Please use template to report bugs and problems. Post here your questions when not sure where else to post Only for bugs in the Domoticz application! other problems go in different subforums!
Forum rules
rpi : Raspberry Pi 2 Model B Rev 1.1 / Modele : Cortex-A7 armv7l GNU/Linux / Os Name : bullseye
Docker/Domoticz/zwave-ui/homebridge/mosquitto/wireguard
If any one can see how to modify these to follow the new requirements, i would be grateful of any help.
var jurl=$.domoticzurl+"/json.htm?type=devices
thanks
Newpond
That one has to change ‘type=command¶m=getdevices’
You can remove the ‘&jsoncallback=?’ as that is also not supported anymore.
The others should be ok
EDITED
I hope someone can help me please. I'm having trouble getting my frontpage working again after Domoticz update. I was getting two Rtype errors, one for devices and one for scenes. I have changed /json.htm?type=devices to /json.htm?type=command¶m=getdevices and that seems to have fixed the devices issue but having changed /json.htm?type=scenes to /json.htm?type=command¶m=getscenes I'm still getting a scenes R type error: [WebServer] Deprecated RType (scenes) for API request. Handled via fallback (getscenes), please use correct API Command!
markk wrote: Tuesday 31 October 2023 12:07
but having changed /json.htm?type=devices to /json.htm?type=command¶m=getscenes I'm still getting a scenes R type error:
mmm... I guess you mean you changed:/json.htm?type=scenes to /json.htm?type=command¶m=getscenes ?
Oops, yes, sorry. That's exactly what I mean. I now corrected this typo.
Ça peut être lié à un soucis de rapport. Donc il faudrait que tu mettes une ampoule dont tu connais la consommation et ainsi je pourrais en déduire le bon ratio
EDITED
Then there is another proces/application in your environment calling the deprecated API call. Also clear your browser cache, that also helps to get changes implemented in a browser environment.
So the rtype errors have now gone but no devices are showing on frontpage. I can see the incoming connection in the log: 192.168.0.39:8080/frontpage2/index.html. The index.html file is the same one that was working before I updated Domoticz
markk wrote: Tuesday 31 October 2023 18:25
Hit F12 and goto the network tab to see the requests and the results returned.
I don’t know how to post a screenshot but when I hit F12 I can view my index.html file under the sources tab. Network tab shows a list of requests
Yes. All showing (200) but it is reporting an issue:
Because a cookie’s SameSite attribute was not set or is invalid, it defaults to SameSite=Lax, which prevents the cookie from being set in a cross-site context. This behavior protects user data from accidentally leaking to third parties and cross-site request forgery.
Resolve this issue by updating the attributes of the cookie:
Specify SameSite=None and Secure if the cookie is intended to be set in cross-site contexts. Note that only cookies sent over HTTPS may use the Secure attribute.
Specify SameSite=Strict or SameSite=Lax if the cookie should not be set by cross-site requests.
1 cookie
Name Domain & Path
DMZSID 192.168.0.XXX/
The messages about "Depricated RType" don't appear anymore
I have 2 devices running on the old API which I cannot convert to the new API. Unfortunately, I do not have the source code for one, and for the other I am not able to compile the ESP8266 batch using the current libraries. So the Domoticz upgrade lock will probably last quite a long time for me...
One way could be to implement an reverse proxy that will translate the old API call to the new format as I posted here as solution when the Android App crashed when used on old domoticz versions: viewtopic.php?p=308169#p308169
The only thing you need to be able to do is change the used port on those devices you can't change the API format on from eg 8080 to 8082 when using that posted setup.
Thank you for that.
Simpler option is to maintain backward compatibility in domoticz itself and no disabling old format.
I already lost one way to access domoticz via old, not maintained from 2017 year app Imperihome because of changes in domoticz security.
Now another thing in next version will be lost. It shouldn't be like this.
