Domoticz 2024.1 Can not install Aeotec Z-Wave Plus Z-Stick
Knibor
Domoticz version: Stable
Post by Knibor »
Best wishes for 2024 yet all
I have installed Domoticz 2024.1, but now it does not find the Aeotec Z-Wave Plus Z-Stick Gen5. In the hardware can't find "OpenZWave USB" ?
Now I cannot install the Aeotec Gen 5 anymore. How can this problem be solved?
Domoticz version: 2025.1
Re: Domoticz 2024.1 Can not install Aeotec Z-Wave Plus Z-Stick
Openzwave has been deprecated in latest 2024.1 stable version because the Openzwave project has not been updated for years. Switch to Zwave-JS-UI https://www.domoticz.com/wiki/Zwave-JS-UI
Or revert back to your backup before you updates Domoticz.
hnogueira
Post by hnogueira »
Can anyone explain how to install on Windows?
thks
pkelderman
Domoticz version: 2024.4
Post by pkelderman »
Is it possible to get updates without deprecated Openzwave? It functioned perfect. The alternative is a disaster! The Aeotec z-wave gen 5 is not visible in a raspberry 3b anymore. The documentation does not help. :mrgreen:
If it is not visible in Zwave-JS-UI it will also not be visible in Domoticz with OpenZwave.
https://www.domoticz.com/wiki/Zwave-JS-UI#Serial_Port
pkelderman
"If it is not visible in Zwave-JS-UI it will also not be visible in Domoticz with OpenZwave." That's not true, because it was! Until 2024.1.
Egregius
Domoticz version: v2024.7
Post by Egregius »
Install 2024.2 ;)
pkelderman
I did. But that causes the problem of not seeing devices from a remote domoticz server (a server in the same domain -192.168.1.*). :roll:
pkelderman wrote: Tuesday 23 January 2024 16:17 "If it is not visible in Zwave-JS-UI it will also not be visible in Domoticz with OpenZwave." That's not true, because it was! Until 2024.1.
If it is visible in Linux eg through command ls /dev/serial/by-id it should be visible Zwave-JS-UI if your docker compose file is correct.
In 20241,1 the openzwave functionality was removed.
In 2024.2 it is enabled again but still advised is to move to Zwave-JS-UI.
Users browsing this forum: eddieb and 1 guest
