sonoff zigbee 3.0 usb stick
tjabas
Re: sonoff zigbee 3.0 usb stick
Post by tjabas »
i have now uppdated to bullseye and domoticz starts but some of the plugins has disappeared in the hardware menu, zigate,tuya,mqtt and more is gone, i also tried to install zigbeefordomoticz wich all went well but even that one wont show in the hardware menu.
any idea what i should do?
Domoticz version: 2024.7
Seems python needs some attention, see menu setup - about if python is recognized by Domoticz.
You probably need to install some extra modules, see wiki for instructions https://www.domoticz.com/wiki/Using_Python_plugins
tjabas
Post by tjabas »
it seems like python is missing, domoticz says oython version: none
do i install python in the domoticz folder?
tjabas
Post by tjabas »
i finally got it working, but my only problem now is that i cant get the zigbee plugin to work. i get these error messages:
2023-12-11 20:01:26.110 Error: zigate: Call to function 'onStop' failed, exception details:
2023-12-11 20:01:26.113 Error: zigate: Traceback (most recent call last):
2023-12-11 20:01:26.113 Error: zigate: File "/home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py", line 846, in onStop
2023-12-11 20:01:26.113 Error: zigate: _plugin.onStop()
2023-12-11 20:01:26.113 Error: zigate: File "/home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py", line 358, in onStop
2023-12-11 20:01:26.114 Error: zigate: WriteDeviceList(self, 0)
2023-12-11 20:01:26.114 Error: zigate: File "/home/pi/domoticz/plugins/Domoticz-Zigate/Modules/database.py", line 134, in WriteDeviceList
2023-12-11 20:01:26.114 Error: zigate: if self.pluginconf.pluginConf['pluginData'] is None or self.DeviceListName is None:
2023-12-11 20:01:26.114 Error: zigate: AttributeError: 'NoneType' object has no attribute 'pluginConf'
2023-12-11 20:01:26.657 Error: zigate: Call to function 'onStart' failed, exception details:
2023-12-11 20:01:26.674 Error: zigate: Traceback (most recent call last):
2023-12-11 20:01:26.674 Error: zigate: File "/home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py", line 842, in onStart
2023-12-11 20:01:26.674 Error: zigate: _plugin.onStart()
2023-12-11 20:01:26.674 Error: zigate: File "/home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py", line 224, in onStart
2023-12-11 20:01:26.674 Error: zigate: self.pluginconf = PluginConf(Parameters["HomeFolder"], self.HardwareID)
2023-12-11 20:01:26.674 Error: zigate: File "/home/pi/domoticz/plugins/Domoticz-Zigate/Classes/PluginConf.py", line 232, in __init__
2023-12-11 20:01:26.674 Error: zigate: self._load_Settings()
2023-12-11 20:01:26.674 Error: zigate: File "/home/pi/domoticz/plugins/Domoticz-Zigate/Classes/PluginConf.py", line 350, in _load_Settings
2023-12-11 20:01:26.674 Error: zigate: _pluginConf = json.load( handle, encoding=dict)
2023-12-11 20:01:26.674 Error: zigate: File "/usr/lib/python3.9/json/__init__.py", line 293, in load
2023-12-11 20:01:26.674 Error: zigate: return loads(fp.read(),
2023-12-11 20:01:26.674 Error: zigate: File "/usr/lib/python3.9/json/__init__.py", line 359, in loads
2023-12-11 20:01:26.674 Error: zigate: return cls(**kw).decode(s)
2023-12-11 20:01:26.674 Error: zigate: TypeError: __init__() got an unexpected keyword argument 'encoding'
Perhaps file access? Did you follow the install instruction on the Z4D wiki?
tjabas
Post by tjabas »
waltervl wrote: Monday 11 December 2023 21:37 Perhaps file access? Did you follow the install instruction on the Z4D wiki?
I missed that part here I need to delete the old zigate plugin, I did that and now it initializing the new sonoff dongle, unfortunately it seems like all the nodes on my zigate got deleted, but it's only 28 nodes so I will iclufe them again.
But now I have noticed that shelly mqqt isn't working after updating to bullseye, it's always something else..
tjabas
Post by tjabas »
after a few days of upgrading to bullseye and domoticz 2023.2 i got almost evertything working exept, shelly MQTT and some other plugins.
but i have now gone back to buster and 2022.2, everything now works exept zigbeefordomoticz and my sonoff stick.
is there a way to get zigbeefordomoticz and my sonoff stick to work with buster and 2022.2?
is there and older plugin version of zigbeefordomoticz that works with buster?
Go the docker way.
tjabas
Post by tjabas »
Ok, so I won't get these problems with docker?
tjabas
Post by tjabas »
isnt there any way to get the zonoff 3.0 stick to work with buster and dmoticz verison 2022.2?
