I am experimenting with moving over to Docker following the guide here
https://www.domoticz.com/wiki/Docker
The guide mentions the possibilty of using a custom.sh script which should be placed in "userdata" however I do not have this folder in /opt/domoticz
Does anyone know the actual location to place this file ?
Custom.sh scripts location for Docker
- Domoticz version: 2024.6
Intel NUC with Ubuntu Server VM (Proxmox),mosquitto(docker),RFXtrx433E,zwavejsUI (docker),Zigbee2mqtt(docker),SMA Hub (docker),Harmony Hub plugin, Kodi plugin,Homebridge(docker)+Google Home,APC UPS,SMA Modbus,Mitsubishi MQTT, Broadlink,Dombus
- Domoticz version: 2024.7
Re: Custom.sh scripts location for Docker
See also https://hub.docker.com/r/domoticz/domoticz
After you have started domoticz a userdata folder (and some others for scripting) will be created.
- andreo
- Domoticz version: 2024.3
/opt/domoticz/userdata/customstart.sh
Latest version of Domoticz and more running on Docker|Raspberry Pi 4-B 8GB Bookworm|RF-Link|Klik Aan Klik Uit|Nefit easy|ESPeasy|P1 power meter|S0PCM-5 through Ser2Net|Alecto WS5500|FrtizBox|Satel Integra|Solis
Greetz Andre.
Greetz Andre.
Brilliant, thank you.
