I am not satisfied with the (non existing) integration into my home automation system with my doorbell (Philips Welcome Eye Connect) : no API or equivalent and no (more) open RTSP stream.
Could you recommend a product:
- at a reasonable price
- ideally 2 wires (I did not include more than the 2 wires in my 30 meters between portal pillar and current home screen) and therefore no POE
- local video stream available (RTSP), ideally that could be left open all the time without impacting the "ring" functionality. Failing that, "native" motion detection with full API or possibility to retrieve events (therefore motion detection), and local photo capture
- Full open API or way to retrieve events, photos and send commands (opening)
Thank you very much or your help
Doorbell for portal opening
- Domoticz version: 2025.1
Re: Doorbell for portal opening
Perhaps Reolink? viewtopic.php?p=304502
Foscam VD1: viewtopic.php?t=37003
Both I do not know how this 2 wires connection will work for these...
rezzalex
Thanks a lot.
Maybe I was nt precise enough in my description.
I need a video doorbell with 1 or idealy 2 integrated relays so that I can open my gate when someone is ringing. I think I should have call it an "intercom", right ("portier" in french)?
Even if there could be a Domoticz integration to be notified in video when ringing, I want an out of the box solution for answering, talking and visualizing the person who ring and open the gate to him. Because as far as I know, the 2 ways audio flow can never be integrated in a DYI domotic system.
For the moment I am looking at the DoorBird D1101V but I am a bit afraid of the price, even though it looks wonderfull for my needs.
rezzalex
Finally, it will be the Dahua DHI-VTO2202F-P-S2
I expect to use this plugin and maybe add some features if I am able to :
https://github.com/rbrouwer/dahua-vto-dz
