Request: AirconWithMe configurable pollinginterval
joostvanderlinde
Domoticz version: 2023.2
Post by joostvanderlinde »
I am using the AirconWithMe plugin for some time to control my Mitsubishi Heavy Industries airco/heatpump.
Works like a charm, but I notice that the data from the AirconWithMe is updated every 30 seconds. because I want to minimize the traffic on my network, I´d like to change this. Of course I can update the hard-coded value in the sources, but then I´d have to maintain my own codebase just for this....
Therefore I´d like to submit this request: Can anyone capable make the pollinginterval of the AirconWithMe plugin configurable (eg. via Hardware / AirconWithMe Wifi Airco Module / Setup, similar to other plugins so that the user can set it to something else?
Domoticz on BPI-M2-Pro (compiled on Ubuntu 22.04) and RPI (binary on Raspian 10)
RFXCom, Sonoff Zigbee stick, eBusd Adapter 5, P1, S0, Husdata H60 integration
Zigbee2MQTT AD, MQTT local, AirconWithMe, Ebusd, VolvoRecharge, PSA Car Controller
Domoticz version: 2025.1
Re: Request: AirconWithMe configurable pollinginterval
Seems to be hardcoded here: https://github.com/domoticz/domoticz/pull/4357
It is a pity in my opinion.
joostvanderlinde
Yeah, found that as well.
Hence my question if 'someone' could change the hardcoded constant into a hardware setup item. . . .
My programming skills are rather limited once it goes beyond backend (and 'simple') Python coding....
Perhaps contact the persons (LarsenDX, RDols) who programmed the change in Github.
