sonoff usb 3.0 dongle E and zigbeefordomotciz
jacobsentertainment
Domoticz version: 2021-1
Post by jacobsentertainment »
I took the time to apply a completely new installation to my domoticz. Now I am running into the point where I would like to do the upgrade to switch to zigbee for domoticz. After some simple searching I come up with blackadder that the usb stick should work if it uses the zigbee standard, also on Itead's site it says "Domoticz zigbee plugin" is compatible. Prime went through the whole installation proccess without any problems.
Now we come to installing the plugin, and in the dropdown menu there is only a few devices available "Zigate, Zigate+, Texas instruments ZNP, Silicon labs EZSP or Conbee/rasbee"
Of course none of them match or actually work either. And all come back with an error in the log.
What is the next step because on the wiki of zigbeefordomoticz I can't figure it out.
Domoticz version: 2025.1
Re: sonoff usb 3.0 dongle E and zigbeefordomotciz
This dongle should work with the Silicon labs EZSP option.
jacobsentertainment
In the meantime, of course, I was also trying to get it working, I tried a few things. Eventually I set the "API base url (http://username:[email protected]:port):" with my own ip address which finally led to a working installation. Including the device as you discribed. As that is the nearest to my device. Now I'm busy reconnecting all the zigbee devices one by one and then making an image of the whole thing for the future.
Cheers again walter :lol:
