = dz.devices('Electriciteit Kosten (maand)') -- Output device cost month
local outputDeviceCostYear = dz.devices('Electriciteit Kosten (jaar)') -- Output device cost year
-- Electricity costs per unit ------
local costElectricityUnitT1 = 0.36264
local costElectricityUnitT2 = 0.30987
local costElectricityUnitR1 = 0.11500
local costElectricityUnitR2 = 0.11500
-- Fixed cost per day -------------------------------------------------------------------------------------------------------
local costElectricityFixedDay = (0.25526 + 1.16656 - 1.7298) -- (Transport cost + Grid operator cost - Energy tax reduction)
-- Funtion for consumption retrieval ------------
local function ConsumptionGetGraphData(id, delay)
local period = 'year'
electricityURL = dz.settings['Domoticz url'] .. '/json.htm?type=graph&sensor=counter&range=' .. period .. '&idx=' .. id
dz.openURL({ url = electricityURL, callback = scriptVar .. '_' .. id}).afterSec(delay or 0)
-- Function for consumption calculation --
local function makeConsumption(device)
local currentConsumption
if device == outputDeviceConsumptionToday then
currentConsumption = (dz.data.electricity.consumptionTodayT1) + (dz.data.electricity.consumptionTodayT2)
currentConsumption = currentConsumption - (dz.data.electricity.consumptionTodayR1) - (dz.data.electricity.consumptionTodayR2)
dz.log('currentConsumption (today): ' .. currentConsumption .. ' kWh', dz.LOG_DEBUG)
if device == outputDeviceConsumptionMonth then
currentConsumption = (dz.data.electricity.consumptionMonthT1) + (dz.data.electricity.consumptionMonthT2)
currentConsumption = currentConsumption - (dz.data.electricity.consumptionMonthR1) - (dz.data.electricity.consumptionMonthR2)
dz.log('currentConsumption (month): ' .. currentConsumption .. ' kWh', dz.LOG_DEBUG)
if device == outputDeviceConsumptionYear then
currentConsumption = (dz.data.electricity.consumptionYearT1) + (dz.data.electricity.consumptionYearT2)
currentConsumption = currentConsumption - (dz.data.electricity.consumptionYearR1) - (dz.data.electricity.consumptionYearR2)
dz.log('currentConsumption (year): ' .. currentConsumption .. ' kWh', dz.LOG_DEBUG)
return dz.utils.round(currentConsumption, 3)
-- Function for cost calculation --
local function makeCost(device)
local currentCost
if device == outputDeviceCostToday then
currentCost = (dz.data.electricity.consumptionTodayT1 * dz.data.electricity.costElectricityUnitT1) + (dz.data.electricity.consumptionTodayT2 * dz.data.electricity.costElectricityUnitT2)
currentCost = currentCost - (dz.data.electricity.consumptionTodayR1 * dz.data.electricity.costElectricityUnitR1) - (dz.data.electricity.consumptionTodayR2 * dz.data.electricity.costElectricityUnitR2)
currentCost = currentCost + (dz.data.electricity.costElectricityFixedDay)
dz.log('currentCost (today): ' .. currentCost .. ' EUR', dz.LOG_DEBUG)
if device == outputDeviceCostMonth then
currentCost = (dz.data.electricity.consumptionMonthT1 * dz.data.electricity.costElectricityUnitT1) + (dz.data.electricity.consumptionMonthT2 * dz.data.electricity.costElectricityUnitT2)
currentCost = currentCost - (dz.data.electricity.consumptionMonthR1 * dz.data.electricity.costElectricityUnitR1) - (dz.data.electricity.consumptionMonthR2 * dz.data.electricity.costElectricityUnitR2)
currentCost = currentCost + (dz.data.electricity.costElectricityFixedDay * dz.data.electricity.daysCounterMonth)
dz.log('currentCost (month): ' .. currentCost .. ' EUR', dz.LOG_DEBUG)
if device == outputDeviceCostYear then
currentCost = (dz.data.electricity.consumptionYearT1 * dz.data.electricity.costElectricityUnitT1) + (dz.data.electricity.consumptionYearT2 * dz.data.electricity.costElectricityUnitT2)
currentCost = currentCost - (dz.data.electricity.consumptionYearR1 * dz.data.electricity.costElectricityUnitR1) - (dz.data.electricity.consumptionYearR2 * dz.data.electricity.costElectricityUnitR2)
currentCost = currentCost + (dz.data.electricity.costElectricityFixedDay * dz.data.electricity.daysCounterYear)
dz.log('currentCost (year): ' .. currentCost .. ' EUR', dz.LOG_DEBUG)
return dz.utils.round(currentCost, 2)
-- Function for updating a Virtual Custom Sensor --
local function updateCustomSensor(device, value)
local currentValue = device.rawData[1]
if value ~= tonumber(currentValue) then -- Update only necessary when new value differs from the previous one
device.updateCustomSensor(value)
dz.log(device.name .. " ==>> Previous value: " .. currentValue .. " ; New value: " .. value,dz.LOG_DEBUG)
-- Function for JSON processing --
local function ProcessJSON(t)
local todayVolumeT1, todayVolumeT2, todayVolumeR1, todayVolumeR2 = 0, 0, 0, 0
local monthVolumeT1, monthVolumeT2, monthVolumeR1, monthVolumeR2 = 0, 0, 0, 0
local yearVolumeT1, yearVolumeT2, yearVolumeR1, yearVolumeR2 = 0, 0, 0, 0
local daysCounterMonth = 0
local daysCounterYear = 0
local currentDayIdentifier = dz.time.rawDate:sub(1,10)
local currentMonthIdentifier = dz.time.rawDate:sub(1,4) .. '%-' .. dz.time.rawDate:sub(6,7)
local day = 86400 -- (24 * 60 * 60)
for index, inputDevice in ipairs(t) do
if inputDevice.d == currentDayIdentifier then
todayVolumeT1 = todayVolumeT1 + inputDevice.v
todayVolumeT2 = todayVolumeT2 + inputDevice.v2
todayVolumeR1 = todayVolumeR1 + inputDevice.r1
todayVolumeR2 = todayVolumeR2 + inputDevice.r2
if inputDevice.d:match(currentMonthIdentifier) then
monthVolumeT1 = monthVolumeT1 + inputDevice.v
monthVolumeT2 = monthVolumeT2 + inputDevice.v2
monthVolumeR1 = monthVolumeR1 + inputDevice.r1
monthVolumeR2 = monthVolumeR2 + inputDevice.r2
daysCounterMonth = daysCounterMonth + 1
if inputDevice.d:match(dz.time.year) then
yearVolumeT1 = yearVolumeT1 + inputDevice.v
yearVolumeT2 = yearVolumeT2 + inputDevice.v2
yearVolumeR1 = yearVolumeR1 + inputDevice.r1
yearVolumeR2 = yearVolumeR2 + inputDevice.r2
daysCounterYear = daysCounterYear + 1
dz.log('daysCounterMonth: ' .. daysCounterMonth, dz.LOG_DEBUG)
dz.log('daysCounterYear: ' .. daysCounterYear, dz.LOG_DEBUG)
dz.data.electricity.consumptionTodayT1 = todayVolumeT1
dz.data.electricity.consumptionTodayT2 = todayVolumeT2
dz.data.electricity.consumptionTodayR1 = todayVolumeR1
dz.data.electricity.consumptionTodayR2 = todayVolumeR2
dz.data.electricity.consumptionMonthT1 = monthVolumeT1
dz.data.electricity.consumptionMonthT2 = monthVolumeT2
dz.data.electricity.consumptionMonthR1 = monthVolumeR1
dz.data.electricity.consumptionMonthR2 = monthVolumeR2
dz.data.electricity.consumptionYearT1 = yearVolumeT1
dz.data.electricity.consumptionYearT2 = yearVolumeT2
dz.data.electricity.consumptionYearR1 = yearVolumeR1
dz.data.electricity.consumptionYearR2 = yearVolumeR2
dz.data.electricity.costElectricityUnitT1 = costElectricityUnitT1
dz.data.electricity.costElectricityUnitT2 = costElectricityUnitT2
dz.data.electricity.costElectricityUnitR1 = costElectricityUnitR1
dz.data.electricity.costElectricityUnitR2 = costElectricityUnitR2
dz.data.electricity.costElectricityFixedDay = (costElectricityFixedDay or 0)
dz.data.electricity.daysCounterMonth = daysCounterMonth
dz.data.electricity.daysCounterYear = daysCounterYear
-- Main -----------------------------------
if item.isHTTPResponse and item.isJSON then
ProcessJSON(item.json.result)
elseif item.isTimer or item.isDevice then
ConsumptionGetGraphData(inputDevice.id, 0)
updateCustomSensor(outputDeviceConsumptionToday, makeConsumption(outputDeviceConsumptionToday))
updateCustomSensor(outputDeviceConsumptionMonth, makeConsumption(outputDeviceConsumptionMonth))
updateCustomSensor(outputDeviceConsumptionYear, makeConsumption(outputDeviceConsumptionYear))
updateCustomSensor(outputDeviceCostToday, makeCost(outputDeviceCostToday))
updateCustomSensor(outputDeviceCostMonth, makeCost(outputDeviceCostMonth))
updateCustomSensor(outputDeviceCostYear, makeCost(outputDeviceCostYear))
dz.log('Error retrieving data. Result is: ' .. item.statusText ..' ; Response is: ' .. item.data,LOG_ERROR)
}- jvdz
This is an pretty easy one as there is only one API call in that script!
Line 49:
From the API Definitions Wiki:
Line 49:
Warning Stable 2023.2 (and newer)
For users using API calls from outside Domoticz there has been some changes in API calls. They now always should be of the form /json.htm?type=command¶m=**command**
For example
/json.htm?type=graph will be /json.htm?type=command¶m=graph
arjan93
Thanks, that was the trickjvdz wrote: Saturday 16 March 2024 11:10 This is an pretty easy one as there is only one API call in that script!
Line 49:From the API Definitions Wiki:Code: Select all
electricityURL = dz.settings['Domoticz url'] .. '/json.htm?type=graph&sensor=counter&range=' .. period .. '&idx=' .. idCode: Select all
Warning Stable 2023.2 (and newer) For users using API calls from outside Domoticz there has been some changes in API calls. They now always should be of the form /json.htm?type=command¶m=**command** For example /json.htm?type=graph will be /json.htm?type=command¶m=graph
- McMelloW
- Domoticz version: V2024.1
@jvdz
Thanks for the solution, works for me too.
Greetings McMelloW
Note: in beta 2024.7 (december 2024) the old RType API calls have been removed so instead of warnings you now will get errors and no results!!!
Please update your applications and scripts to use the new API calls.
enboer
I also get this [WebServer] Depricated RType message in 2024.7.
Disabled the scripts\lua, dzvents\scripts, events in the Domoticz GUI, disabled hardware devices/plugins. But this get this message any idea?
Tried to start domoticz with these settings to get some more info:
DAEMON_ARGS="$DAEMON_ARGS -loglevel error,debug -debuglevel webserver"
But then the Domoticz GUI does not come up at all, it keeps trying to load the webpage.
Any help appreciated to get to the source of this issue.
It could well be outside the domoticz server so for example an ESP device updating a Domoticz device.
Is there an IP address connected to the message? Is that IP from an external device or from the server?
