Zigbee for domoticz error Topic is solved
pipiche
Re: Zigbee for domoticz error
Post by pipiche »
please update to the most recent Z4D version ...
jacobsentertainment
Domoticz version: 2021-1
Post by jacobsentertainment »
I see there is a new update available, ill do this as soon as possible when back onshore. Thanks!!
jacobsentertainment
Seems to be working fine, yesterday I noticed that an sonoff snzb-03 (motion/pir) was mistaken for a humidity/temperature sensor. deleted it and tried again and came back up again as an hum/temp sensor. Ill try again tonight.
I did update to most recent version.
pipiche
Post by pipiche »
jacobsentertainment wrote:Seems to be working fine, yesterday I noticed that an sonoff snzb-03 (motion/pir) was mistaken for a humidity/temperature sensor. deleted it and tried again and came back up again as an hum/temp sensor. Ill try again tonight.
If you can provide pairing logs and export.json that would be great
jacobsentertainment
This is from the domoticz log
2023-10-27 16:55:38.659 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 87e4 Simple Descriptor Response EP: 0x01 LQI: 144
2023-10-27 16:55:38.659 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 87e4 ProfileID 0104
2023-10-27 16:55:38.660 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 87e4 ZDeviceID 0402
2023-10-27 16:55:38.660 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 87e4 Application Version 0000
2023-10-27 16:55:38.660 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 87e4 Cluster IN Count: 04
2023-10-27 16:55:38.660 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 87e4 Cluster In 1: 0000 (Basic)
2023-10-27 16:55:38.661 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 87e4 Cluster In 2: 0003 (Identify)
2023-10-27 16:55:38.661 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 87e4 Cluster In 3: 0500 (IAS Zone)
2023-10-27 16:55:38.661 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 87e4 Cluster In 4: 0001 (Power Configuration)
2023-10-27 16:55:38.661 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 87e4 Cluster OUT Count: 01
2023-10-27 16:55:38.662 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 87e4 Cluster Out 1: 0003 (Identify)
2023-10-27 16:55:40.944 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 87e4 Simple Descriptor Response EP: 0x01 LQI: 144
2023-10-27 16:55:40.945 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 87e4 ProfileID 0104
2023-10-27 16:55:40.945 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 87e4 ZDeviceID 0402
2023-10-27 16:55:40.945 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 87e4 Application Version 0000
2023-10-27 16:55:40.946 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 87e4 Cluster IN Count: 04
2023-10-27 16:55:40.946 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 87e4 Cluster In 1: 0000 (Basic)
2023-10-27 16:55:40.946 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 87e4 Cluster In 2: 0003 (Identify)
2023-10-27 16:55:40.946 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 87e4 Cluster In 3: 0500 (IAS Zone)
2023-10-27 16:55:40.947 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 87e4 Cluster In 4: 0001 (Power Configuration)
2023-10-27 16:55:40.947 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 87e4 Cluster OUT Count: 01
2023-10-27 16:55:40.947 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 87e4 Cluster Out 1: 0003 (Identify)
2023-10-27 16:55:42.085 Status: zigbee: [ MainThread 19363] [1] NEW OBJECT: 87e4 Model Name: 66666
2023-10-27 16:55:42.091 Status: zigbee: [ MainThread 19363] [1] NEW OBJECT: 87e4 Manufacturer Name: eWeLink
2023-10-27 16:55:42.102 Status: zigbee: [ MainThread 19363] [None] NEW OBJECT: 87e4 Request Node Descriptor
2023-10-27 16:55:46.530 Status: zigbee: [ZigpyForwarder_22 19574] (87e4/00124b002247e662) sent a Leave indication and will be outside of the network. LQI: 0
2023-10-27 16:55:46.530 Status: zigbee: [ZigpyForwarder_22 19574] (87e4/00124b002247e662) cleanup key plugin data informations
2023-10-27 16:55:46.540 Status: zigbee: [ZigpyForwarder_22 19574] (87e4/00124b002247e662) sent a Leave indication and will be outside of the network. LQI: 0
2023-10-27 16:55:46.540 Status: zigbee: [ZigpyForwarder_22 19574] (87e4/00124b002247e662) cleanup key plugin data informations
jacobsentertainment
I grabbed an brand new one out of the box, paired it and this does come up as a motion device
Domoticz log
    Allemaal
    Status
    Probleem
	Filter: X
2023-10-27 17:01:41.443 Status: zigbee: [ZigpyForwarder_22 19574] [None] NEW OBJECT: 55a9 None
2023-10-27 17:01:42.908 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 55a9 Active Endpoint Response Ep: 01 LQI: 144
2023-10-27 17:01:42.911 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 55a9 Request Simple Descriptor for Ep: 01
2023-10-27 17:01:45.588 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 55a9 Simple Descriptor Response EP: 0x01 LQI: 144
2023-10-27 17:01:45.589 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 55a9 ProfileID 0104
2023-10-27 17:01:45.589 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 55a9 ZDeviceID 0402
2023-10-27 17:01:45.589 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 55a9 Application Version 0000
2023-10-27 17:01:45.589 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 55a9 Cluster IN Count: 04
2023-10-27 17:01:45.590 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 55a9 Cluster In 1: 0000 (Basic)
2023-10-27 17:01:45.590 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 55a9 Cluster In 2: 0003 (Identify)
2023-10-27 17:01:45.590 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 55a9 Cluster In 3: 0500 (IAS Zone)
2023-10-27 17:01:45.591 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 55a9 Cluster In 4: 0001 (Power Configuration)
2023-10-27 17:01:45.591 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 55a9 Cluster OUT Count: 01
2023-10-27 17:01:45.591 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 55a9 Cluster Out 1: 0003 (Identify)
2023-10-27 17:01:47.073 Status: zigbee: [ MainThread 19363] [None] NEW OBJECT: 55a9 Request Node Descriptor
2023-10-27 17:01:47.992 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 55a9 Simple Descriptor Response EP: 0x01 LQI: 144
2023-10-27 17:01:47.992 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 55a9 ProfileID 0104
2023-10-27 17:01:47.993 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 55a9 ZDeviceID 0402
2023-10-27 17:01:47.993 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 55a9 Application Version 0000
2023-10-27 17:01:47.993 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 55a9 Cluster IN Count: 04
2023-10-27 17:01:47.994 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 55a9 Cluster In 1: 0000 (Basic)
2023-10-27 17:01:47.994 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 55a9 Cluster In 2: 0003 (Identify)
2023-10-27 17:01:47.994 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 55a9 Cluster In 3: 0500 (IAS Zone)
2023-10-27 17:01:47.994 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 55a9 Cluster In 4: 0001 (Power Configuration)
2023-10-27 17:01:47.995 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 55a9 Cluster OUT Count: 01
2023-10-27 17:01:47.995 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 55a9 Cluster Out 1: 0003 (Identify)
2023-10-27 17:01:52.087 Status: zigbee: [ MainThread 19363] [2] NEW OBJECT: 55a9 Model Name: MS01
2023-10-27 17:01:52.088 Status: zigbee: [ MainThread 19363] [2] NEW OBJECT: 55a9 Manufacturer Name: eWeLink
pipiche
Post by pipiche »
jacobsentertainment wrote: Friday 27 October 2023 16:59 This is from the domoticz log
It looks like the Model 66666 can be a Temp/Humi as well as a Motion
I'll see how to fix it
pipiche
Post by pipiche »
I did a hack on the plugin side. Before making it available for all, I did it on a specific branch.
I assumed that you are on plugin 7.1.004 (if not please upgrade first and be aware that is not possible if you are on buster)
then
git pull
git checkout fix-sonoff-firmware-model
sudo python3 -m pip install -r requirements.txt --upgrade
let me know how it works
jacobsentertainment
I'm on 7.1.003 with bullseye. Ill have to get in to it somewhere this weekend. Ill keep you updated.
btw I already replaced it with an new one, those device are inexpensive ;-)
jacobsentertainment
Cheers, now it's back as an motion device. :lol:
While we are at it, still have some issues to sort with zigbee4domoticz.
- not all devices are recognized if they are battery operated. trädfri pir devices, Heiman SMOK_YDLV10, and an TRV TS0601-eTRV1
- Also the smoke detector of heiman is giving out an battery update and status update but the device does time out in domoticz. (red tab in left top)
Any ideas for this?
Also is it possible to see all traffic in the log?
Thanks for the hard work!
pipiche
Post by pipiche »
I would need an export.json plugin raw devices information. so I can understand what is wrong with battery
for logging traffic you can enable the debug parameters
trackZclClustersIn
trackZclClustersOut
trackZdpClustersIn
trackZdpClustersOut
and so all ZCL and ZDP in and out will be dump in the log in a formated way
jacobsentertainment
pipiche wrote: Tuesday 31 October 2023 8:13 I would need an export.json plugin raw devices information. so I can understand what is wrong with battery
How do I get this data :?
pipiche
Post by pipiche »
Screenshot 2023-10-31 at 20.15.08.png (138.67 KiB) Viewed 3175 times
jacobsentertainment
Ikea trädfri pir, hope this will do, if not let me know.
Version: "3"
ZDeviceName: "Pir terras"
Status: "inDB"
SQN: "6d"
Ep:
01:
1000: Object {}
0000: Object {"4000":"2.0.022","0004":"IKEA of Sweden","0005":"TRADFRI motion sensor","0000":3,"0001":32,"0002":98,"0003":1,"0007":3,"000a":"E1745"}
0001: Object {"0021":11}
0003: Object {}
0009: Object {}
0b05: Object {}
0004: Object {}
0006: Object {"0000":"Cmd: 42, 02"}
0019: Object {}
Type: "Motion"
ClusterType: Object {"616":"Motion"}
Heartbeat: "1568"
RIA: "1"
LQI: 100
Battery: 11
Model: "TRADFRI motion sensor"
ForceAckCommands: Array[0] []
MacCapa: "80"
IEEE: "5c0272fffe8a987d"
Type: "Motion"
ProfileID: "0104"
ZDeviceID: "0850"
App Version: 32
Attributes List: Object {}
DeviceType: "RFD"
HW Version: 1
Last Cmds: Array[0] []
LogicalType: "End Device"
Manufacturer: "117c"
Manufacturer Name: "IKEA of Sweden"
NbEp: "1"
PowerSource: "Battery"
ReadAttributes:
Ep:
01:
0001:
TimeStamp: "28/10/2023 00:11:08"
iSQN: Object {"0021":"32"}
Attributes: Object {}
ZigateRequest: Object {}
0006:
iSQN: Object {"4000":"33","4001":"33","4002":"34","4003":"34","0000":"33","fffd":"34","fffe":"35"}
0000:
iSQN: Object {"4000":"38","0000":"36","0001":"36","0002":"36","0003":"37","0004":"37","0005":"37","0007":"38","000a":"38"}
ReceiveOnIdle: ""
Stack Version: 98
Stamp: Object {"time":1698774674.1152956,"Time":"2023-10-31 18:51:14","MsgType":"8011","LastSeen":"31/10/2023 18:51:14"}
ZCL Version: 3
Health: "Live"
CertifiedDevice: true
Max Tx: "0052"
bitfield: "4002"
Epv2: Object {"01":{"ProfileID":"0104","ZDeviceID":"0850","ClusterIn":{"1000":{},"0000":{},"0001":{},"0003":{},"0009":{},"0020":{},"fc7c":{}},"ClusterOut":{"1000":{},"0003":{},"0004":{},"0006":{},"0008":{},"0019":{}}}}
_rawNodeDescriptor: "117c005200522c000080524002"
Max Rx: "0052"
server_mask: "2c00"
BindingTable: Array[4] [{"Devices":[],"SQN":0,"Status":"","TimeStamp":"27/10/2023 19:03:11","Time":"27/10/2023 19:03:11"},{"Devices":[],"SQN":0,"Status":"","TimeStamp":"27/10/2023 19:28:11","Time":"27/10/2023 19:28:11"},{"Devices":[],"SQN":0,"Status":"","TimeStamp":"27/10/2023 19:38:12","Time":"27/10/2023 19:38:12"},{"Devices":[],"SQN":0,"Status":"","TimeStamp":"28/10/2023 00:11:08","Time":"28/10/2023 00:11:08"}]
OTAClient: Object {"ManufacturerCode":"117c","ImageType":"11c8","CurrentImageVersion":"20022623"}
Max Buffer Size: "52"
descriptor_capability: "00"
Param: Object {}
ConfigSource: "DeviceConf"
macapa: "80"
Capability: Array[3] ["Reduced-Function Device","Standard security","NwkAddr should be allocated"]
BatteryUpdateTime: "27/10/2023 18:55:16"
WriteAttributes:
Ep: Object {"01":{"1000":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0000":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0001":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0003":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0009":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0b05":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0004":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0006":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0019":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}}}}
ConsistencyCheck: "ok"
ZCL-IN-SQN:
0019: "6d"
0006: "6b"
RollingLQI: Array[11] [104,104,104,100,100,100,100,100,100,100,100]
ZCLSQN: "08"
MapLQI:
d966: 129
NwkID: "b519"
jacobsentertainment
And the smoke detector
Version: "3"
ZDeviceName: "rookmelder overloop"
Status: "inDB"
SQN: "00"
Ep: Object {"01":{"0000":{"0004":"Heiman","0005":"SMOK_YDLV10","0003":1,"0006":"20150330","0007":3,"0010":"","0011":0,"0012":"01","0013":0},"0001":{"0000":0,"0001":0,"0010":0,"0011":0,"0012":65535,"0013":0,"0020":30,"0021":200,"0030":"","0031":255,"0032":0,"0033":0,"0034":30,"0035":1,"0036":25,"0037":0,"0038":0,"0039":0,"003a":40,"003b":0,"003c":0,"003d":0,"003e":"00000000"},"0003":{},"0009":{},"0019":{},"0500":{"0010":"e0798dfffec7b5a1","0000":"01","0001":"0028","0002":"alarm1: 1, alarm2: 0, tamper: 0, battery: 0, Support Reporting: 0, restore Reporting: 1, trouble: 0, acmain: 0, test: 0, battdef: 0"},"0502":{"0000":"240"},"Type":"Smoke","ClusterType":{"605":"Smoke"}}}
Heartbeat: "33950"
RIA: "3"
LQI: 120
Battery: 200
Model: "SMOK_YDLV10"
MacCapa: "84"
IEEE: "005043c903356c2f"
Type: "Smoke"
ProfileID: "0104"
ZDeviceID: "0402"
App Version: ""
DeviceType: "RFD"
HW Version: 1
Manufacturer: "120b"
Manufacturer Name: "Heiman"
NbEp: "1"
PowerSource: "Main"
ReadAttributes: Object {"Ep":{"01":{"0000":{"TimeStamp":"08/10/2023 20:25:18","iSQN":{"4000":"1f","8000":"1f","0000":"00","0001":"18","0002":"18","0003":"19","0004":"19","0005":"19","0006":"1a","0007":"1a","0008":"1a","0009":"1b","000a":"1b","000b":"1b","000c":"1c","000d":"1c","000e":"1c","0010":"1d","0011":"1d","0012":"1d","0013":"1e","0014":"1e","0015":"1e","fffd":"1f","fffe":"20","ffdf":"20","ffe0":"20","ffe1":"21","ffe2":"21","ffe4":"21"},"Attributes":{"8000":"86","0009":"86","000c":"86","0014":"86","fffe":"86","ffe1":"86"},"ZigateRequest":{}},"0500":{"TimeStamp":"08/10/2023 20:24:37","iSQN":{},"Attributes":{"0010":"00","0000":"00","0001":"00","0002":"00"},"ZigateRequest":{}},"0001":{"TimeStamp":"08/10/2023 20:24:35","iSQN":{"0000":"09","0001":"09","0010":"09","0011":"0a","0012":"0a","0013":"0a","0020":"0b","0021":"0b","0030":"0b","0031":"0c","0032":"0c","0033":"0c","0034":"0d","0035":"0d","0036":"0d","0037":"0e","0038":"0e","0039":"0e","003a":"0f","003b":"0f","003c":"0f","003d":"10","003e":"10","fffd":"10","fffe":"11"},"Attributes":{},"ZigateRequest":{}},"0019":{"TimeStamp":"08/10/2023 20:24:35","iSQN":{"0000":"12","0001":"12","0002":"12","0003":"13","0004":"13","0005":"13","0006":"14","0007":"14","0008":"14","0009":"15","000a":"15","fffd":"15","fffe":"16"},"Attributes":{},"ZigateRequest":{}},"0502":{"TimeStamp":"08/10/2023 20:25:04","iSQN":{"0000":"17"},"Attributes":{"0000":"00"},"ZigateRequest":{}}}}}
ReceiveOnIdle: ""
Stack Version: ""
Stamp: Object {"time":1696789861.5398967,"Time":"2023-10-08 20:31:01","MsgType":"8401","LastSeen":"08/10/2023 20:31:01","LastPing":1698684654}
ZCL Version: ""
Health: "Not Reachable"
ReadConfigureReporting: Object {}
IAS: Object {"Auto-Enrollment":{"Status":"Enrolled","Ep":{"01":{"Status":"Enrolled","ZoneId":"00"}}},"01":{"EnrolledStatus":1,"ZoneType":40,"ZoneTypeName":"fire","ZoneStatus":{"alarm1":0,"alarm2":0,"tamper":0,"battery":0,"Support Reporting":0,"Restore Reporting":1,"trouble":0,"acmain":0,"test":0,"battdef":0,"doorbell":0,"GlobalInfos":"0;0;0;0;0;1;0;0;0;0;0","TimeStamp":"08/10/2023 20:24:29"}}}
Max Tx: "0000"
IASBattery: 100
SWBUILD_1: "20150330"
bitfield: "4002"
Epv2: Object {"01":{"ProfileID":"0104","ZDeviceID":"0402","ClusterIn":{"0000":{},"0003":{},"0500":{},"0001":{},"0009":{},"0502":{}},"ClusterOut":{"0019":{}}}}
_rawNodeDescriptor: "bbaa0000000000000384404002"
Bind: Object {"01":{"0500":{"Target":"0000","Stamp":"08/10/2023 20:24:32","Phase":"binded","Status":"00","i_sqn":"03"}}}
Max Rx: "0000"
ConfigureReporting: Object {"Ep":{"01":{"0500":{"TimeStamp":"08/10/2023 20:24:35","iSQN":{"0000":"06","0001":"06","0002":"06"},"Attributes":{},"ZigateRequest":{}},"0502":{"TimeStamp":"08/10/2023 20:24:35","iSQN":{"0000":"07"},"Attributes":{"0000":"8c"},"ZigateRequest":{}},"0001":{"TimeStamp":"08/10/2023 20:24:35","iSQN":{"0000":"08","0020":"08","0021":"08"},"Attributes":{"0000":"8c","0020":"8c","0021":"8d"},"ZigateRequest":{}}}}}
server_mask: "0000"
BindingTable: Object {"SQN":0,"Status":"Success","TimeStamp":"08/10/2023 20:24:40","BindingTableSize":1,"Devices":[{"005043c903356c2f":{"sourceEp":"01","Cluster":"0500","targetIEEE":"e0798dfffec7b5a1","targetNickName":"Zigbee Coordinator","targetEp":"01"}}]}
Max Buffer Size: "40"
descriptor_capability: "03"
Param: Object {}
macapa: "84"
Capability: Array[4] ["Reduced-Function Device","Main Powered","Standard security","NwkAddr should be allocated"]
BatteryUpdateTime: "08/10/2023 20:24:47"
WriteAttributes: Object {"Ep":{"01":{"0500":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0000":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0001":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0003":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0009":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0019":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0502":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}}}}}
ZCLSQN: "00"
pingDeviceRetry: Object {"Retry":0,"TimeStamp":"30/10/2023 17:50:59"}
NwkID: "e3ff"
