Oficial Docker Container Topic is solved
nitpicker
- Domoticz version: 2022.2
Re: Oficial Docker Container
even sudo docker volume create portainer_data results in nothing...
- Sjonnie2017
- Domoticz version: Latest ß
What do you mean? How do you check? "results in nothing" says... well simply... nothing
YouLess Energy meter
nitpicker
when I click 'Enter'. Then the cursus moves to a new line and nothing happens until I click 'CTRL-C'.
- Sjonnie2017
I think you should best start over. And you might want to read the documentation on docker and docker-compose. This is not meant as a down play but you should get the basics before you endeavour into Dockerization.
- Domoticz version: 2025.1
For the docker users here, is the system reboot function (menu setup - reboot) working in a Domoticz Docker? Asking for viewtopic.php?f=6&t=39878
- Sjonnie2017
I haven't tested because restarting the container is fast and efficient enough.waltervl wrote: Thursday 09 February 2023 19:25 For the docker users here, is the system reboot function (menu setup - reboot) working in a Domoticz Docker? Asking for viewtopic.php?f=6&t=39878
- gizmocuz
nitpicker wrote: Thursday 09 February 2023 17:29 I don't know why, but I cannot start containers.
Docker compose can be installed with
From this moment you should not have to use 'sudo'Code: Select all
sudo apt-get update && sudo apt-get upgrade curl -fsSL test.docker.com -o get-docker.sh && sh get-docker.sh sudo usermod -aG docker ${USER} sudo systemctl enable docker sudo reboot
Anyway, you should also not chmod +x the docker compose configuration file (docker-compose.yml)
There is also no need to create any volumes as the configuration file of the Domoticz docker compose file already does this for you
What the above means is, create a local volume 'data' (./data)Code: Select all
volumes: - ./data:/opt/domoticz/userdata
This is great as here is stored everything you need.
Make a backup of this folder (or even better, the folder where you placed the docker-compose.yml file in (here will also be the data folder created)
To start the domoticz docker you then issue
or for previous docker-compose installationsCode: Select all
docker compose up -d
(note the dash between docker and compose)Code: Select all
docker-compose up -d
That's all, and now you should be able to browse to port 8080 of this machine
If you need to connect a USB device to the docker
issue
ls -al /dev/serial/by-id
you should see your serial devices
Next you edit the file docker-compose.yml
remove the # infront of the lines (take care of the indenting of the lines!)Code: Select all
# devices: # - "/dev/serial/by-id/usb-0658_0200-if00:/dev/ttyACM0"
make sure the serial line contains the right path (that you found above)
instead of /dev/ttyACM0 you can use /dev/ttyUSB0 and/or /dev/ttyUSB1
next you restart the docker container with
docker compose restart
or
docker compose stop
Now when you refresh the hardware page in domoticz, you should see the serial port
And that's it
And as said, please do some reading about docker-compose, you need to do it once and it will give you pleasure for the rest of live
nitpicker
It is working now, thanks for your help.
Domoticz, mqtt and portainer are all working in their docker containers.
hoeby
- Domoticz version: V2022.1
This doesn't work in docker.waltervl wrote: Thursday 09 February 2023 19:25 For the docker users here, is the system reboot function (menu setup - reboot) working in a Domoticz Docker? Asking for viewtopic.php?f=6&t=39878
I run the latest stable, maybe if something if changed, it works in the beta. I can't test beta, because i only want to run stable versions
Thin-client --> Docker Domoticz main environment
Pi3A+ --> Google home (GAssistPi)
Pi3B+ --> Docker (P1monitor, Domoticz test environment, Ubiquity controller)
- kiddigital
Reboot function probably does not work as the containers stops automatically when the Domoticz process stops.
So when requesting a reboot, processes stop and the container exits.
But you can specify ‘—restart unless-stopped’ as docker command parameter which restarts a stopped container.
hjzwiers
Why doesn't anyone post a working set of docker compose files for the less competent under us ....
I have a running zwave-js, domoticz running under docker containers set up through docker compose. I set up mosquitto direcly because I could not set this up through docker. It was supposed to be a smooth transition, but I am already working on it for two days .....
I would like to setup swag though a container as well
I have also setup portainer directly.
I found out why I could not connect to the Zwave stick, found someone with the same problem: solved
I have still have trouble with nefiteasyhttpserver, which uses the same port 3000 as zwave-js .....
I have trouble with getting acces from outside though 4443:443, but i am looking for the files I need to add to get this right. I have looked for an good tutorial but there is none .....
version: '3.3'
services:
domoticz:
container_name: domoticz
image: domoticz/domoticz:latest
restart: unless-stopped
devices:
- "/dev/serial/by-id/usb-0658_0200-if00-port0:/dev/ttyACM0"
ports:
- "8080:8080"
- “4443:443”
volumes:
- ./domoticz/config:/opt/domoticz/userdata
environment:
- TZ=Europe/Amsterdam
networks:
- domoticz
- proxy
version: '3.7'
services:
zwave-js-ui:
container_name: zwave-js-ui
image: zwavejs/zwave-js-ui:latest
restart: always
tty: true
stop_signal: SIGINT
environment:
- SESSION_SECRET=mysupersecretkey
- ZWAVEJS_EXTERNAL_CONFIG=/usr/src/app/store/.config-db
# Uncomment if you want logs time and dates to match your timezone instead of UTC
# Available at https://en.wikipedia.org/wiki/List_of_t ... time_zones
networks:
- zwave
devices:
# Do not use /dev/ttyUSBX serial devices, as those mappings can change over time.
# Instead, use the /dev/serial/by-id/X serial device for your Z-Wave stick.
- '/dev/serial/by-id/usb-0658_0200-if00:/dev/zwave'
volumes:
- /home/hjz/docker/zwjs/store:/usr/src/app/store
ports:
- '8091:8091' # port for web interface
- '3000:3000' # port for Z-Wave JS websocket server
networks:
zwave:
volumes:
zwave-config:
version: '3.3'
services:
domoticz:
devices:
ports:
- "8080:8080"
- “4443:443”
volumes:
environment:
networks:
- domoticz
- proxy
version: '3.7'
services:
zwave-js-ui:
restart: always
tty: true
stop_signal: SIGINT
environment:
networks:
- zwave
devices:
volumes:
ports:
networks:
zwave:
volumes:
zwave-config:
- andreo
- Domoticz version: 2024.3
here is my compose file
This install the next containers: NodeRed | NefitEasy | Duplicati | Grafana | Mosquitto | InfluxDB and Domoticz
version: '3.3'
services:
rpi-influxdb:
restart: always
ports:
- '8086:8086'
container_name: myInfluxDB
volumes:
- '/var/mydata/influxdb:/data'
image: hypriot/rpi-influxdb
grafana:
restart: always
ports:
- '3010:3000'
volumes:
- '/var/lib/grafana:/grafana_data'
container_name: myGrafana
image: grafana/grafana
eclipse-mosquitto:
restart: always
ports:
- '1883:1883'
- '9001:9001'
container_name: myMosquitto
volumes:
- '/var/mydata/mosquitto/config/mosquitto.conf:/mosquitto/config/mosquitto.conf'
- '/var/mydata/mosquitto/data:/mosquitto/data'
- '/var/mydata/mosquitto/log:/mosquitto/log'
image: 'eclipse-mosquitto:latest'
node-red:
restart: always
ports:
- '1880:1880'
volumes:
- '/var/mydata/nodered/data:/data'
container_name: myNodered
image: 'nodered/node-red:latest'
domoticz:
image: domoticz/domoticz:beta
container_name: myDomoticz
# Pass devices to container
devices:
- "/dev/serial/by-id/usb-Arduino__www.arduino.cc__Arduino_Mega_2560_852353331353518060D0-if00:/dev/ttyACM0"
- "/dev/snd/:/dev/snd/"
ports:
- "8080:8080"
- "8088:8088"
- "8443:443"
- "5000:5000"
- "1012:1012"
- "49000:49000"
volumes:
- ./userdata:/opt/domoticz/userdata
environment:
- LOG_PATH=/opt/domoticz/userdata/domoticz.log
nefiteasy-http-server:
restart: always
ports:
- '3000:3000'
container_name: myNefitEasy
environment:
- NEFIT_SERIAL_NUMBER=4180xxxxx
- NEFIT_ACCESS_KEY=BNBsFYnZ4S6xxxxx
- NEFIT_PASSWORD=xxxx
image: trafex/nefiteasy-http-server
duplicati:
image: lscr.io/linuxserver/duplicati:latest
container_name: myDuplicati
environment:
- PUID=1000
- PGID=1000
- TZ=Etc/UTC
- CLI_ARGS= #optional
volumes:
- /var/mydata/duplicati:/config
- /var/mydata:/source
- /opt:/source
ports:
- 8200:8200
restart: unless-stoppedLatest version of Domoticz and more running on Docker|Raspberry Pi 4-B 8GB Bookworm|RF-Link|Klik Aan Klik Uit|Nefit easy|ESPeasy|P1 power meter|S0PCM-5 through Ser2Net|Alecto WS5500|FrtizBox|Satel Integra|Solis
Greetz Andre.
Greetz Andre.
hjzwiers
Wow, it seems as though you took care of domotics and nefit
How is acces from the outside with this setup?
And I also have IDetect running whish needs tweaking also.
But this seems like a good way to start! I may give it a go. I wonder how I can make the transition of 35 Zwave devices better than it is with the current setup.
hjzwiers
I also see that you do not run from Zwave-js ....
- andreo
I connect from the outside using a VPN and I do not use any Zwave deviceshjzwiers wrote: Monday 31 July 2023 8:21 Wow, it seems as though you took care of domotics and nefit
Greetz Andre.
Greetz Andre.
hjzwiers
I now see that Zwave-js uses port 3000 and nefit also uses that poort, so i need to change this but I am wondering which one
The ZwaveJS one as that is not used by Domoticz and others. It is used by HomeAssistant (WebSocket integration)
- Marathon2010
- Domoticz version: 2025.2
I've implemented ZWaveJS2MQTT mid last year under docker. I'm using port 8091 to open control panel of Zwave. Does that help?hjzwiers wrote: Tuesday 01 August 2023 15:27 I now see that Zwave-js uses port 3000 and nefit also uses that poort, so i need to change this but I am wondering which one
Synology DS920+ DSM7 (Docker) | Integrations: Audio, Heating, Gas, Electricity, Water, Alarm, Car, Camera, Doorbell, Garage, Garbage, Washer | SW: Tasmota, DzVents, Pushbullet, Telegram | Plugins: UPS, GPSLogger, BatteryLevel, Hyundai KIA, Rhasspy
hjzwiers
Then why do I see port 3000 in every script?
As that is a default of ZwavejsUI for HomeAssistant integration? But not related to Domoticz docker so slightly off topic in this discussion.
You can use 3010:3000 to move the original 3000 to 3010 to get it out of Nefiteasy http server
