Xenomes wrote: Thursday 04 May 2023 15:58 Can you put the plugin on debug all, then the plugin will give a line where the error condors.
2023-05-04 18:26:05.709 Error: TinyTUYA: Device read failed: bfd6bda7f3a84e2064d97h
2023-05-04 18:26:06.182 TinyTUYA: Acquiring GIL for 'onHeartbeatCallback'
2023-05-04 18:26:15.005 TinyTUYA: Pushing 'onHeartbeatCallback' on to queue
2023-05-04 18:26:15.055 TinyTUYA: Processing 'onHeartbeatCallback' message
2023-05-04 18:26:15.055 TinyTUYA: Acquiring GIL for 'onHeartbeatCallback'
2023-05-04 18:26:15.055 TinyTUYA: Calling message handler 'onHeartbeat' on 'module' type object.
2023-05-04 18:26:15.055 TinyTUYA: onHeartbeat called
2023-05-04 18:26:15.055 TinyTUYA: onHeartbeat called skipped
2023-05-04 18:26:15.056 TinyTUYA: Acquiring GIL for 'onHeartbeatCallback'
2023-05-04 18:26:25.029 TinyTUYA: Pushing 'onHeartbeatCallback' on to queue
2023-05-04 18:26:25.079 TinyTUYA: Processing 'onHeartbeatCallback' message
2023-05-04 18:26:25.079 TinyTUYA: Acquiring GIL for 'onHeartbeatCallback'
2023-05-04 18:26:25.079 TinyTUYA: Calling message handler 'onHeartbeat' on 'module' type object.
2023-05-04 18:26:25.079 TinyTUYA: onHeartbeat called
2023-05-04 18:26:25.080 TinyTUYA: onHeartbeat called skipped
2023-05-04 18:26:25.080 TinyTUYA: Acquiring GIL for 'onHeartbeatCallback'
2023-05-04 18:26:35.014 TinyTUYA: Pushing 'onHeartbeatCallback' on to queue
2023-05-04 18:26:35.065 TinyTUYA: Processing 'onHeartbeatCallback' message
2023-05-04 18:26:35.065 TinyTUYA: Acquiring GIL for 'onHeartbeatCallback'
2023-05-04 18:26:35.065 TinyTUYA: Calling message handler 'onHeartbeat' on 'module' type object.
2023-05-04 18:26:35.065 TinyTUYA: onHeartbeat called
2023-05-04 18:26:35.065 TinyTUYA: onHeartbeat called skipped
2023-05-04 18:26:45.042 TinyTUYA: Pushing 'onHeartbeatCallback' on to queue
2023-05-04 18:26:45.093 TinyTUYA: Processing 'onHeartbeatCallback' message
2023-05-04 18:26:45.093 TinyTUYA: Acquiring GIL for 'onHeartbeatCallback'
2023-05-04 18:26:45.093 TinyTUYA: Calling message handler 'onHeartbeat' on 'module' type object.
2023-05-04 18:26:45.093 TinyTUYA: onHeartbeat called
2023-05-04 18:26:45.093 TinyTUYA: onHeartbeat called skipped
2023-05-04 18:26:55.023 TinyTUYA: Pushing 'onHeartbeatCallback' on to queue
2023-05-04 18:26:55.073 TinyTUYA: Processing 'onHeartbeatCallback' message
2023-05-04 18:26:55.073 TinyTUYA: Acquiring GIL for 'onHeartbeatCallback'
2023-05-04 18:26:55.073 TinyTUYA: Calling message handler 'onHeartbeat' on 'module' type object.
2023-05-04 18:26:55.073 TinyTUYA: onHeartbeat called
2023-05-04 18:26:55.074 TinyTUYA: onHeartbeat called skipped
2023-05-04 18:26:55.074 TinyTUYA: Acquiring GIL for 'onHeartbeatCallback'
2023-05-04 18:27:05.036 TinyTUYA: Pushing 'onHeartbeatCallback' on to queue
2023-05-04 18:27:05.087 TinyTUYA: Processing 'onHeartbeatCallback' message
2023-05-04 18:27:05.087 TinyTUYA: Acquiring GIL for 'onHeartbeatCallback'
2023-05-04 18:27:05.087 TinyTUYA: Calling message handler 'onHeartbeat' on 'module' type object.
2023-05-04 18:27:05.087 TinyTUYA: onHeartbeat called
2023-05-04 18:27:05.087 TinyTUYA: onHeartbeat called skipped
2023-05-04 18:27:15.018 TinyTUYA: Pushing 'onHeartbeatCallback' on to queue
2023-05-04 18:27:15.072 TinyTUYA: Processing 'onHeartbeatCallback' message
2023-05-04 18:27:15.073 TinyTUYA: Acquiring GIL for 'onHeartbeatCallback'
2023-05-04 18:27:15.073 TinyTUYA: Calling message handler 'onHeartbeat' on 'module' type object.
2023-05-04 18:27:15.074 TinyTUYA: onHeartbeat called
2023-05-04 18:27:15.074 TinyTUYA: onHeartbeat called last run: 69.36461281776428
2023-05-04 18:27:15.075 TinyTUYA: Device name=Cleverio Wifi Outdoor Plug id=bfd6bda7f3a84e2064d97h category=switch
2023-05-04 18:27:15.651 TinyTUYA: Update devices in Domoticz
2023-05-04 18:27:15.657 TinyTUYA: handleThread: 15 line 955
2023-05-04 18:27:15.657 TinyTUYA: Device name=Cleverio AF-F100 id=43035720e098061d58bc category=fan
2023-05-04 18:27:15.657 Error: TinyTUYA: Device read failed: bfd6bda7f3a84e2064d97hCode: Select all
2023-05-04 18:30:33.433 TinyTUYA: Device ID: 'bfd6bda7f3a84e2064d97h'
2023-05-04 18:30:33.433 TinyTUYA: --->Unit Count: '5'
2023-05-04 18:30:33.433 TinyTUYA: --->Unit: 1
2023-05-04 18:30:33.433 TinyTUYA: --->Unit Name: 'Tvättmaskin'
2023-05-04 18:30:33.433 TinyTUYA: --->Unit nValue: 1
2023-05-04 18:30:33.433 TinyTUYA: --->Unit sValue: 'On'
2023-05-04 18:30:33.433 TinyTUYA: --->Unit LastLevel: 0
2023-05-04 18:30:33.433 TinyTUYA: --->Unit: 11
2023-05-04 18:30:33.433 TinyTUYA: --->Unit Name: 'Tvättmaskin (A)'
2023-05-04 18:30:33.433 TinyTUYA: --->Unit nValue: 0
2023-05-04 18:30:33.433 TinyTUYA: --->Unit sValue: '114'
2023-05-04 18:30:33.434 TinyTUYA: --->Unit LastLevel: 0
2023-05-04 18:30:33.434 TinyTUYA: --->Unit: 12
2023-05-04 18:30:33.434 TinyTUYA: --->Unit Name: 'Tvättmaskin: Current Watt Meter'
2023-05-04 18:30:33.434 TinyTUYA: --->Unit nValue: 0
2023-05-04 18:30:33.434 TinyTUYA: --->Unit sValue: '7'
2023-05-04 18:30:33.434 TinyTUYA: --->Unit: 13
2023-05-04 18:30:33.434 TinyTUYA: --->Unit Name: 'Tvättmaskin (V)'
2023-05-04 18:30:33.434 TinyTUYA: --->Unit sValue: '234'
2023-05-04 18:30:33.434 TinyTUYA: --->Unit: 14
2023-05-04 18:30:33.434 TinyTUYA: --->Unit Name: 'Tvättmaskin: kWh Meter'
2023-05-04 18:30:33.434 TinyTUYA: --->Unit sValue: '7;56422.9900833333'
2023-05-04 18:30:33.435 TinyTUYA: Pushing 'PollIntervalDirective' on to queue
2023-05-04 18:30:33.416 Status: TinyTUYA: Initialized version 1.5.5, author 'Xenomes'
2023-05-04 18:30:34.479 TinyTUYA: No device data returned for Tuya. Trying again!
2023-05-04 18:30:34.936 TinyTUYA: Scanning for tuya devices on network...
2023-05-04 18:30:52.971 TinyTUYA: Device name=Cleverio Wifi Outdoor Plug id=bfd6bda7f3a84e2064d97h category=switch
2023-05-04 18:30:53.580 TinyTUYA: Run Startup script
2023-05-04 18:30:53.581 TinyTUYA: (TinyTUYA) Creating Unit 'Cleverio Wifi Outdoor Plug (mA)'.
2023-05-04 18:30:53.584 TinyTUYA: Update devices in Domoticz
2023-05-04 18:30:53.592 TinyTUYA: handleThread: 15 line 955
2023-05-04 18:30:53.592 TinyTUYA: Device name=Cleverio AF-F100 id=43035720e098061d58bc category=fan
2023-05-04 18:30:53.581 Error: TinyTUYA: (TinyTUYA) Unit creation failed, Domoticz settings prevent accepting new devices.
2023-05-04 18:30:53.591 Error: TinyTUYA: Device read failed: bfd6bda7f3a84e2064d97h
