The installation went smootly and i cane see the 2 widgets in Domoticz (widget startup icon is grey) and i have access to the administration interface via port 9940.
But I get a persistant error and i dont succeed in adding a new device. (its not found).
The persistant error in the log is:
2023-11-02 20:59:33.073 Error: RPiZigbeeCoordinator: [ 70] I have hard time to get Coordinator Version. Mostlikly there is a communication issueIn the wiki page it said that with Debian 12 Bookworm, you have to add "--break-system-packages" to the "sudo pip3 install -r requirements.txt" command line.
I have Debian 12 Bookworm on my pi so i tried:
sudo pip3 install -r requirements.txt --break-system-packagesCode: Select all
sudo pip3 install -r requirements.txtOr should i use Texas intrumens as the Sonof has a Texas Instruments chipset according to the Wiki? (the note that the Texas instruments is for ZigPy made me pick the Zigate+).
Below a more extensive log from Domoticz with more errors:
2023-11-02 20:59:43.111 Error: RPiZigbeeCoordinator: [ 80] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2023-11-02 20:59:53.088 Error: RPiZigbeeCoordinator: [ 90] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2023-11-02 21:00:03.098 Error: RPiZigbeeCoordinator: [100] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2023-11-02 21:00:13.075 Error: RPiZigbeeCoordinator: [110] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2023-11-02 21:00:17.178 Raspberry Pi sensors: General/Percentage (RPi_CPU_Usage)
2023-11-02 21:00:17.185 Raspberry Pi sensors: General/Custom Sensor (Arm Clock Speed)
2023-11-02 21:00:17.195 Raspberry Pi sensors: General/Custom Sensor (V3D Clock Speed)
2023-11-02 21:00:17.204 Raspberry Pi sensors: General/Custom Sensor (Core Clock Speed)
2023-11-02 21:00:23.104 Error: RPiZigbeeCoordinator: [120] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2023-11-02 21:00:24.111 RPiZigbeeCoordinator: URL INFOS {'type': 'command', 'param': 'updatehardware', 'htype': '94', 'idx': 18, 'name': 'RPiZigbeeCoordinator', 'address': '0.0.0.0', 'port': '9999', 'serialport': '/dev/ttyUSB-Zigbee3PlusV2', 'Mode1': 'V2', 'Mode2': 'USB', 'Mode3': 'False', 'Mode4': '9440', 'Mode5': 'http://127.0.0.1:8080', 'Mode6': '0', 'extra': 'Zigate', 'enabled': 'true', 'datatimeout': '0', 'loglevel': 7}
2023-11-02 21:00:24.177 RPiZigbeeCoordinator: onStop()
2023-11-02 21:00:24.183 RPiZigbeeCoordinator: Connection closed
2023-11-02 21:00:24.119 Status: RPiZigbeeCoordinator: Plugin Restart command : http://127.0.0.1:8080/json.htm?type=command¶m=updatehardware&htype=94&idx=18&name=RPiZigbeeCoordinator&address=0.0.0.0&port=9999&serialport=%2Fdev%2FttyUSB-Zigbee3PlusV2&Mode1=V2&Mode2=USB&Mode3=False&Mode4=9440&Mode5=http%3A%2F%2F127.0.0.1%3A8080&Mode6=0&extra=Zigate&enabled=true&datatimeout=0&loglevel=7
2023-11-02 21:00:24.174 Status: RPiZigbeeCoordinator: Stop directive received.
2023-11-02 21:00:24.219 Status: RPiZigbeeCoordinator: ZigateTransport: ZiGateSerialListen Thread stop.
2023-11-02 21:00:24.220 Status: RPiZigbeeCoordinator: ZigateTransport: thread_processing_and_sending Thread stop.
2023-11-02 21:00:25.541 RPiZigbeeCoordinator: logging_thread - ended
2023-11-02 21:00:25.550 RPiZigbeeCoordinator: Logging Thread shutdown
2023-11-02 21:00:25.550 RPiZigbeeCoordinator: onStop called (6) Close Logging Management
2023-11-02 21:00:25.878 RPiZigbeeCoordinator: Worker thread started.
2023-11-02 21:00:25.541 Status: RPiZigbeeCoordinator: ZigateTransport: writer_thread Thread stop.
2023-11-02 21:00:25.822 Status: RPiZigbeeCoordinator: Exiting work loop.
2023-11-02 21:00:25.877 Status: RPiZigbeeCoordinator: Stopping threads.
2023-11-02 21:00:25.877 Status: RPiZigbeeCoordinator: Stopped.
2023-11-02 21:00:25.878 Status: RPiZigbeeCoordinator: Started.
2023-11-02 21:00:25.878 Status: RPiZigbeeCoordinator: Entering work loop.
2023-11-02 21:00:29.331 Status: RPiZigbeeCoordinator: Initialized version 7.1, author 'pipiche38'
2023-11-02 21:00:29.336 Status: RPiZigbeeCoordinator: Zigbee for Domoticz plugin starting
2023-11-02 21:00:29.336 Status: RPiZigbeeCoordinator: Z4D plugin requires python3 3.8 or above and you are running 3.9
2023-11-02 21:00:29.337 Status: RPiZigbeeCoordinator: Checking Python modules /home/pi/domoticz/plugins/Domoticz-Zigbee/requirements.txt
2023-11-02 21:00:31.241 RPiZigbeeCoordinator: load PluginConf
2023-11-02 21:00:31.244 RPiZigbeeCoordinator: Loading PluginConf - from Domoticz sqlite Db
2023-11-02 21:00:31.245 RPiZigbeeCoordinator: /home/pi/domoticz/plugins/Domoticz-Zigbee/Conf/PluginConf-18.json timestamp is 1698950307.6635633
2023-11-02 21:00:31.245 RPiZigbeeCoordinator: Dz PluginConf is older than Json Dz: 0 Json: 1698950307.6635633
2023-11-02 21:00:31.249 RPiZigbeeCoordinator: Installing plugin custom page /home/pi/domoticz/www/templates/RPiZigbeeCoordinator.html
2023-11-02 21:00:31.250 RPiZigbeeCoordinator: Starting LoggingManagement thread
2023-11-02 21:00:31.250 RPiZigbeeCoordinator: zigpy_login_mode(30)
2023-11-02 21:00:31.256 RPiZigbeeCoordinator: start_logging_thread
2023-11-02 21:00:31.257 RPiZigbeeCoordinator: logging_thread - listening
2023-11-02 21:00:31.248 Status: RPiZigbeeCoordinator: filename set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Conf/PluginConf-18.json
2023-11-02 21:00:31.248 Status: RPiZigbeeCoordinator: pluginHome set to /home/pi/domoticz/plugins/Domoticz-Zigbee
2023-11-02 21:00:31.248 Status: RPiZigbeeCoordinator: homedirectory set to /home/pi/domoticz/plugins/Domoticz-Zigbee
2023-11-02 21:00:31.248 Status: RPiZigbeeCoordinator: pluginData set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Data
2023-11-02 21:00:31.248 Status: RPiZigbeeCoordinator: pluginConfig set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Conf
2023-11-02 21:00:31.248 Status: RPiZigbeeCoordinator: pluginOTAFirmware set to /home/pi/domoticz/plugins/Domoticz-Zigbee/OTAFirmware
2023-11-02 21:00:31.248 Status: RPiZigbeeCoordinator: pluginReports set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Reports
2023-11-02 21:00:31.248 Status: RPiZigbeeCoordinator: pluginWWW set to /home/pi/domoticz/plugins/Domoticz-Zigbee/www
2023-11-02 21:00:31.248 Status: RPiZigbeeCoordinator: pluginLogs set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Logs
2023-11-02 21:00:31.249 Status: RPiZigbeeCoordinator: expJsonDatabase set to 0
2023-11-02 21:00:31.257 Status: RPiZigbeeCoordinator: Please watch plugin log into /home/pi/domoticz/plugins/Domoticz-Zigbee/Logs/PluginZigbee_18.log
2023-11-02 21:00:31.273 Status: RPiZigbeeCoordinator: Zigbee for Domoticz (z4d) plugin stable7-7.1.004 started
2023-11-02 21:00:31.330 Status: RPiZigbeeCoordinator: Loading ZCL Cluster definitions
2023-11-02 21:00:31.335 Status: RPiZigbeeCoordinator: - ZCL Cluster 0000 - (V1) Basic loaded
2023-11-02 21:00:31.337 Status: RPiZigbeeCoordinator: - ZCL Cluster 0001 - (V1) Power loaded
2023-11-02 21:00:31.339 Status: RPiZigbeeCoordinator: - ZCL Cluster 0002 - (V1) Device Temperature Configuration loaded
2023-11-02 21:00:31.341 Status: RPiZigbeeCoordinator: - ZCL Cluster 0003 - (V1) Identify loaded
2023-11-02 21:00:31.343 Status: RPiZigbeeCoordinator: - ZCL Cluster 0004 - (V1) Groups loaded
2023-11-02 21:00:31.345 Status: RPiZigbeeCoordinator: - ZCL Cluster 0005 - (V1) Scenes loaded
2023-11-02 21:00:31.347 Status: RPiZigbeeCoordinator: - ZCL Cluster 0006 - (V1) On/Off loaded
2023-11-02 21:00:31.349 Status: RPiZigbeeCoordinator: - ZCL Cluster 0007 - (V1) On/Off Switch Configuration loaded
2023-11-02 21:00:31.351 Status: RPiZigbeeCoordinator: - ZCL Cluster 0008 - (V1) Level loaded
2023-11-02 21:00:31.353 Status: RPiZigbeeCoordinator: - ZCL Cluster 0009 - (V1) Alarms loaded
2023-11-02 21:00:31.355 Status: RPiZigbeeCoordinator: - ZCL Cluster 000a - (V1) Time loaded
2023-11-02 21:00:31.357 Status: RPiZigbeeCoordinator: - ZCL Cluster 000d - (V1) Analog Output loaded
2023-11-02 21:00:31.359 Status: RPiZigbeeCoordinator: - ZCL Cluster 000f - (V1) Binary Input loaded
2023-11-02 21:00:31.361 Status: RPiZigbeeCoordinator: - ZCL Cluster 0013 - (V1) Multistate Output loaded
2023-11-02 21:00:31.363 Status: RPiZigbeeCoordinator: - ZCL Cluster 0019 - (V1) OTA Upgrade loaded
2023-11-02 21:00:31.365 Status: RPiZigbeeCoordinator: - ZCL Cluster 0020 - (V1) Poll Control loaded
2023-11-02 21:00:31.367 Status: RPiZigbeeCoordinator: - ZCL Cluster 0102 - (V1) Window Covering loaded
2023-11-02 21:00:31.369 Status: RPiZigbeeCoordinator: - ZCL Cluster 0202 - (V1) Fan Control loaded
2023-11-02 21:00:31.371 Status: RPiZigbeeCoordinator: - ZCL Cluster 0204 - (V1) Thermostat User Interface Configuration loaded
2023-11-02 21:00:31.375 Status: RPiZigbeeCoordinator: - ZCL Cluster 0300 - (V1) Color Control loaded
2023-11-02 21:00:31.377 Status: RPiZigbeeCoordinator: - ZCL Cluster 0301 - (V1) Ballast Configuration loaded
2023-11-02 21:00:31.379 Status: RPiZigbeeCoordinator: - ZCL Cluster 0400 - (V1) Illuminance Level Sensing loaded
2023-11-02 21:00:31.382 Status: RPiZigbeeCoordinator: - ZCL Cluster 0402 - (V1) Temperature Measurement loaded
2023-11-02 21:00:31.384 Status: RPiZigbeeCoordinator: - ZCL Cluster 0403 - (V1) Pressure Measurement loaded
2023-11-02 21:00:31.386 Status: RPiZigbeeCoordinator: - ZCL Cluster 0405 - (V1) Relative Humidity Measurement loaded
2023-11-02 21:00:31.388 Status: RPiZigbeeCoordinator: - ZCL Cluster 0406 - (V1) Occupancy Sensing loaded
2023-11-02 21:00:31.395 Status: RPiZigbeeCoordinator: - ZCL Cluster 0700 - (V1) Price loaded
2023-11-02 21:00:31.399 Status: RPiZigbeeCoordinator: - ZCL Cluster 0702 - (V1) Metering (Smart Energy) loaded
2023-11-02 21:00:31.401 Status: RPiZigbeeCoordinator: - ZCL Cluster 0b01 - (V1) Meter Identification loaded
2023-11-02 21:00:31.405 Status: RPiZigbeeCoordinator: - ZCL Cluster 0b04 - (V1) Electrical Measurement loaded
2023-11-02 21:00:31.408 Status: RPiZigbeeCoordinator: - ZCL Cluster 0b05 - (V1) Diagnostics loaded
2023-11-02 21:00:31.409 Status: RPiZigbeeCoordinator: - ZCL Cluster e000 - (V1) Tuya E000 Private Cluster loaded
2023-11-02 21:00:31.411 Status: RPiZigbeeCoordinator: - ZCL Cluster e001 - (V1) Tuya E001 Private Cluster loaded
2023-11-02 21:00:31.413 Status: RPiZigbeeCoordinator: - ZCL Cluster e002 - (V1) Tuya E002 Private Cluster loaded
2023-11-02 21:00:31.415 Status: RPiZigbeeCoordinator: - ZCL Cluster fcc0 - (V1) LUMI Private Cluster loaded
2023-11-02 21:00:31.418 Status: RPiZigbeeCoordinator: - ZCL Cluster ff66 - (V1) Lixee Zlinky private cluster loaded
2023-11-02 21:00:31.427 Status: RPiZigbeeCoordinator: DeviceConf loaded - 16 confs loaded
2023-11-02 21:00:31.438 Status: RPiZigbeeCoordinator: Local-Device conf loaded - 21 confs loaded
2023-11-02 21:00:32.216 Status: RPiZigbeeCoordinator: Certified Devices loaded - 513 confs loaded
2023-11-02 21:00:32.217 Status: RPiZigbeeCoordinator: load ListOfDevice
2023-11-02 21:00:32.223 Status: RPiZigbeeCoordinator: 0 Entries loaded from /home/pi/domoticz/plugins/Domoticz-Zigbee/Data/DeviceList-18.txt
2023-11-02 21:00:32.225 Status: RPiZigbeeCoordinator: Transport mode: V2-USB
2023-11-02 21:00:33.203 Status: RPiZigbeeCoordinator: Plugin looks to upgrade the Certified Device package
2023-11-02 21:00:44.074 Thermostaat: Thermostat (Setpoint)
2023-11-02 21:00:44.087 Thermostaat: Temp (Room Temperature)
2023-11-02 21:00:44.285 Thermostaat: Temp (Flow Temperature)
2023-11-02 21:00:44.782 Buienradar: General/Custom Sensor (Next Rainshower Leadtime)
2023-11-02 21:00:47.234 Raspberry Pi sensors: Temp (RPi_Internal_Temperature)
2023-11-02 21:00:47.249 Raspberry Pi sensors: General/Percentage (RPi_CPU_Usage)
2023-11-02 21:00:47.255 Raspberry Pi sensors: General/Custom Sensor (Arm Clock Speed)
2023-11-02 21:00:47.264 Raspberry Pi sensors: General/Custom Sensor (V3D Clock Speed)
2023-11-02 21:00:47.272 Raspberry Pi sensors: General/Custom Sensor (Core Clock Speed)
2023-11-02 21:00:48.498 Status: RPiZigbeeCoordinator: Domoticz Widgets usage is at 1.2 % (252 units free)
2023-11-02 21:01:57.072 Error: RPiZigbeeCoordinator: [ 70] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2023-11-02 21:02:07.104 Error: RPiZigbeeCoordinator: [ 80] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2023-11-02 21:02:17.088 Error: RPiZigbeeCoordinator: [ 90] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2023-11-02 21:02:27.115 Error: RPiZigbeeCoordinator: [100] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2023-11-02 21:02:37.099 Error: RPiZigbeeCoordinator: [110] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2023-11-02 21:02:47.072 Error: RPiZigbeeCoordinator: [120] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2023-11-02 21:02:48.078 RPiZigbeeCoordinator: URL INFOS {'type': 'command', 'param': 'updatehardware', 'htype': '94', 'idx': 18, 'name': 'RPiZigbeeCoordinator', 'address': '0.0.0.0', 'port': '9999', 'serialport': '/dev/ttyUSB-Zigbee3PlusV2', 'Mode1': 'V2', 'Mode2': 'USB', 'Mode3': 'False', 'Mode4': '9440', 'Mode5': 'http://127.0.0.1:8080', 'Mode6': '0', 'extra': 'Zigate', 'enabled': 'true', 'datatimeout': '0', 'loglevel': 7}
2023-11-02 21:02:48.151 RPiZigbeeCoordinator: onStop()
2023-11-02 21:02:48.159 RPiZigbeeCoordinator: Connection closed
2023-11-02 21:02:48.080 Status: RPiZigbeeCoordinator: Plugin Restart command : http://127.0.0.1:8080/json.htm?type=command¶m=updatehardware&htype=94&idx=18&name=RPiZigbeeCoordinator&address=0.0.0.0&port=9999&serialport=%2Fdev%2FttyUSB-Zigbee3PlusV2&Mode1=V2&Mode2=USB&Mode3=False&Mode4=9440&Mode5=http%3A%2F%2F127.0.0.1%3A8080&Mode6=0&extra=Zigate&enabled=true&datatimeout=0&loglevel=7
2023-11-02 21:02:48.128 Status: RPiZigbeeCoordinator: Stop directive received.
2023-11-02 21:02:48.174 Status: RPiZigbeeCoordinator: ZigateTransport: ZiGateSerialListen Thread stop.
2023-11-02 21:02:48.174 Status: RPiZigbeeCoordinator: ZigateTransport: thread_processing_and_sending Thread stop.
2023-11-02 21:02:49.524 RPiZigbeeCoordinator: logging_thread - ended
2023-11-02 21:02:49.532 RPiZigbeeCoordinator: Logging Thread shutdown
2023-11-02 21:02:49.532 RPiZigbeeCoordinator: onStop called (6) Close Logging Management
2023-11-02 21:02:49.948 RPiZigbeeCoordinator: Worker thread started.
2023-11-02 21:02:49.516 Status: RPiZigbeeCoordinator: ZigateTransport: writer_thread Thread stop.
2023-11-02 21:02:49.857 Status: RPiZigbeeCoordinator: Exiting work loop.
2023-11-02 21:02:49.948 Status: RPiZigbeeCoordinator: Stopping threads.
2023-11-02 21:02:49.948 Status: RPiZigbeeCoordinator: Stopped.
2023-11-02 21:02:49.948 Status: RPiZigbeeCoordinator: Entering work loop.
2023-11-02 21:02:49.948 Status: RPiZigbeeCoordinator: Started.
2023-11-02 21:02:53.368 Status: RPiZigbeeCoordinator: Initialized version 7.1, author 'pipiche38'
2023-11-02 21:02:53.376 Status: RPiZigbeeCoordinator: Zigbee for Domoticz plugin starting
2023-11-02 21:02:53.376 Status: RPiZigbeeCoordinator: Z4D plugin requires python3 3.8 or above and you are running 3.9
2023-11-02 21:02:53.377 Status: RPiZigbeeCoordinator: Checking Python modules /home/pi/domoticz/plugins/Domoticz-Zigbee/requirements.txt
2023-11-02 21:02:55.280 RPiZigbeeCoordinator: load PluginConf
2023-11-02 21:02:55.283 RPiZigbeeCoordinator: Loading PluginConf - from Domoticz sqlite Db
2023-11-02 21:02:55.284 RPiZigbeeCoordinator: /home/pi/domoticz/plugins/Domoticz-Zigbee/Conf/PluginConf-18.json timestamp is 1698950307.6635633
2023-11-02 21:02:55.284 RPiZigbeeCoordinator: Dz PluginConf is older than Json Dz: 0 Json: 1698950307.6635633
2023-11-02 21:02:55.288 RPiZigbeeCoordinator: Installing plugin custom page /home/pi/domoticz/www/templates/RPiZigbeeCoordinator.html
2023-11-02 21:02:55.289 RPiZigbeeCoordinator: Starting LoggingManagement thread
2023-11-02 21:02:55.289 RPiZigbeeCoordinator: zigpy_login_mode(30)
2023-11-02 21:02:55.294 RPiZigbeeCoordinator: start_logging_thread
2023-11-02 21:02:55.295 RPiZigbeeCoordinator: logging_thread - listening
2023-11-02 21:02:55.287 Status: RPiZigbeeCoordinator: filename set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Conf/PluginConf-18.json
2023-11-02 21:02:55.287 Status: RPiZigbeeCoordinator: pluginHome set to /home/pi/domoticz/plugins/Domoticz-Zigbee
2023-11-02 21:02:55.287 Status: RPiZigbeeCoordinator: homedirectory set to /home/pi/domoticz/plugins/Domoticz-Zigbee
2023-11-02 21:02:55.287 Status: RPiZigbeeCoordinator: pluginData set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Data
2023-11-02 21:02:55.287 Status: RPiZigbeeCoordinator: pluginConfig set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Conf
2023-11-02 21:02:55.287 Status: RPiZigbeeCoordinator: pluginOTAFirmware set to /home/pi/domoticz/plugins/Domoticz-Zigbee/OTAFirmware
2023-11-02 21:02:55.287 Status: RPiZigbeeCoordinator: pluginReports set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Reports
2023-11-02 21:02:55.287 Status: RPiZigbeeCoordinator: pluginWWW set to /home/pi/domoticz/plugins/Domoticz-Zigbee/www
2023-11-02 21:02:55.287 Status: RPiZigbeeCoordinator: pluginLogs set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Logs
2023-11-02 21:02:55.288 Status: RPiZigbeeCoordinator: expJsonDatabase set to 0
2023-11-02 21:02:55.296 Status: RPiZigbeeCoordinator: Please watch plugin log into /home/pi/domoticz/plugins/Domoticz-Zigbee/Logs/PluginZigbee_18.log
2023-11-02 21:02:55.311 Status: RPiZigbeeCoordinator: Zigbee for Domoticz (z4d) plugin stable7-7.1.004 started
2023-11-02 21:02:55.354 Status: RPiZigbeeCoordinator: Loading ZCL Cluster definitions
2023-11-02 21:02:55.358 Status: RPiZigbeeCoordinator: - ZCL Cluster 0000 - (V1) Basic loaded
2023-11-02 21:02:55.361 Status: RPiZigbeeCoordinator: - ZCL Cluster 0001 - (V1) Power loaded
2023-11-02 21:02:55.363 Status: RPiZigbeeCoordinator: - ZCL Cluster 0002 - (V1) Device Temperature Configuration loaded
2023-11-02 21:02:55.376 Status: RPiZigbeeCoordinator: - ZCL Cluster 0003 - (V1) Identify loaded
2023-11-02 21:02:55.379 Status: RPiZigbeeCoordinator: - ZCL Cluster 0004 - (V1) Groups loaded
2023-11-02 21:02:55.381 Status: RPiZigbeeCoordinator: - ZCL Cluster 0005 - (V1) Scenes loaded
2023-11-02 21:02:55.383 Status: RPiZigbeeCoordinator: - ZCL Cluster 0006 - (V1) On/Off loaded
2023-11-02 21:02:55.385 Status: RPiZigbeeCoordinator: - ZCL Cluster 0007 - (V1) On/Off Switch Configuration loaded
2023-11-02 21:02:55.387 Status: RPiZigbeeCoordinator: - ZCL Cluster 0008 - (V1) Level loaded
2023-11-02 21:02:55.389 Status: RPiZigbeeCoordinator: - ZCL Cluster 0009 - (V1) Alarms loaded
2023-11-02 21:02:55.391 Status: RPiZigbeeCoordinator: - ZCL Cluster 000a - (V1) Time loaded
2023-11-02 21:02:55.393 Status: RPiZigbeeCoordinator: - ZCL Cluster 000d - (V1) Analog Output loaded
2023-11-02 21:02:55.395 Status: RPiZigbeeCoordinator: - ZCL Cluster 000f - (V1) Binary Input loaded
2023-11-02 21:02:55.397 Status: RPiZigbeeCoordinator: - ZCL Cluster 0013 - (V1) Multistate Output loaded
2023-11-02 21:02:55.399 Status: RPiZigbeeCoordinator: - ZCL Cluster 0019 - (V1) OTA Upgrade loaded
2023-11-02 21:02:55.401 Status: RPiZigbeeCoordinator: - ZCL Cluster 0020 - (V1) Poll Control loaded
2023-11-02 21:02:55.403 Status: RPiZigbeeCoordinator: - ZCL Cluster 0102 - (V1) Window Covering loaded
2023-11-02 21:02:55.405 Status: RPiZigbeeCoordinator: - ZCL Cluster 0202 - (V1) Fan Control loaded
2023-11-02 21:02:55.407 Status: RPiZigbeeCoordinator: - ZCL Cluster 0204 - (V1) Thermostat User Interface Configuration loaded
2023-11-02 21:02:55.410 Status: RPiZigbeeCoordinator: - ZCL Cluster 0300 - (V1) Color Control loaded
2023-11-02 21:02:55.412 Status: RPiZigbeeCoordinator: - ZCL Cluster 0301 - (V1) Ballast Configuration loaded
2023-11-02 21:02:55.414 Status: RPiZigbeeCoordinator: - ZCL Cluster 0400 - (V1) Illuminance Level Sensing loaded
2023-11-02 21:02:55.416 Status: RPiZigbeeCoordinator: - ZCL Cluster 0402 - (V1) Temperature Measurement loaded
2023-11-02 21:02:55.418 Status: RPiZigbeeCoordinator: - ZCL Cluster 0403 - (V1) Pressure Measurement loaded
2023-11-02 21:02:55.420 Status: RPiZigbeeCoordinator: - ZCL Cluster 0405 - (V1) Relative Humidity Measurement loaded
2023-11-02 21:02:55.422 Status: RPiZigbeeCoordinator: - ZCL Cluster 0406 - (V1) Occupancy Sensing loaded
2023-11-02 21:02:55.429 Status: RPiZigbeeCoordinator: - ZCL Cluster 0700 - (V1) Price loaded
2023-11-02 21:02:55.433 Status: RPiZigbeeCoordinator: - ZCL Cluster 0702 - (V1) Metering (Smart Energy) loaded
2023-11-02 21:02:55.435 Status: RPiZigbeeCoordinator: - ZCL Cluster 0b01 - (V1) Meter Identification loaded
2023-11-02 21:02:55.438 Status: RPiZigbeeCoordinator: - ZCL Cluster 0b04 - (V1) Electrical Measurement loaded
2023-11-02 21:02:55.441 Status: RPiZigbeeCoordinator: - ZCL Cluster 0b05 - (V1) Diagnostics loaded
2023-11-02 21:02:55.443 Status: RPiZigbeeCoordinator: - ZCL Cluster e000 - (V1) Tuya E000 Private Cluster loaded
2023-11-02 21:02:55.444 Status: RPiZigbeeCoordinator: - ZCL Cluster e001 - (V1) Tuya E001 Private Cluster loaded
2023-11-02 21:02:55.446 Status: RPiZigbeeCoordinator: - ZCL Cluster e002 - (V1) Tuya E002 Private Cluster loaded
2023-11-02 21:02:55.448 Status: RPiZigbeeCoordinator: - ZCL Cluster fcc0 - (V1) LUMI Private Cluster loaded
2023-11-02 21:02:55.453 Status: RPiZigbeeCoordinator: - ZCL Cluster ff66 - (V1) Lixee Zlinky private cluster loaded
2023-11-02 21:02:55.461 Status: RPiZigbeeCoordinator: DeviceConf loaded - 16 confs loaded
2023-11-02 21:02:55.471 Status: RPiZigbeeCoordinator: Local-Device conf loaded - 21 confs loaded
2023-11-02 21:02:56.248 Status: RPiZigbeeCoordinator: Certified Devices loaded - 513 confs loaded
2023-11-02 21:02:56.256 Status: RPiZigbeeCoordinator: load ListOfDevice
2023-11-02 21:02:56.257 Status: RPiZigbeeCoordinator: 0 Entries loaded from /home/pi/domoticz/plugins/Domoticz-Zigbee/Data/DeviceList-18.txt
2023-11-02 21:02:56.259 Status: RPiZigbeeCoordinator: Transport mode: V2-USB
2023-11-02 21:02:56.836 Status: RPiZigbeeCoordinator: ZigateTransport: Serial Connection open: Serial<id=0x69474e80, open=True>(port='/dev/ttyUSB-Zigbee3PlusV2', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=None, xonxoff=False, rtscts=False, dsrdtr=False)
2023-11-02 21:02:56.840 Status: RPiZigbeeCoordinator: ZigateTransport: writer_thread Thread start.
2023-11-02 21:02:56.841 Status: RPiZigbeeCoordinator: ZigateTransport: thread_processing_and_sending Thread start.
2023-11-02 21:02:56.859 Status: RPiZigbeeCoordinator: Start Web Server connection
2023-11-02 21:02:56.891 Status: RPiZigbeeCoordinator: Web backend for Web User Interface started on port: 9440
2023-11-02 21:02:57.242 Status: RPiZigbeeCoordinator: Plugin looks to upgrade the Certified Device package
2023-11-02 21:03:07.449 Raspberry Pi sensors: Temp (RPi_Internal_Temperature)
2023-11-02 21:03:12.379 Status: RPiZigbeeCoordinator: Domoticz Widgets usage is at 1.2 % (252 units free)
