This is the point where I decided to root the Toon... which in the end also saved me the costs of the Toon subscription..EdwinK wrote: Tuesday 13 August 2019 10:02 Tried, and after activating all my settings in domoticz are gone. Deleted the plugin and everything works fine again.
I think it's time to give up on Toon.
Error ToonThermostat
Martini77
- Domoticz version: 2023.2
Re: Error ToonThermostat
Running Domoticz:
- Main @ LXC (Proxmox);
- Secondary @ Pi4B (for backup / test / alerts)
- Synology (Docker) for alerts on main
Martini77
I had issues with the API and discrict heat...SteGe wrote: Tuesday 30 July 2019 20:05 Cool, super nice to see there is finally a solution on the ongoing Toon problems in Domoticz.
I've got it working on my Domoticz which runs on a synology NAS. I need to use the ToonApiLib tag 3.0.9 and toonapiblib4domoticz tag 1.0.14 before it was working.
The only problem is that after adding the devices the device list is empty and the logging is giving the error: Error: WebServer PO exception occurred : 'stoull'
The error isn't giving a lot on information on this forum nor on internet. Did a reboot which wasn't successful. Finally removed the hardware and the device list was full again. Probably it has something to do that my Toon is connected to Stadswarmte? Because it receives all data on the first time but gives directly the following errors in the logging:
(Toon) An error occurred updating gas usage
(Toon) An error occurred updating program state
Could you all give me a help on this?
Was able to fix this with some changes in the code; see District heat not supported #20
Running Domoticz:
SteGe
Unfortenatly if I do that I will get other errors, probably due to the fact I'm running it on synology so I have to stick to 3.0.9 of the library?
Synology DS3615xs | Raspberry pi 3b |
RFXtrx433E | MySensors | Z-wave | Philips Hue | Ikea Tradfri |
Sunscreen | Power switches | Toon | Harmony | UE Smartradio |
Weatherstation | Doorbell | Letterbox reader | Lux | Temp | Humidity | Motion |
It works perfect!
It works perfect!
Domoticz latest stable, Intel NUC, Proxmox, Zigate, RFLink, Kaku switches, Ikea lights, Xiaomi sensors, Honeywell smoke detectors, Yeelight, Shelly, Slave Domoticz PI 3B+, Node-Red, Espeasy.
steef84
- Domoticz version: DS213+
Simple question; is an subscription nessecary for this plugin? Or is it also working via the api without a subscription. Installed this on a pi4, but the log is full of errors.
- Stefan
- a3vd
You need a subscription !
Raspberry 3+ / 4
P1 smartcable / RFXtrx433 FW 182 / Several 1 wire Temp Sensors /DHT12/Conbee2 (zigbee)
Several Kaku switches/ Weather Underground / Hue
Hello, after updating to 2020 stable domoticz Toon is not working anymore? Or should i use a beta?
2020-04-20 21:16:45.710 Error: (ToonApiLib) failed to load 'plugin.py', Python Path used was '/home/pi/domoticz/plugins/toonapilib4domoticz/:/usr/lib/python37.zip:/usr/lib/python3.7:/usr/lib/python3.7/lib-dynload:/usr/local/lib/python3.7/dist-packages:/usr/lib/python3/dist-packages:/usr/lib/python3.7/dist-packages'.
2020-04-20 21:16:45.710 Error: (ToonAPI) Module Import failed, exception: 'ModuleNotFoundError'
2020-04-20 21:16:45.710 Error: (ToonAPI) Module Import failed: ' Name: devices.device_factory'
2020-04-20 21:16:45.710 Error: (ToonAPI) Error Line details not available. Domoticz latest stable, Intel NUC, Proxmox, Zigate, RFLink, Kaku switches, Ikea lights, Xiaomi sensors, Honeywell smoke detectors, Yeelight, Shelly, Slave Domoticz PI 3B+, Node-Red, Espeasy.
- a3vd
I got it working with the beta, but i think it should work with the normal stable aswell did you follow the installation instructions ?
Raspberry 3+ / 4
stephanvdplas
- Domoticz version: 2023.1
Since today, the certificate of https://api.toon.eu is no longer valid.
I'll try to reach eneco to solve this. In the meantime I'm afraid the toonapilib4domoticz plugin is not operational.
Regards,
Stephan
Regards,
Stephan
- Running LMS, Domoticz and Dashticz on a windows 11 laptop.
- LMS (11 players) / Hue (26 lights, 2 switches) / Z-wave (14 devices) / Toon (unrooted) / Chromecast
Any update from eneco?stephanvdplas wrote: Monday 07 August 2023 12:45 Since today, the certificate of https://api.toon.eu is no longer valid.
Regards,
Stephan
stephanvdplas
[/quote]
[/quote]
No update, but I saw it was solved later that day. All toons had D03 issues until tuesday, but since yesterday all is working fine again.
[/quote]
stephanvdplas
Hello all,
I have Toon errors in my Domoticz logs again.
The testtoonapilib as provided by Waspy is also showing that there cannot be created a Toon object (while this did work before).
Have others the same experience?
Here the errors (debug=on):
2024-11-18 11:26:40.081 Toon: Worker thread started.
2024-11-18 11:26:40.081 Status: Toon: Started.
2024-11-18 11:26:40.081 Status: Toon: Entering work loop.
2024-11-18 11:26:40.425 Error: Toon: (ToonApiLib) failed to load 'plugin.py', Python Path used was 'C:\Program Files (x86)\Domoticz\plugins\toonapilib4domoticz\;C:\Program Files (x86)\Python38-32\python38.zip;C:\Program Files (x86)\Python38-32\Lib\;C:\Program Files (x86)\Python38-32\DLLs\;C:\Program Files (x86)\Domoticz;C:\Program Files (x86)\Python38-32;C:\Program Files (x86)\Python38-32\lib\site-packages'.
2024-11-18 11:26:40.430 Error: Toon: Traceback (most recent call last):
2024-11-18 11:26:40.430 Error: Toon: File "C:\Program Files (x86)\Domoticz\plugins\toonapilib4domoticz\plugin.py", line 34, in <module>
2024-11-18 11:26:40.430 Error: Toon: import toonapilib
2024-11-18 11:26:40.430 Error: Toon: File "C:\Program Files (x86)\Python38-32\lib\site-packages\toonapilib\__init__.py", line 41, in <module>
2024-11-18 11:26:40.431 Error: Toon: from .toonapilib import Toon
2024-11-18 11:26:40.431 Error: Toon: File "C:\Program Files (x86)\Python38-32\lib\site-packages\toonapilib\toonapilib.py", line 39, in <module>
2024-11-18 11:26:40.431 Error: Toon: from requests import Session
2024-11-18 11:26:40.432 Error: Toon: File "C:\Program Files (x86)\Python38-32\lib\site-packages\requests\__init__.py", line 48, in <module>
2024-11-18 11:26:40.432 Error: Toon: from charset_normalizer import __version__ as charset_normalizer_version
2024-11-18 11:26:40.432 Error: Toon: File "C:\Program Files (x86)\Python38-32\lib\site-packages\charset_normalizer\__init__.py", line 24, in <module>
2024-11-18 11:26:40.432 Error: Toon: from .api import from_bytes, from_fp, from_path, is_binary
2024-11-18 11:26:40.432 Error: Toon: File "C:\Program Files (x86)\Python38-32\lib\site-packages\charset_normalizer\api.py", line 5, in <module>
2024-11-18 11:26:40.432 Error: Toon: from .cd import (
2024-11-18 11:26:40.432 Error: Toon: File "C:\Program Files (x86)\Python38-32\lib\site-packages\charset_normalizer\cd.py", line 14, in <module>
2024-11-18 11:26:40.432 Error: Toon: from .md import is_suspiciously_successive_range
2024-11-18 11:26:40.432 Error: Toon: AttributeError: PyCapsule_Import "charset_normalizer.md__mypyc.init_charset_normalizer___md" is not valid- Running LMS, Domoticz and Dashticz on a windows 11 laptop.
Users browsing this forum: Bing [Bot], Google [Bot] and 1 guest
