I would like to arm the alarm system without the need to enter the code first.
Also the time delay when activate Arm Home is not needed.
Maybe this can be changed in the domoticz/www/secpanel/index.html file, but to be honnest, i don't know how.
Maybe there is somebody who has more knowledge to help me with this?
Thanks in advance.
Security panel pin code removal for arming system
- Domoticz version: 2025.1
Re: Security panel pin code removal for arming system
The delay and pin code is a setting in menu setup - settings tab Security.
Did you already try to empty the pin field? I do not know if this works.
Check also wiki page https://www.domoticz.com/wiki/Alarm_Setup for more background how to use Domoticz as an alarm system.
Pauls
Hi waltervl,
Thanks for your reply.
Domoticz does not allow blanks in the security panel password.
On top of that i would like the need to enter the pin to disarm the system.
It does allow an empty pin field to arm and disarm without a pin.
Only there is no option to differ using a pin code for arming or disarming.
Pauls
When i clear the password field and apply setting, the original password is set again.
I wonder how you clear your password.
I cleared the field and pressed apply.
The password field is then filled with asterix ***
Pauls
Yes, i do exactly the same.
But when i press "arm away" (without entering a code first) on the code panel, the system response with "wrong code".
Also after a refresch of the screen.
But then again, this is not what i have in mind, i still want only the need to enter a code when dis-arming the alarm.
Again thanks for your support, hopefully this will be possible in the future.
