I'm looking for a hardware security keypad solution to arm/disarm my Domoticz security panel.
I have Dashticz running on tablets and the integration is working great, except the fact that you'll always need power to the place where you want to use your keypad.
I see that the "Xfinity URC4450BC0-X-R" and the "Centralite 3400-D" keypads (Zigbee) are compatible with Z2M.
Anyone already got this working?
On reddit, users have got it nicely integrated with HA. The keypad even beeps when the entry/exit delay is running. The keypad changes color depending on the arm/disarm state.
Centralite 3400-D or Xfinity URC4450BC0-X-R keypads anyone?
sammyke007
- Domoticz version: 2022.1
kimhav
- Domoticz version: 2023.2
Re: Centralite 3400-D or Xfinity URC4450BC0-X-R keypads anyone?
Was you ever able to get any of the above mentioned keypads to work with Domoticz?
Thorgal789
- Target OS: -
Some of them are working with deconz with a start of integration in Domoticz https://github.com/Smanar/Domoticz-deCO ... o-domoticz
But it create a new widget, the python plugin haven't a connexion to the "Domoticz security panel".
But if I m right, there is no "alarm System" by defaut in domoticz, you need to code it yourself ?
For me, will be same for all others zigbee solution, you need to make the code yourself like here https://www.domoticz.com/wiki/Alarm_Setup
