test sensor values before storing in database
mancide
Domoticz version: 2024.6
Post by mancide »
Is there way to run a script on a new sensor value before it is stored in the value database?
I think it is possible as I once wrote a script that ate all my sensor values...
What I want to do:
1. a sensor value comes in.
2. I want to do some checking (eg. the water temp of my fish pond can´t be 2000C. Yes, I do get such values...)
3. ignore bad values.
Maybe an (optional) value range for each sensor might be a good idea.
Tom
Raspberry Pi 3B v1.3 - 16GB SDcard - Raspbian Bullseye
Aeotec Z-Stick Gen5 (ZW090) -> Z-Wave JS UI -> mosquitto
RFXCOM RFXtrx433E
Unifi controller -> Domoticz-Unifi-Presence plugin
Nest thermostat
SAJ solar convertor
Smart Gateway Gas/water meter
Domoticz version: 2025.1
Re: test sensor values before storing in database
The hardware gateway (integration or python plugin) should manage this.
There is no possibility to script this.
If you have a Dummy device created you probably using an external script that fills the dummy device. So that script can do the validation first.
mancide
Post by mancide »
I don´t think the hardware gateway 'can' solve this problem.
It can´t know how I'm using a sensor. For example, I have a RF sensor in my freezer which should never display 30C. Air temp sensors should display 30C.
Besides that I have temp sensor coming from an RFXCom and from Z-wave. Different hardware, same issue...
Each sensor already has a correction factor that can be set.
If you would add a value range option there, it would solve the problem...
RFXCOM RFXtrx433E
Nest thermostat
SAJ solar convertor
I think there is something else wrong if you have this many incorrect values coming from your sensors.
I do not use RF nor Zwave, only use Zigbee but I never have discrepancies in reported values.
I know Zwave has some checks for incorrect energy readings. But that is still arranged in the hardware gateway as indicated before.
