zwave.me uzb1 on debian bookworm on pi3b
akamming
Post by akamming »
I felt brave today, so i tried to upgrade to bookworm. So did a fresh install of raspberry pi os (bookworm 64 bit edition) on the 3b and then installed domoticz.
Only to find out i could not select a serial port for the zwave.me uzb1 on openzwave anymore. Diving a bit deeper i found also on os level it was missing (so the tip move to zwave js ui won't help here, the device is no longer recognized by the OS)
does anyone have an id how to get that serial port of the zwave.me uzb1 recognized on bookworm, is i can get domoticz to work with it again (either on openzwave or wave js ui)
(BTW: When putting back the old sd card with bullseye on it, all worked fine again...)
capitalT
Re: zwave.me uzb1 on debian bookworm on pi3b
Post by capitalT »
Do you have a little bit more info? Is /dev/serial/by-id totally empty?
solarboy
Domoticz version: 2024.6
Post by solarboy »
There are some Debian problems where "by-id" is not created and some extra config is required. It's a Debian bug.
https://www.reddit.com/r/debian/comment ... y_missing/
Intel NUC with Ubuntu Server VM (Proxmox),mosquitto(docker),RFXtrx433E,zwavejsUI (docker),Zigbee2mqtt(docker),SMA Hub (docker),Harmony Hub plugin, Kodi plugin,Homebridge(docker)+Google Home,APC UPS,SMA Modbus,Mitsubishi MQTT, Broadlink,Dombus
