Netatmo authentication changes Oct 2022
Re: Netatmo authentication changes Oct 2022
If a dev knows how to change the code, I can test it with my Netatmo account.
Raspbian Buster on Raspberry pi 3 B+ Domoticz Version: 2023.2 (build 15474)
jcb2
I have the same issue with Domoticz 2023.2
Many test with change of password with '!', '/', '+', '-' but always one autentification error : 2023-08-26 10:08:26.134 Error: Météo: No access granted, check username/password...
Any proposal ?
Jean-Charles
Any proposal ?
Jean-Charles
- Domoticz version: 2026.3
Changes are being discussed on GitHub. https://github.com/domoticz/domoticz/issues/5766
jcb2
We hope a quick solving, in advance thank to the development dream team.
And one day a local API to have an no-cloud solution ...
ccaru
Has anybody worked out a solution to the Netatmo authentication issue ? I was relying on my netatmo wind, rain, temp sensors for a number of automated tasks and i've lost all that up until i'm able to reconnect.
RFXCom, Somfy RTS, 433Mhz Lighting, Evohome, Smart watering via Netatmo, solenoid valves, soil humidity sensors, Airthings Radon via bluetooth, Marley heat recovery fresh air units, Blue Iris, Alexa via DA Bridge.
See the github issue, it seems quiet now.
also check topic viewtopic.php?t=40092 that has a dzvents solution in it for some setups.
- kiddigital
A first Pull Request has been created to address the issue of authentication. Once it makes its way into the Beta, Netatmo owners can start testing it.
ccaru
Great that it's moving. I had some dzvents scripts that used to work before but I just can't get anything to work anymore. Tried following the new examples but no luck.
- kiddigital
Try Beta build 15535 (and up).
Instructions from the PR: https://github.com/domoticz/domoticz/pull/5815
step 1:
Setup an App under MyApps in the Netatmo developers portal
The Redirect_URI has to contain
Once configured correctly, the Client_ID and Client_Secret will be generated and shown.
step 2:
In the domoticz hardware setup:
This URL brings you to the My Netatmo page where you have to identify yourself and are asked for permission to grant access to certain devices and types (based on the scope provided).
After confirmation, your browser will try to redirect you to a page it cannot find so you will get an error. But the URL of that page is visible in the browser and looks like
You need to pass this SOMECODE as the password in the domoticz hardware screen.
NOTE:
At the moment, the scopes are fixed to read_station read_thermostat write_thermostat read_homecoach read_smokedetector read_presence read_camera
The <SOMECODE> you retrieved is only valid for a few minutes, so if you take too long and domoticz says (check the logs) it cannot login, retrieve a new code and be a little quicker
Wiki https://www.domoticz.com/wiki/Netatmo will be updated later (needs way more information I suppose....)
step 1:
http://localhost/netatmostep 2:
- Create/modify the Netatmo hardware
- the username should contain <client_id>:<client_secret>
- while the password should contain the retrieved <code>
https://api.netatmo.com/oauth2/authorize?client_id=<YOURCLIENTID>&redirect_uri=http%3A%2F%2Flocalhost%2Fnetatmo&state=teststate&scope=read_station%20read_thermostat%20write_thermostat%20read_homecoach%20read_smokedetector%20read_presence%20read_cameraAfter confirmation, your browser will try to redirect you to a page it cannot find so you will get an error. But the URL of that page is visible in the browser and looks like
http://localhost/netatmo?state=teststate&code=<SOMECODE>NOTE:
jcb2
Now it is ready for me.
Many thanks for dev dreamteam !
- kiddigital
You mean it works for you? That is great!jcb2 wrote:Hello,
What type of Netatmo devices do you have connected?
ccaru
Hi! I've downloaded the beta and followed the instructions and everything so far is working great!
Thank you so much!
Claude
Thank you so much!
Claude
Wiki https://www.domoticz.com/wiki/Netatmo is now updated with new instructions.
fjuppe
- Domoticz version: 16341
Followed the instructions exactly, upgraded to Beta and I got 6 devices in total from my weather station!
And they even update every 5 minutes!
Thank you!
Thank you!
homeJLB
- Domoticz version: 2024.7
I have made a new installation with docker and follow the instructions.
Now I see my 2 thermostat and the weather station, and they are updated.
But my homecoach and camera's with doorsensors and valve-thermostats and smoke-sensors are not shown?
I'm on Build 2023.2 15535
These are the only devices that show up in Domoticz I'm I doing something wrong? or do I miss something ?
when I log in to the Netatmo website I do have access to all the devices.
I am not sure all Netatmo devices are supported. The integration is not well documented.
homeJLB
but the Netatmo.h uses the scope NETYPE_WEATHER_STATION = 0, NETYPE_HOMECOACH, NETYPE_ENERGY
so I suspect that the homecoach, weather station and thermostat with valves will work.
But for some reason on my setup the homecoach and the valves are not working.
southmind
- Domoticz version: 2023.2 -
I did the same, but still got "No access granted, check username/password..." with NetAtmo pluginfjuppe wrote: Thursday 14 September 2023 19:38 Hi,
Thank you!
My domoticz version is 2023.2. Do u mean I have to use the beta version ?
Version: 2023.2
southmind
Ok I reply to myself. It works with the beta version. Netatmo devices are added to domoticz. (I own only a complete weather station).southmind wrote: Monday 06 November 2023 18:06I did the same, but still got "No access granted, check username/password..." with NetAtmo pluginfjuppe wrote: Thursday 14 September 2023 19:38 Hi,
Thank you!
It seems ok. Just i got sometime the msg "No access granted, check username/password..." but NetAtmo devices are refreshed.
Version: 2023.2
