Maybe somebody can help to find a solution. I am trying to add a local variable to a json url command without success. The following command is working well and the RBG color will change.
os.execute('curl "http://127.0.0.1:8080/json.htm?type=com ... hite=false"')
but if I replace the hex value by a local variable the curl command end with an error.
I tried serveral things to to create first the the http string and store it to a variable but everything will fail.
What am I doing wrong? Please help
Lua Script tu update a device with json url -help
- jvdz
- Domoticz version: 4.107
Re: Lua Script tu update a device with json url -help
Post your lua script code in a codebox </> so we can see exactly what you coded and tell us the error you get.
- psubiaco
Edited:
THIS DOES NOT WORK
THIS WORK CORRECTLY!
THIS DOES NOT WORK
os.execute("curl http://127.0.0.1:8080/json.htm?type=command¶m=setcolbrightnessvalue&idx=14&brightness=12&hex=" .. RGB .. "&iswhite=false")
os.execute("curl \"http://127.0.0.1:8080/json.htm?type=command¶m=setcolbrightnessvalue&idx=14&brightness=12&hex=" .. RGB .. "&iswhite=false\"")
Paolo
thaui
- Domoticz version: 2023.2
@psubiaco
the first recommended line is not generating any error in the protocol, but it's also not doing anything.
the second one is working well. Thanks you saved me many hours of playing around
- psubiaco
Ok, I've edited my post to let people solving this issue quickly.
Have a nice weekend!!
Paolo
