ilkaskim
Posts: 19 Joined: Friday 20 August 2021 2:20
Post
by ilkaskim » Monday 25 December 2023 22:06
Good evening, I have a problem with my script that I can't solve on my own. I've looked at many sites but haven't found the right one. My script opens my garage door when I work that day. Because I mostly ride my motorcycle, it's practically impossible to always reach for the remote control. So far I have done the automatic opening with my cell phone (Tasker). This made it possible for me to stop the automatic opening if I didn't finish work normally. Maybe someone knows better how I can stop the countdown.
Happy holidays
return
on =
devices =
'Schichtkalender', -- Name of your device
logging =
level = domoticz.LOG_DEBUG,
marker = 'Schichtkalender',
execute = function(dz, item)
local variables = dz.variables('Schichtende')
if item.text == '' then
dz.variables('Frühschicht').set('0')
dz.variables('Spätschicht').set('0')
dz.variables('Nachtschicht').set('0')
dz.variables('Schichtende').set('0')
elseif variables.value == 1 then
elseif item.text == 'Frühschicht' and variables.value == 0 then
dz.variables('Frühschicht').set('1')
dz.devices('Rolltor Öffnen').switchOn().at('13:49')
elseif item.text == 'Spätschicht' and variables.value == 0 then
dz.variables('Spätschicht').set('1')
dz.devices('Rolltor Öffnen').switchOn().at('21:49')
elseif item.text == 'Nachtschicht' and variables.value == 0 then
dz.variables('Nachtschicht').set('1')
dz.devices('Rolltor Öffnen').switchOn().at('05:49')
Posts: 5904 Joined: Monday 28 January 2019 18:48
Domoticz version: 2024.7
Post
by waltervl » Monday 25 December 2023 22:56
To cancel the countdown (or queue) you can use cancelQueuedCommands()
Eg
dz.devices('Rolltor Öffnen').cancelQueuedCommands()
Next you need to discover that you used a tasker to open it. Perhaps you can send also a tasker command to set your user variable to a special state.
ilkaskim
Post
by ilkaskim » Monday 25 December 2023 23:25
waltervl wrote: ↑ Monday 25 December 2023 22:56
Eg
Thank you, that worked. I have modified the script so far. Using Tasker I send a variable (Schichtende) and the process aborts. Thank you
return
on =
devices =
logging =
marker = 'Kalender',
elseif item.text == 'Frühschicht' then
elseif item.text == 'Spätschicht' then
elseif item.text == 'Nachtschicht' then
