I love Domoticz for the flexibility and for Dzvents. I also use HA, the integrations are difficult to resist. Now I use both and I was trying to control HA device using Dzvents without MQTT (yet).
The following script allows direct control of a HA Device using REST API, maybe it is usefull for someone
timer = {'every minute'},
httpResponses = {'Light_Callback'},
logging = { level = domoticz.LOG_DEBUG,
marker = "Home assistant" },
local state = 'turn_on'
local pump = '{"entity_id": "switch.smart_plug_4"}'
if (item.isTimer) then
domoticz.log('Timer event')
domoticz.openURL({
url = 'http://192.168.1.232:8123/api/services/switch/' .. state,
headers = {['Authorization'] = 'Bearer eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJxxxxxxxxxxxxxxxxxjMxYWM4OTgxNzUzNzFmZDFhZiIsImlhdCI6MTY5MDU3NTAxMCwiZXhwIjoyMDA1OTM1MDEwfQ.LjsUi9oVJB6qXif4lMaDoIX540LGOSmCGXdKE968e6w'},
method = 'POST',
callback = 'Light_Callback',
postData = pump
if (item.isHTTPResponse) then
domoticz.log('HTTP reponse HA was ok')
if (item.statusCode == 200) and (item.isJSON) then
-- domoticz.log(item)
domoticz.log('Home assistant')
