somfy rts gateway
bend94
somfy rts gateway
Post by bend94 »
i am not skill in radio frequency
i would like to build a gateway between my homeautomation system (like domoticz ) and my somfy technology Radio Somfy RTS 433,42 MHz (like blinds, shutter, etc).
i can manage my somfy RTS equipments with my remote control but it should be great to manage with my homeautomation system
What is the best choice to build such gateway ?
Do you have links for my to start ?
thanks in advance
plugge
Re: somfy rts gateway
Post by plugge »
bend94 wrote: Friday 04 August 2023 15:27 What is the best choice to build such gateway ?
Well, the best way depends on your situation (wishes and devices), but I use RFXcom rfxtrx 433 lan. Mostly for the RTS Somfy blinds, but also some kaku switches and rubicson temp and hum devices.
http://www.rfxcom.com/
bend94
Post by bend94 »
if i buy RFX433 Usb device
is it possible to connect it to a raspberry pi ?
do i have to load a special firmware on that device ?
Thx
plugge
Post by plugge »
bend94 wrote: Friday 04 August 2023 16:07 if i buy RFX433 Usb device
Yes, no problem connecting it to your pi.
No, no special firmware.
Checkout the user guide on: http://www.rfxcom.com/epages/78165469.s ... /Downloads
bend94
Post by bend94 »
what kind of rfxcom to buy ?
Is there different type or just one version ?
b_weijenberg
Post by b_weijenberg »
Somfy RTS is supported by the older RFXtrx433E and RFXtrx433XL.
The new RFXusb-RFX433, RFX433XL-Wifi and RFXtrxLAN-RFX433 support Somfy RTS but now also Brel bi-directional.
In addition you can receive and control many other 433.92MHz sensors, fans and appliance modules. See chapter 2.2 in the RFXtrx User Guide.
RFX-433, RFX-433EMC, RFX-868
