Hello
I'm trying to use Shelly H&T with MQTT. Domoticz gets the device properly but... the Shelly H&T sleeps fot about 10 minutes and wakes up for few seconds to send info, on this time Domoticz creates a new device and I cannot configure it to log temperature of the room... is there any way to lock this to the created device avoiding it to create new one al the times?
Shelly H&T issue
leonardo71
- Domoticz version: 2025.1
Re: Shelly H&T issue
What integration do you use to communicate with Shelly? Shelly Plugin? discovery script? Please check the integration forum topic you are using and ask your question there.
leonardo71
Hi, I'm using MQTT with the Shelly MQTT addon... it works great for other Shelly (2, 2.5, PM and whatever) but yesterday I had to replace the H&T due a issue... as soon as I connect the new one I "replaced" I'm quite sure I did a mistake there... now it works ok, thanks a lot
