Since ARM clock speed support was removed from domoticz 2024.1 and i do monitor this, i recreated it using a python plugin.
Installation can be done by:
- go to your plugins directory
- git pull https://github.com/akamming/Domoticz_pi ... eds_Plugin
- restart domoticz
- go to your hardware page in domoticz
- add the plugin with the name "Pi Clockspeeds"
it is very rudimentary, and does not check if you are installing actually on a pi. so expect errors if you are not using a raspberry pi
Futhermore i am now trying to force throttling to test the sensors, but cannot get my pi to get heated enough to start throttling, so pls let me know if the switches work or not...
Python plugin: pi clock speeds
