Domoticz-Google-Assistant (dzga) Topic is solved
gvandick
Re: Domoticz-Google-Assistant (dzga)
file ngrok.yml must install in ngrok2/config this is an hiden file use ls -a to show hidden files.
daroot
- Domoticz version: 2023.2
Since a few weeks I'm using dzga, which works almost flawlessly. Keep up that good work.
I was looking for a way to get notifications of someone pressing our doorbell on my Google Home speakers and Nest Hub.
I saw that's also possible with dzga, but I can't seem to get it to work.
I have a simple old Friedland wireless 433MHz doorbell, which I made "smart" by putting a Shelly 1 between the doorbell-sender and a classic doorbell knob next to the door. When this knob is pressed, the shelly flips it's relay which is connected to the push-button of the sender/transmitter thing. This way, the receiver/chime is actually ringing, and my Domoticz system is aware of the doorbell being used. This way I can send notifications via Domoticz to my phone via Telegram or other systems.
So far so good..
In Domoticz, I set up HTTP notifications. The test-button works: I see it passing by in the logfile @ dzga.
Then when I setup notifications on the Shelly button or the shelly relay, I get errors. More carefull reading gives me the clue that I won't work with light-switches, only with doorbells and smoke-detectors. Fair enough. I changed the switch type of the shelly to Doorbell, changed the notification, resynced the devices in dzga, the doorbell is then recognized as type Doorbell, but it won't show up in my Google Home app. I did add it to the correct room in Domoticz.
I then tested it with a dummy switch. Made it also type Doorbell, dzga sees it after resyncing, but it's not visible in Google Home app. When I change the type back to Lightswitch, it does show up.
When I change the dummy switch to Smoke detector, resync, and then check the Google Home app, it does show up. Then it's also possible to turn on notifications from within the Home app. After doing that, and virtually pressing the smoke detector in Domoticz, I do get an audio notification on my google home speakers.
Is this simply not yet working for doorbells, or am I missing something?
Some info:
Version: 2023 2
Build Hash: 19efd039c
Compile Date: 2023-07-21 17:23:44
dzVents Version: 3 1 8
Python Version: 3 7 3 (default, Jun 29 2023, 18:03:57) [GCC 8 3 0]
DZGA version 1 23 10
Running on a RPi 3B+
So far so good..
Some info:
Version: 2023 2
gvandick
Synchronize devices to Google app failed. Devices showing "offline" in app, but voice control works for lamps and blinds. Get message something go's wrong. I made a new project on Google . Several times but doesn't work. I use ngrok no problem. Devices import from domoticz to dzga no problem. In dzga log all devices listed as online: false 2023-10-02 07:38:20 - ERROR - Unexpected error serializing query for <helpers.AogState object at 0x753335d0> Anyone idea how to solve this.
Kedi
I use nodered with https://flows.nodered.org/node/node-red ... -smarthomedaroot wrote: Wednesday 27 September 2023 14:48 Is this simply not yet working for doorbells, or am I missing something?
I can get any textual message be spoken by my Google devices.
rensbr
I have updated Domoticz to the latest version 2023.2, but not dzga does not work anymore. I think this has something to do with the new safety features.
I have created a separate user for Google Assistant and when I try to login with that user into Domoticz trough the http port, I cannot login anymore. I have selected 'Allow Basic Authentication over plain HTTP', but that did not do the trick. I can login trough the https port, but when i change that into the configuration of dzga, the container does not want to start anymore.
I'm running Domoticz and dgza in docker.
Versions:
Domoticz: 2023.2
dzga: 1.23.12
Does anybody has the solution?
Edit: I'm running Domoticz on port 8081 and that was not in my dockerfile, so I have changed that and now it works:
Versions:
Domoticz: 2023.2
dzga: 1.23.12
FROM domoticz/domoticz
EXPOSE 8080
EXPOSE 8081
EXPOSE 444
WORKDIR /opt/domoticz
RUN pip install --upgrade pip
RUN pip3 install --upgrade pip
#FOR LG plugin
RUN pip install pylgtv paramiko
#FOR Precense detection
RUN pip install paramiko
RUN pip install parallel-ssh
#FOR conbee II plugin
RUN pip install requests
RUN pip3 install requests
#FOR airco
RUN pip3 install wheel
RUN pip3 install pyfujitsu
ENTRYPOINT ["docker-entrypoint.sh"]
CMD ["/opt/domoticz/domoticz"]
louresman
Hello
I made a clean install of Raspios Bullseye and of Domoticz Version: 2023 2 with Python Version: 3 9 2
All running grreat with no issues.
I have have enabled Allow Basic Authentication over plain HTTP
Installed DZGA-Flask version and after issuing:
sudo systemctl status dzga-flask it reports no errors and that it is active and running.
So apparently it is running but I cannot accsess the web interface using ip address:8181
I just get an "unable to connect" message.
Any assitance on how to get this working will be apreciated
daroot
Dewgew made a new project: DZGA-Flask.daroot wrote: Wednesday 27 September 2023 14:48 Since a few weeks I'm using dzga, which works almost flawlessly. Keep up that good work.
So far so good..
Some info:
Version: 2023 2
I installed that project (in Docker), works pretty much the same, but now the notifications on the speakers also do work. Very happy with the great work!
louresman
Is no one affected by the problem I am encountering in not beeing able to bring up the Dzga configuration page?
I had everythig working in a prevoius instalation using Rasperry Pi OS Stretch, but decided to do a clean install of the OS. I opted for Bullseye because I believe it is the version which is currently not presenting problems as far as Domoticz is concerned.
After a fresh install of the OS and of the latest Domoticz and resotring the database, everything is working as it should. So next I try to install DZGA running the instalation script and it also reports it is running when I check its status. But I cannot bring up the config screen at <IP Address:3030/settings>.
After multiple reinstalls of the OS, I get the same result. After that I tried installing Raspberry Bookworm, Domoticz runs on this as well, but still no DZGA config page. I also tried DZGA-Flask on another reinstalation but no config screen at <IP Address:8181>.
Since no one else seems to be complaining, I sure it must be something I am missing.
This is all native install, not Docker. Any hints on what could be the cause? Really frustrating as everything worked great on the previous install of Stretch and the older DZGA version.
- DewGew
- Domoticz version: V4.10618
Have you tryed running dzag manually? Maybe its the systemtcl service issue.louresman wrote: Thursday 23 November 2023 15:12 Is no one affected by the problem I am encountering in not beeing able to bring up the Dzga configuration page?
For dzga:
cd /home/${USER}/
sudo systemctl stop dzga #If service is running
source Domoticz-Google-Assistant/env/bin/activate
python3 Domoticz-Google-AssistantCode: Select all
sudo systemctl stop dzga-flask #If service is running
cd /home/${USER}/DZGA-Flask
source env/bin/activate
python3 smarthome.pyRaspberry Pi 3 | domoticz | Aeon Labs Z-Stick GEN5 | RFlink gateway
jpvaneijk
- Domoticz version: latest
The same issue here. Fresh install of Bookworm on a RPi 5. No User interface on both DZGA and DZGA FLASK. Not on localhost:8181 and ip:8181louresman wrote: Thursday 23 November 2023 15:12 Is no one affected by the problem I am encountering in not beeing able to bring up the Dzga configuration page?
All was fine on RPi 4B that had Buster installed. I used DZGA on that.
sudo systemctl start dzga-flaskCode: Select all
sudo systemctl stop dzga-flasCode: Select all
sudo systemctl status dzga-flaskNov 25 15:29:07 Domoticz systemd[1]: Stopped dzga-flask.service - DZGA-Flask dashboard.
Nov 25 15:29:07 Domoticz systemd[1]: dzga-flask.service: Start request repeated too quickly.
Nov 25 15:29:07 Domoticz systemd[1]: dzga-flask.service: Failed with result 'exit-code'.
Nov 25 15:29:07 Domoticz systemd[1]: Failed to start dzga-flask.service - DZGA-Flask dashboard.
A bit of help would be great!
EDIT:
I've got another Rpi 4B 8GB running on Bullseye and installed DZGA-Flask once more.
bash <(curl -s https://raw.githubusercontent.com/DewGew/dzga-installer/master/DZGA-Flask-install.sh)dzga-flask.service - DZGA-Flask dashboard
Loaded: loaded (/etc/systemd/system/dzga-flask.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Sun 2023-11-26 10:42:00 CET; 8min ago
Process: 3201 ExecStart=/home/pi/DZGA-Flask/env/bin/python /home/pi/DZGA-Flask/smarthome.py (code=exited, status=1/FAILURE)
Main PID: 3201 (code=exited, status=1/FAILURE)
CPU: 1.666s
nov 26 10:42:00 Server systemd[1]: dzga-flask.service: Consumed 1.666s CPU time.
nov 26 10:42:00 Server systemd[1]: dzga-flask.service: Scheduled restart job, restart counter is at 5.
nov 26 10:42:00 Server systemd[1]: Stopped DZGA-Flask dashboard.
nov 26 10:42:00 Server systemd[1]: dzga-flask.service: Start request repeated too quickly.
nov 26 10:42:00 Server systemd[1]: dzga-flask.service: Failed with result 'exit-code'.
nov 26 10:42:00 Server systemd[1]: Failed to start DZGA-Flask dashboard.
Just a friendly heads-up:
Do you know that there are 2 installation-codes on Github?
Under the tab Wiki is
bash <(curl -s https://raw.githubusercontent.com/DewGew/dzga-installer/master/dzga-flask-install.sh)Under the tab Code is
bash <(curl -s https://raw.githubusercontent.com/DewGew/dzga-installer/master/DZGA-Flask-install.sh)-
louresman
@DewGew thanks for the suggestion. I have followed the install instructions very carefully.
I have tried running dzga manually in both instances of DZGA and DZGA-Flask on the various installs I have tried.
It reports DZGA is running when checking the status bit I still cannot access the web interface.
- fabry91
- Domoticz version: 2022.2
since I have updated my Domoticz (running on Synology - DSM 7.1) to the latest release v2023.2 (build 15674) the DGA doesn't connect to the Domoticz server.
When I login to the console 192.xxx.xx.x:3031/settings it keeps me message me "Connection to Domoticz refused! Check configuration." but I didn't change anything on the configuration of Domoticz and DGA.
Sync device results in "Page not found!: 500 Server Error: Internal Server Error for url: https://homegraph.googleapis.com/v1/devices:requestSync"
Anybody have had this problem?
Thank you in advanced!
- fabry91
Solved, in Domoticz (menu setup - settings - security) tipped "allow http api calls", this solved the problem.fabry91 wrote: Monday 27 November 2023 16:29 Hello,
More info here: viewtopic.php?t=40205
jpvaneijk
Unfortunately, this is not a solution for me. I had already configured this nicely.
Since Bookworm there seem to be some problems with pip in Python and I thought that might be where the problem lay. Unfortunately, that does not appear to be the case either.
It applies to both DZGA and DZGA-Flak. I can't get the user interface up and running with anything.
My hopes lie with Dewgew who will probably come up with a simple solution soon, I seem to be missing something.
I was able to install all the other plugins and software/hardware just fine but unfortunately I am stuck on, what I think is just so important, linking everything through to my Google devices at home.
My problem seems to be the same as Louresman's. So just a little more patience (I hope)
- DewGew
Install script for DZGA-Flask is updated and should now work.jpvaneijk wrote: Monday 27 November 2023 20:52 Unfortunately, this is not a solution for me. I had already configured this nicely.
Remove all old service and DZGA-Flask folder first
bash <(curl -s https://raw.githubusercontent.com/DewGew/dzga-installer/master/DZGA-Flask-install.sh)Raspberry Pi 3 | domoticz | Aeon Labs Z-Stick GEN5 | RFlink gateway
jpvaneijk
Hi DewGew,
Very glad you apparently had the opportunity to take a look. Unfortunately, your work so far has not had the desired result. Below I'll just show you what's happening on my end and I'd love to hear if I can test something for you.
Thanks in advance!
EDIT:
Good to know is that on my RPi 4B with Bulleye installed I now can get my UI up DewGew. Great!
However It is verry much advised to install Bookworm om my new RPi 5 and as described above, no such luck. Could it be a Bookworm issue?
It does make me curious to know if Louresman is moving on now?
Thanks in advance!
Install DZGA-Flask
*Note : Dzga-Flask is free
*for personal use.
Install the DZGA-Flask?
(y)es or (N)o? Default : No
y
Installing DZGA-Flask
Cloning into 'DZGA-Flask'...
remote: Enumerating objects: 1433, done.
remote: Counting objects: 100% (519/519), done.
remote: Compressing objects: 100% (297/297), done.
remote: Total 1433 (delta 330), reused 330 (delta 218), pack-reused 914
Receiving objects: 100% (1433/1433), 5.65 MiB | 9.24 MiB/s, done.
Resolving deltas: 100% (693/693), done.
This script must run as MYUSERNAME, trying to change user...
Installing system requirements...
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
libffi-dev is already the newest version (3.4.4-1).
libssl-dev is already the newest version (3.0.11-1~deb12u2+rpt1).
python3 is already the newest version (3.11.2-1+b1).
python3-dev is already the newest version (3.11.2-1+b1).
python3-pip is already the newest version (23.0.1+dfsg-1+rpt1).
python3-venv is already the newest version (3.11.2-1+b1).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
DZGA-Flask requires python 3.5 or greater
Installing dzga-flask.service...
Created symlink /etc/systemd/system/multi-user.target.wants/dzga-flask.service → /etc/systemd/system/dzga-flask.service.
Starting DZGA-Flask...
Login to DZGA-Flask Server UI at: http://ip.address:8181
Default username is admin and default password is smarthome
MYUSERNAME@Domoticz:~ $ sudo systemctl start dzga-flask
MYUSERNAME@Domoticz:~ $ sudo systemctl status dzga-flask
× dzga-flask.service - DZGA-Flask dashboard
Loaded: loaded (/etc/systemd/system/dzga-flask.service; enabled; preset: enabled)
Active: failed (Result: exit-code) since Fri 2023-12-01 10:52:38 CET; 5s ago
Duration: 1ms
Process: 2302 ExecStart=/home/MYUSERNAME/DZGA-Flask/env/bin/python /home/[email protected]/DZGA-Flask/smarthome.py (code=exited, status=203/EXEC)
Main PID: 2302 (code=exited, status=203/EXEC)
CPU: 1ms
Dec 01 10:52:38 Domoticz systemd[1]: dzga-flask.service: Scheduled restart job, restart counter is at 5.
Dec 01 10:52:38 Domoticz systemd[1]: Stopped dzga-flask.service - DZGA-Flask dashboard.
Dec 01 10:52:38 Domoticz systemd[1]: dzga-flask.service: Start request repeated too quickly.
Dec 01 10:52:38 Domoticz systemd[1]: dzga-flask.service: Failed with result 'exit-code'.
Dec 01 10:52:38 Domoticz systemd[1]: Failed to start dzga-flask.service - DZGA-Flask dashboard.
[email protected]@Domoticz:~ $
Last edited by jpvaneijk on Friday 01 December 2023 16:21, edited 1 time in total.
Xavier82
I have today installed DZGA-Flask on a Raspberry Pi 4B (8GB), with OS Bullseye, Domoticz 2023.2 (BETA build 15679).
This is my test-environment.
I think I have entered all information correct but the Dashboard doesn't display the devices from Domoticz.
I can't find any clue in the logging of DZGA-flask.
The only message I get is:
No other message is displayed.
What could be wrong?
I checked the user in Domoticz (incl. password)--> changing password give me:
ofcourse also restarted DZGA-flask....
In the old DZGA version there was the use of NGROK, how and where in DZGA-flask is this configurable?
UPDATE:
I now get this error in the logg:
2023-12-01 11:34:46 http://X.X.X.X:8084 "GET /json.htm?type=command¶m=getversion HTTP/1.1" 200 46What could be wrong?
2023-12-01 11:29:34 http://X.X.X.X.:8084 "GET /json.htm?type=command¶m=getusers HTTP/1.1" 401 91In the old DZGA version there was the use of NGROK, how and where in DZGA-flask is this configurable?
UPDATE:
2023-12-01 13:09:43 Error on request:
File "/home/pi/DZGA-Flask/env/lib/python3.9/site-packages/werkzeug/serving.py", line 364, in run_wsgi
execute(self.server.app)
File "/home/pi/DZGA-Flask/env/lib/python3.9/site-packages/werkzeug/serving.py", line 328, in execute
write(data)
File "/home/pi/DZGA-Flask/env/lib/python3.9/site-packages/werkzeug/serving.py", line 300, in write
self.wfile.write(hex(len(data))[2:].encode())
File "/usr/lib/python3.9/socketserver.py", line 799, in write
self._sock.sendall(b)
TimeoutError: [Errno 110] Connection timed out-
louresman
Hi DewGew,
After the latest update, I can now access the user interface and see my Domoticz devices.
Thanks for your work fixing this issue.
jpvaneijk
Just to be clear: This is not on Bookworm or a RPi 5 right?louresman wrote: Friday 01 December 2023 20:44 Hi DewGew,
Thanx
louresman
In response to jpvaneijk
I am running a fresh install of Bullseye on a RPi 3 and DZGA-Flask. I had previously installed Bookworm, thought the issue was the OS and reverted back to Bullseye. I only managed to get everything working with DZGA-Flask v23.9. Previously I could not launch the web inerface.
