an update for users with the same problem.
It appears to be a problem that the volume dimmer in Domoticz is compatible with a volume field in Zwave JS that does not work,
there are 2 fields in Zwave JS with volume
"[78-121-1-defaultVolume] Default volume" and
[78-121-1-volume] Volume
domotic is connected to the last [78-121-1-volume] Volume and it does not work in zwave JS so domoticz could be connected on the first mentioned.
There has been a response on GitHub and I hope they can/will resolve it now that the problem has become somewhat clear.
However, more is needed than just linking the button to a different volume field. To make the siren work, you will also need to be able to set the sound tone. and that field is not in domoticz at all.
As soon as there is more to report, I will do so here.
ZW162 (Aeotec Siren 6) No siren switches Domoticz -> ZW-JS-UI
rapperobert
rapperobert
**Aeotec 6 Siren Workaround**: ZW162 (Aeotec Siren 6) No siren switches Domoticz -> ZW-JS-UI
While this solution might not be the most elegant, it works. I'm just a simple user who figured this out through trial and error. For technical support, please be aware that my expertise might be limited. However, I believe the following guide should help you get started.
**Steps**:
1. **Create 3 Dummy Switches**:
- **Sirene Sound**: A selector switch. This will be used to choose your sound, so populate it with values from 1 to 30. The first field is 0, which means no sound.
- **Sirene Control**: A standard switch. This will be used to turn the siren on or off.
- **Sirene 1 Volume Dummy**: A dimmer switch. This will be used to adjust the siren's volume.
2. **Install Mosquitto Clients on the Domoticz Docker Container**:
*Note*: You will lose these changes when the container is refreshed, so you might need to redo these steps after updating the container. If anyone knows a better solution, please share!
- Open your terminal.
- Run `docker ps` to see the container ID for Domoticz.
- Replace `[CONTAINER_NAME_OR_ID]` with the container ID in the following command:
docker exec -it [CONTAINER_NAME_OR_ID] /bin/sh
- Install Mosquitto Clients:
apt update
apt-get install mosquitto-clients
- You can now test with:
mosquitto_pub -h [YOUR_BROKER_IP] -p 1883 -t "[YOUR_MQTT_PREFIX]/sirene_aeotec_6/121/1/toneId/set" -m '{"value": 14}'
For example:
mosquitto_pub -h x.x.x.x -p 1883 -t "zwavejs/sirene_aeotec_6/121/1/toneId/set" -m '{"value": 14}'
- The siren should turn on. Change 14 to 0 to turn it off.
- Exit with `exit`.
3. **Domoticz Scripting**:
- In Domoticz, navigate to the script editor and create a DzVents script. Note that the broker name below is the MQTT prefix you used in Zwave JS.
- For volume control, create a separate script:
I hope this guide is clear enough to help those struggling with this issue. The Domoticz team is working on a permanent solution, but until then, this workaround should suffice.
Note: Be sure to replace placeholder values like `[YOUR_BROKER_IP]` and `[YOUR_MQTT_PREFIX]` with your actual values before using the script.
**Steps**:
apt update
For example:
- Exit with `exit`.
devices = { 'Sirene Control' }
local brokerIp = '[YOUR_BROKER_IP]'
local brokerPort = '1883'
local topic = '[YOUR_MQTT_PREFIX]/sirene_aeotec_6/121/1/toneId/set'
local message = ''
-- Get the selector level name from 'Sirene Sound'
local sireneSoundValue = domoticz.devices('Sirene Sound').levelName
-- Check the state of 'Sirene Control' switch
if device.state == 'On' then
message = '{"value": ' .. sireneSoundValue .. '}'
message = '{"value": 0}'
local command = '/usr/bin/mosquitto_pub -h ' .. brokerIp .. ' -p ' .. brokerPort .. ' -t "' .. topic .. '" -m \'' .. message .. '\''
domoticz.log('About to execute command: ' .. command, domoticz.LOG_INFO)
local result = domoticz.executeShellCommand(command)
-- Log the command result
domoticz.log('Result of the command: ' .. tostring(result), domoticz.LOG_INFO)
}- For volume control, create a separate script:
devices = { 'sirene 1 volume dummy' }
local topic = '[YOUR_MQTT_PREFIX]/sirene_aeotec_6/121/1/defaultVolume/set'
-- Get the dimmer level and include it in the message
local message = '{"value": ' .. device.level .. '}'
}I hope this guide is clear enough to help those struggling with this issue. The Domoticz team is working on a permanent solution, but until then, this workaround should suffice.
Eugene
Re: ZW162 (Aeotec Siren 6) No siren switches Domoticz -> ZW-JS-UI
Hi Guys,
Did someone manage to make this siren work in Domoticz?
I got my ZW164 siren today, added it into ZwaveJS, got devices discovered in Domoticz but can't activate the Siren from domoticz UI.I can trigger the siren from Zwave JS direct, but it seems Domoticz is missing the corresponding interface for some reason.
I am attaching subset of devices discovered by ZwaveJS and i can make sound on the Siren by flipping dropbox "[104-121-6-ToneId] Play Tone" between tone type and "off". but if you look into devices which domoticz discovered from MQTT - it is missing this option completely, it has only "Volume" from 104-121-* subset. When i try to switch or change corresponding "Volume" dimmer - nothing happens not matter what the dimmer value is or what the switch state is.
Any thoughts on the next steps i can take to make this work will be highly appreciated.
- Screenshot 2025-01-06 233139.png (73.48 KiB) Viewed 1333 times
- Screenshot 2025-01-06 232933.png (93.44 KiB) Viewed 1333 times
Eugene
I’m trying to control a siren by sending MQTT messages to the zwave/Siren/121/6/toneId/set topic. Using MQTT Explorer, I can successfully make the siren sound by publishing {"value":1} to this topic and turn it off by publishing {"value":0}. However, when I try to send the same messages from a Lua script in Domoticz, the messages always appear under the domoticz/out topic instead of the zwave/Siren/121/6/toneId/set topic I need.
Here’s my Lua script:
if devicechanged['SirenControl'] then
print('Device SirenControl changed to: ' .. devicechanged['SirenControl'])
if devicechanged['SirenControl'] == 'On' then
commandArray['PublishMqtt'] = 'zwave/Siren/121/6/toneId/set:{"value":1}'
elseif devicechanged['SirenControl'] == 'Off' then
commandArray['PublishMqtt'] = 'zwave/Siren/121/6/toneId/set:{"value":0}'
I have two MQTT connections configured:
With autodiscovery, used for Home Assistant and Z-Wave devices.
Without autodiscovery, using domoticz/in and domoticz/out topics.
How can I send messages directly to the zwave topic from Lua within Domoticz? Is there a way to configure this without relying on external binaries like mosquitto_pub? Would I need to modify the domoticz/out topic or create an additional MQTT connection?
- Domoticz version: 2025.1
These missing devices could be number devices that are shown in Domoticz in the MQTT Autodiscovery Hardware gateway setup. See wiki https://wiki.domoticz.com/MQTT#MQTT_Autodiscovery_SetupEugene wrote: Monday 06 January 2025 23:44 Hi Guys,
There is no function (yet) to set these from a scripting language (lua, dzvents etc).
Eugene
Thanks for detailed information, waltervl! indeed, i see non discovered devices in the Hardware setup. Is there anything i can do to help to make those devices discoverable by Domoticz?
Regarding sending the MQTT messages - i made a bit of research and it seems i need a node-red to transform the message from domoticz. Am I on the right way or is there better/smarter way to make MQTT control of the siren work?
They are discovered as number devices and therefore are being displayed in the setup part as these number devices should be used to setup devices (change timeout, change transition times etc).
If you want to directly send custom mqtt payloads from domoticz to zwave-js-ui better use mosquito_pub in Lua. But you can also use Node-Red, it has a big fan base.
Eugene
so, i confirm with node-red i can achieve what i want, the attached workflow makes at least one siren sound work for me over mqtt.
waltervl, do you know by any chance if there is plan to make domoticz better supporting Aeotec devices or if there is a plan to add mosquitto_pub into domoticz docker image?
I am just trying to understand what the most feasible way forward for me with the current limitations i am facing. I am not a big fan of modifying existing container myself, also node-red seems a bit an overkill here
- Screenshot 2025-01-07 171324.png (49.48 KiB) Viewed 1303 times
I believe this is discussed before. Search for Sirene on this forum or in Domoticz GitHub issues.
I suppose only when someone with programming skills has the same issue it will be solved.
