Errors after plugin update to 7.1.005 [2.150]
Cizetta
Post by Cizetta »
I'm using ZigBeeForDomoticz on a Raspberry 3B+ with a Sonoff Zigbee 3.0 USB Dongle Plus.
I was using version 7.1.003 of the plugin without any errors.
Two hours ago I saw that there is a new release from today and decided to update the plugin.
Update was successful (stopped Domoticz, pulled the new version, updated the required python packages, etc.)
Now plugins start and it is working fine (I can add new devices, control the already connected ones) but I get such error every several minutes:
From Domoticz log:
2023-11-18 18:32:19.774 Error: Zigbee Gate: forwarder_thread - Error while receiving a Coordinator command
2023-11-18 18:32:19.785 Error: Zigbee Gate: Issue in request 0180020024ff0001040004010102afb9020000198102ff005103, dumping stack: Traceback (most recent call last):
2023-11-18 18:32:19.785 File "/home/pi/domoticz/plugins/Domoticz-Zigbee/Classes/ZigpyTransport/forwarderThread.py", line 41, in forwarder_thread
2023-11-18 18:32:19.785 forward_message(self, message)
2023-11-18 18:32:19.785 File "/home/pi/domoticz/plugins/Domoticz-Zigbee/Classes/ZigpyTransport/instrumentation.py", line 31, in f_out
2023-11-18 18:32:19.785 result = f_in(self, message)
2023-11-18 18:32:19.785 File "/home/pi/domoticz/plugins/Domoticz-Zigbee/Classes/ZigpyTransport/forwarderThread.py", line 57, in forward_message
2023-11-18 18:32:19.785 self.F_out(message)
2023-11-18 18:32:19.785 File "/home/pi/domoticz/plugins/Domoticz-Zigbee/plugin.py", line 874, in processFrame
2023-11-18 18:32:19.785 ZigateRead(self, Devices, Data)
2023-11-18 18:32:19.785 File "/home/pi/domoticz/plugins/Domoticz-Zigbee/Modules/input.py", line 177, in ZigateRead
2023-11-18 18:32:19.785 _decoding(self, Devices, MsgData, MsgLQI)
2023-11-18 18:32:19.785 File "/home/pi/domoticz/plugins/Domoticz-Zigbee/Modules/input.py", line 2514, in Decode8062
2023-11-18 18:32:19.785 self.groupmgt.look_for_group_member_ship_response(MsgData)
2023-11-18 18:32:19.785 AttributeError: 'NoneType' object has no attribute 'look_for_group_member_ship_response'
From Plugin:
0:
Time: "18/11/2023 18:40:37"
Module: "TransportFrwder"
nwkid: "None"
PluginHealth: "Ready"
message: "forwarder_thread - Error while receiving a Coordinator command"
PermitToJoin: Object {"Duration":0,"Starttime":1700325052}
Thread: "ZigpyForwarder_39"
1:
Module: "TransportWrter"
nwkid: "None"
message: "Issue in request 0180020028ff00010400040101022820020000198b020f0100005103, dumping stack: Traceback (most recent call last): File "/home/pi/domoticz/plugins/Domoticz-Zigbee/Classes/ZigpyTransport/forwarderThread.py", line 41, in forwarder_thread forward_message(self, message) File "/home/pi/domoticz/plugins/Domoticz-Zigbee/Classes/ZigpyTransport/instrumentation.py", line 31, in f_out result = f_in(self, message) File "/home/pi/domoticz/plugins/Domoticz-Zigbee/Classes/ZigpyTransport/forwarderThread.py", line 57, in forward_message self.F_out(message) File "/home/pi/domoticz/plugins/Domoticz-Zigbee/plugin.py", line 874, in processFrame ZigateRead(self, Devices, Data) File "/home/pi/domoticz/plugins/Domoticz-Zigbee/Modules/input.py", line 177, in ZigateRead _decoding(self, Devices, MsgData, MsgLQI) File "/home/pi/domoticz/plugins/Domoticz-Zigbee/Modules/input.py", line 2514, in Decode8062 self.groupmgt.look_for_group_member_ship_response(MsgData) AttributeError: 'NoneType' object has no attribute 'look_for_group_member_ship_response' "
context: Object {"Message code:":"'NoneType' object has no attribute 'look_for_group_member_ship_response'","Stack Trace":"Traceback (most recent call last):\n File \"/home/pi/domoticz/plugins/Domoticz-Zigbee/Classes/ZigpyTransport/forwarderThread.py\", line 41, in forwarder_thread\n forward_message(self, message)\n File \"/home/pi/domoticz/plugins/Domoticz-Zigbee/Classes/ZigpyTransport/instrumentation.py\", line 31, in f_out\n result = f_in(self, message)\n File \"/home/pi/domoticz/plugins/Domoticz-Zigbee/Classes/ZigpyTransport/forwarderThread.py\", line 57, in forward_message\n self.F_out(message)\n File \"/home/pi/domoticz/plugins/Domoticz-Zigbee/plugin.py\", line 874, in processFrame\n ZigateRead(self, Devices, Data)\n File \"/home/pi/domoticz/plugins/Domoticz-Zigbee/Modules/input.py\", line 177, in ZigateRead\n _decoding(self, Devices, MsgData, MsgLQI)\n File \"/home/pi/domoticz/plugins/Domoticz-Zigbee/Modules/input.py\", line 2514, in Decode8062\n self.groupmgt.look_for_group_member_ship_response(MsgData)\nAttributeError: 'NoneType' object has no attribute 'look_for_group_member_ship_response'\n","Data":"0180020028ff00010400040101022820020000198b020f0100005103"}
LastLog: 1
StartTime: "18/11/2023 18:03:53"
FirmwareVersion: "Z-Stack 3.30+ (build 20210708)"
FirmwareMajorVersion: "20"
PluginVersion: "stable7-7.1.005"
LastLog: 0
As I stated it works fine (or at least I haven't found any issues) so I'm just reporting this error.
pipiche
Re: Errors after plugin update to 7.1.005 [2.150]
Post by pipiche »
Thanks for reporting. Most-likely this happen during the startup phase.
Will fix it in the next version
Cizetta
Post by Cizetta »
Thank you for the quick reply!
Have a nice weekend and cheers!
