Hello
I restored a backup that was made before my Zigbee2mqtt installation. So i lost all my zigbee devices.
Is there a way to recreate them in domoticz without resetting all devices in Zigbee2mqtt frontend ?
Thank you
Lost all my Zigbee devices after restore
- gizmocuz
Re: Lost all my Zigbee devices after restore
Why did you need to restore a backup?
You can issue the following commands when you login with SSH
cd domoticz
./updatebeta
Now you should be on the latest beta version and your should be able to work with zigbee2mqtt again.
cd domoticz
./updatebeta
anthropo
I only restored a database backup. I did it because i deleted a onewire device and i lost it, unabled to make it reborn...
anthropo
what is the procedure to reset the database and restart from scratch ?
thank you
thank you
manjh
- Domoticz version: 2020.2
Try to set the Z2D gui to "accept new hardware", see what happens.anthropo wrote: Tuesday 26 December 2023 12:39 what is the procedure to reset the database and restart from scratch ?
thank you
Hans
