Qubino Virtual Switch (Input 2 Switch) missing?
For devices supporting the Auto Discovery feature. Like ZWaveJS2MQTT, Zigbee2MQTT.
kimhav
Domoticz version: 2023.2
Post by kimhav »
Does zwave2mqtt support the usage of Qubino Virtual Switch (Input 2 Switch) which can be used to turn on a specific group/device? Configuration settings 100 allows to set the 'Enable / Disable Endpoints I2' to 'Binary Sensor' but not even sure if this is correct or whether it's not supported by z2m using virtual switches.
Domoticz version: 2025.1
Re: Qubino Virtual Switch (Input 2 Switch) missing?
Zwave2mqtt is renamed to Zwave-JS-UI now.
For these kind of questions you better check the Zwave-JS device database or the forum.
kimhav
Post by kimhav »
After the changing parameter 100 to 'binary switch' for the I2 one have to exclude and then include the Qubino unit to have z2jsui to detect the additional virtual switch. Unfortunalty what I wanted was to have the same behavious as the I1 switch which is mono-type. So while it worked fine to get the additional virtual switch; it didn't support my use case.
