Investigation of table MultMeter_Calender of Domoticz database show:
Value1 = used Wh (low tarif)
Value2 = delivered Wh (low tarif)
Value5 = used Wh (high tarif)
Value6 = delivered Wh (high tarif)
Countervalues 1-4 corresponds to countervalues of P1 meter (values may differ due to offset. That's what I presume ).
In other words. Once you start using Domoticz the P1-device countersettings (C1-C4) are not synchronized with P1-meter.
Question:
What is Value3 and Value4 representing?
TIA
-Bart
[solved] Q about MultiMeter_Calender table in domoticz.db
BartSr
- Domoticz version: V2024.7
- MultiMeter_Calendar.jpg (51.48 KiB) Viewed 945 times
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Chinese sensors temp (Dallas),movement
Tasmota
Esp8266 / 32 espeasy
Zigbee2MQTT
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
willemd
- Domoticz version: 2026.3
Re: Q about MultiMeter_Calender table in domoticz.db
Value3 and value4 in the multimeter_calendar table are the maximum values of the day as selected from the multimeter table.
Here is the daily closing routine
https://github.com/domoticz/domoticz/bl ... .cpp#L7392
BartSr
Willemd, thanks a lot for pointing me to the source!
-Bart
-Bart
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
