How can I dump data from a device  [Solved]
Tukker
Domoticz version: 2023.2
Post by Tukker »
I tried dumping data from my device.
Whatever I try, there is an error about a nil value.
local myDevice = 'YR weer'
		devices = {'YR weer'},
		timer = {'every minute'},
	logging = {
	    level = domoticz.LOG_DEBUG,
	    marker = 'Outside temperature',
	execute = function(domoticz, triggeredItem)
        -- myDevice.dump()
        -- dumpDeviceStatus(item.data, myDevice)
        -- dumpAttributes(myDevice)
        local outside_temperature = domoticz.devices('YR weer').temperature
        domoticz.log('temp = '.. outside_temperature, domoticz.LOG_DEBUG)
        domoticz.notify('notifyer', YR .. '  outside temperature  : '.. outside_temperature..'º',domoticz.PRIORITY_HIGH)
and the error in the log file
 2023-01-19 00:01:00.413 Error: dzVents: Error: (3.1.8) Outside temperature: An error occurred when calling event handler Temperatuur buiten
2023-01-19 00:01:00.413 Error: dzVents: Error: (3.1.8) Outside temperature: ...scripts/dzVents/generated_scripts/Temperatuur buiten.lua:16: bad argument #1 to 'dump' (function expected, got no value)
Must be a very simple problem, however I can't find the bug.
Bugs bug me.
Domoticz version: 2026.3
Re: How can I dump data from a device  [Solved]
In your script use
triggeredItem.dump()
or use
domoticz.devices(myDevice).dump()
Tukker
Post by Tukker »
Thank you for the information @waltervl
I couldn't find it in the dzvents wiki.
After reading your information I now understand how to handle an attribute like dump() or any other.
The better choice to dump the complete json is: domoticz.devices(myDevice).dump()
Bugs bug me.
Tukker
Post by Tukker »
I'm sorry to come back on this question but I still cannot retrieve how to dump()
dz.devices('Power').dump()
returns this error: 2023-09-13 22:25:00.377 Error: dzVents: Error: (3.1.8) Afzonderlijke Meterstanden 1.10: .../dzVents/generated_scripts/P1 meterstanden gesplitst.lua:51: attempt to concatenate a nil value
dz.log('Production        : ' ..P1.usageDelivered, dz.LOG_INFO)
dz.log('Consumtion      : ' ..P1.usage, dz.LOG_INFO)
works like a charm
usage2, usage1, return2, return1 no problem.
json Data: Data "30174158;16197288;11095429;26693622;510;0"
What's the secret for dump()
From the Wiki:
P1 Smart meter
    counterDeliveredToday: Number.
    counterToday: Number.
    usage1, usage2: Number.
    return1, return2: Number.
    updateP1(usage1, usage2, return1, return2, cons, prod): Function. Updates the device. Supports command options.
    usage: Number.
    usageDelivered: Number.
Bugs bug me.
Do you have more devices called 'Power'? As DzVents cannot handle this. For DzVents all device names should be unique.
What happens if you dump another device to the log?
For me it works
This code gives me be the dump as listed in the spoiler for a P1 smart meter device
		timer = {
			'every minute',
	execute = function(domoticz, timer)
		domoticz.devices(67).dump()
2023-09-13 23:02:00.036 Status: dzVents: device> signalLevel: 12
2023-09-13 23:02:00.036 Status: dzVents: device> id: 67
2023-09-13 23:02:00.036 Status: dzVents: device> description:
2023-09-13 23:02:00.036 Status: dzVents: device> batteryLevel: 255
2023-09-13 23:02:00.036 Status: dzVents: device> switchTypeValue: 0
2023-09-13 23:02:00.036 Status: dzVents: device> name: P1 Smart Meter
2023-09-13 23:02:00.036 Status: dzVents: device> switchType: On/Off
2023-09-13 23:02:00.036 Status: dzVents: device> lastLevel: 0
2023-09-13 23:02:00.036 Status: dzVents: device> baseType: device
2023-09-13 23:02:00.036 Status: dzVents: device> data:
2023-09-13 23:02:00.036 Status: dzVents: device> _state: 3879384;3171962;3169839;141761;2100;100
2023-09-13 23:02:00.036 Status: dzVents: device> counterDeliveredToday: 5.479 kWh
2023-09-13 23:02:00.036 Status: dzVents: device> customImage: 0
2023-09-13 23:02:00.036 Status: dzVents: device> protected: false
2023-09-13 23:02:00.036 Status: dzVents: device> hardwareID: 4
2023-09-13 23:02:00.036 Status: dzVents: device> hardwareType: Dummy (Does nothing, use for virtual switches only)
2023-09-13 23:02:00.036 Status: dzVents: device> icon: counter
2023-09-13 23:02:00.036 Status: dzVents: device> counterToday: 11.315 kWh
2023-09-13 23:02:00.036 Status: dzVents: device> hardwareName: Dummy
2023-09-13 23:02:00.036 Status: dzVents: device> usage: 2100 Watt
2023-09-13 23:02:00.036 Status: dzVents: device> counterDelivered: 3311.6000976562
2023-09-13 23:02:00.036 Status: dzVents: device> usageDelivered: 100 Watt
2023-09-13 23:02:00.036 Status: dzVents: device> _nValue: 0
2023-09-13 23:02:00.036 Status: dzVents: device> counter: 7051.346
2023-09-13 23:02:00.036 Status: dzVents: device> hardwareTypeValue: 15
2023-09-13 23:02:00.036 Status: dzVents: device> unit: 1
2023-09-13 23:02:00.036 Status: dzVents: device> timedOut: false
2023-09-13 23:02:00.036 Status: dzVents: device> subType: Energy
2023-09-13 23:02:00.036 Status: dzVents: device> iconNumber: 34
2023-09-13 23:02:00.036 Status: dzVents: device> image:
2023-09-13 23:02:00.036 Status: dzVents: device> deviceID: 82067
2023-09-13 23:02:00.036 Status: dzVents: device> changed: false
2023-09-13 23:02:00.036 Status: dzVents: device> deviceType: P1 Smart Meter
2023-09-13 23:02:00.036 Status: dzVents: device> lastUpdate: 2023-09-13 23:00:00
2023-09-13 23:02:00.036 Status: dzVents: device> rawData:
2023-09-13 23:02:00.036 Status: dzVents: device> 1: 3879384
2023-09-13 23:02:00.036 Status: dzVents: device> 2: 3171962
2023-09-13 23:02:00.036 Status: dzVents: device> 3: 3169839
2023-09-13 23:02:00.036 Status: dzVents: device> 4: 141761
2023-09-13 23:02:00.036 Status: dzVents: device> 5: 2100
2023-09-13 23:02:00.036 Status: dzVents: device> 6: 100
2023-09-13 23:02:00.036 Status: dzVents: device> active: false
2023-09-13 23:02:00.036 Status: dzVents: device> deviceId: 82067
2023-09-13 23:02:00.036 Status: dzVents: device> actualWatt: 2100
2023-09-13 23:02:00.036 Status: dzVents: device> sValue: 3879384;3171962;3169839;141761;2100;100
2023-09-13 23:02:00.036 Status: dzVents: device> isGroup: false
2023-09-13 23:02:00.036 Status: dzVents: device> _adapters:
2023-09-13 23:02:00.036 Status: dzVents: device> 1: P1 smart meter energy device adapter
2023-09-13 23:02:00.036 Status: dzVents: device> isHTTPResponse: false
2023-09-13 23:02:00.037 Status: dzVents: device> switchTypeValue: 0
2023-09-13 23:02:00.037 Status: dzVents: device> WhActual: 2100
2023-09-13 23:02:00.037 Status: dzVents: device> counterDelivered: 3311.6000976562
2023-09-13 23:02:00.037 Status: dzVents: device> inActive: true
2023-09-13 23:02:00.037 Status: dzVents: device> deviceSubType: Energy
2023-09-13 23:02:00.037 Status: dzVents: device> name: P1 Smart Meter
2023-09-13 23:02:00.037 Status: dzVents: device> signalLevel: 12
2023-09-13 23:02:00.037 Status: dzVents: device> switchType: On/Off
2023-09-13 23:02:00.037 Status: dzVents: device> isDevice: true
2023-09-13 23:02:00.037 Status: dzVents: device> counter: 7051.346
2023-09-13 23:02:00.037 Status: dzVents: device> counterToday: 11.315
2023-09-13 23:02:00.037 Status: dzVents: device> _state: 3879384;3171962;3169839;141761;2100;100
2023-09-13 23:02:00.037 Status: dzVents: device> baseType: device
2023-09-13 23:02:00.037 Status: dzVents: device> hardwareId: 4
2023-09-13 23:02:00.037 Status: dzVents: device> _nValue: 0
2023-09-13 23:02:00.037 Status: dzVents: device> lastUpdate: 2023-09-13 23:00:00
2023-09-13 23:02:00.037 Status: dzVents: device> isScene: false
2023-09-13 23:02:00.037 Status: dzVents: device> isVariable: false
2023-09-13 23:02:00.037 Status: dzVents: device> description:
2023-09-13 23:02:00.037 Status: dzVents: device> isHardware: false
2023-09-13 23:02:00.037 Status: dzVents: device> usage2: 3171962
2023-09-13 23:02:00.037 Status: dzVents: device> usage1: 3879384
2023-09-13 23:02:00.037 Status: dzVents: device> bState: false
2023-09-13 23:02:00.037 Status: dzVents: device> counterDeliveredToday: 5.479
2023-09-13 23:02:00.037 Status: dzVents: device> id: 67
2023-09-13 23:02:00.037 Status: dzVents: device> isSecurity: false
Tukker
Post by Tukker »
I did this:
dz.log('Dumpdata : ' ..domoticz.devices(67).dump(), dz.LOG_INFO)
Dzvents does not like my way of calling the dump() function and press it into a LOG statement.
Lesson learned.
Thanks Walter.
Bugs bug me.
off course as the dump function is doing that writing to the log for you (as described in the wiki)
