error while loading shared libraries: libssl so 1 1
Raspbian 64 bit lite ( Shift key RAspberryPi 4 ; Image loader)
Geekworm powerbutton and Geekworm powerfan scripts installed.
I Build a geekworm, now twice , the first runs smoothly, now thiss second device : I can't access the webside because this error:
./domoticz:
error while loading shared libraries: lib ssl so 1 1: cannot open shared object file: No such file or directory
pi@lightHCC:~/domoticz $
It's telling me that the library lib ssl so1 1 is missing?
Wat went wrong ?
First thought that I had to make a user pi , ( i first did it with user "Peter")
did update domoticz and apt.
./domoticz:
Wat went wrong ?
- FireWizard
Re: error while loading shared libraries: libssl so 1 1
Hi @PeterRozenveld
Search for libssl.so.1.1 on this forum and you will get more than 200 results.
Check these posts first.
Ok, thx, but searching for a solution is not easy!
- gizmocuz
You probably use bookwork? Because many users are using the previous debian release our builds are still using version 1.1
This will change in the near feature to 3.0
If you are using raspbian, install the legacy version or use Domoticz in combination with docker-compose
Yes, I Did installed a Legacy, but how I prevent Domoticz from upgrade !
Stil not running...
Thanks anyway
Stil not running...
Thanks anyway
These commands solved my issues, but I am too beginner to well understand them.
Raspberry Pi 4
Raspberry Pi OS (LEGACY) LITE Bullseye
Install Domoticz
Then you can see the error:
close and edit the file /boot/config (.txt)
Add at the end of file:
Save
Normaly you should see the running status:
Then remove
Save and reboot
You should still see:
Done!
Raspberry Pi 4
sudo apt update && sudo apt upgrade -y && sudo reboot
sudo service domoticz status
start-stop-daemon: unable to start /home/dranreb/domoticz/domoticz (No such file or directory)
arm_64bit=0
sudo reboot
cd domoticz
sudo ./updaterelease
Active: active ([b]running[/b]) since Sat 2023-10-21 20:38:01 CEST; 9s ago
in the config text file.arm_64bit=0
Save and reboot
Active: active ([b]running[/b]) since Sat 2023-10-21 20:40:41 CEST; 6s ago
I have also solutions for
Raspberry Pi 4
With Raspberry Pi OS LITE (32-BIT) Bookworm
Orange Pi 0 Armbian Bookworm
Orange Pi 0 plus (h5) Bookworm
but I am not yet allowed to publish the wget commands (perhaps due to the fact that I am new on this forum)
I get always this message :
You can’t post image, email or url links that are external to this domain.
Perhaps later..
Raspberry Pi 4
Perhaps later..
- Domoticz version: 4.11083
maybe someone else?
quite anoying
quite anoying
THX bob3be its working, that arm64=0 !
I still have the publishing limitations but I will try to explain anyway
(some "." are replaced with ' ')
If you try for :
Raspberry Pi 4
With
All former steps lead to the error:
error while loading shared libraries: lib ssl' 'so' '1' '1: cannot open shared object file: ...
So do the following commands:
In the next 2 lines replace ' ' by a point character.
If you try for :
Raspberry Pi 4
With
wget http://security' 'debian' 'org/debian-security/pool/updates/main/o/openssl/libssl1' '1_1' '1' '1n-0+deb11u5_armhf' 'deb
sudo dpkg -i libssl1' '1_1' '1' '1n-0+deb11u5_armhf' 'deb
sudo reboot
Done !Active: active (running) since Sat 2023-10-21 21:05:01 CEST; 1min 5s ago
For
Orange Pi 0
Armbian_23.8.3_Orangepizero_bookworm_current_6.1.53
FOR
Armbian 23.8.1 Bookworm with Linux 6.1.47-current-sunxi64
Note that arm64 replace armhf
Install Domoticz and reboot
Orange Pi 0
wget http://security' 'debian' 'org/debian-security/pool/updates/main/o/openssl/libssl1.1_1.1.1n-0+deb11u5_armhf' 'deb
sudo dpkg -i libssl1.1_1.1.1n-0+deb11u5_armhf.deb
sudo reboot
FOR
sudo apt update && sudo apt install armbian-config && sudo reboot
sudo apt update && sudo apt install && sudo reboot
wget http://security.debian.org/debian-security/pool/updates/main/o/openssl/libssl1.1_1.1.1n-0+deb11u5_arm64.deb
sudo dpkg -i libssl1' '1_1' '1' '1n-0+deb11u5_arm64' 'deb
sudo reboot
Active: active (running) since Sun 2023-10-22 13:34:04 CEST; 24s ago
Good to know this works, but IMO for those that follows the usual Debian (& derivatives) upgrade path from CLI (by modifying /etc/apt/source.list etc) this may not be needed as old libraries from previous Bullseye/Debian 11 should remain after upgrade to Bookworm/Debian 12. This'll not be the case for a brand new install.
Did not upgrade my raspberry PI3B hosting Domoticz for now, but for a few PC's I still have previous libssl1.1 if I look what's present a file location for an x86-64 PC for instance:
https://packages.debian.org/bullseye/libssl1.1
=> File list for x86-64 shows Bullseye libssl1.1 are supposed to be & if I check on a PC that got upgraded, tadam...
$ ls -alrt /usr/lib/x86_64-linux-gnu/libssl*
-rw-r--r-- 1 root root 417144 15 févr. 2023 /usr/lib/x86_64-linux-gnu/libssl3.so
-rw-r--r-- 1 root root 597792 13 sept. 21:21 /usr/lib/x86_64-linux-gnu/libssl.so.1.1
-rw-r--r-- 1 root root 696352 26 sept. 21:08 /usr/lib/x86_64-linux-gnu/libssl.so.3
Tried to extract/start a stable Linux x86 domoticz supposed to be compiled towards libssl1.1 & no issue observed (https included).
From a new install (not upgraded), we can see no libssl1.1 is available in Bookworm repo:
https://packages.debian.org/search?keywords=libssl
=> So the need to install it manually (& hope no other dependency issue shows-up, looks that was the case for you) using .deb file from previous version for the machine architecture (armhf/arm64 depending on raspbian 32 or 64 bits installed).
Some distros like Alpine Linux provide a libsslcompat that makes a compatibility bridge between libssl1.1 and libssl3 to ease transition but looks Debian do not provide this, unfortunately.
Thanks for the explanations, it-s now more clear for me.
THNX bo2be working like charm!
