For some reason my Opentherm gives periodic misreadings and sends them to my domoticz system.
within my dzvents scripts to control radiators i ingnore values below 10 when reading my thermostat temperature of the livingroom.
Is this a known issue?
is it possible to fix this within domoticz?
see attached image
Opentherm wrong measurements
- Domoticz version: 2025.1
Re: Opentherm wrong measurements
No, this is an Opentherm issue. Did you ask Opentherm Gateway if you can prevent these misreadings?
dizzeenl
i will do
willemd
- Domoticz version: 2024.1
Could also be an issue in the thermostat, instead of Opentherm gateway.dizzeenl wrote: Tuesday 05 December 2023 8:45 For some reason my Opentherm gives periodic misreadings and sends them to my domoticz system.
Striking that it is a very regular pattern, every hour, but then some periods during the day no issue.
Every day the same pattern?
