Quatt Integration
Trumpske
Quatt Integration
For everyone with a Quatt Heatsourcepump see attachment for the Domoticz integration script, this script is made by @heinemancp.
Adjust the "local FQDN" with the IP address of your Quatt CiC.
Add a virtual dummy hardware named "Quatt Status" and add the following virtual sensors:
- Quatt Status - General Text
- Flow [m3/hr] - General Custom Sensor
- Quatt Temp OT room - Temp
- Ingestelde kamertemperatuur - Temp
- Water in [C] - Temp
- Water out [C] - Temp
- Supply out [C] - Temp
- Supply in [C] - Temp
Add the attached script to Domoticz under dzVents - Timer, name is Quatt and press "Save".
- Quatt Script.txt
- (6.13 KiB) Downloaded 205 times
heinemancp
- Domoticz version: 2020.1
Re: Quatt Integration
RPi 3B | Domoticz V2020.1 with Z-WAVE and ESP8266 plugins
- galadril
- Domoticz version: latest
Would be cool to also implement this as python plugin?
- galadril
Ok i've created a python plugin for this Quatt hybride heatpump
https://github.com/galadril/Domoticz-Quatt-Plugin
- Domoticz version: 2025.1
Thanks! I added it to the plugin list on wikigaladril wrote: Tuesday 17 October 2023 12:35 Ok i've created a python plugin for this Quatt hybride heatpump
- galadril
Sweet thanks
Trumpske
Quatt Power in, Quatt Power Out and COP have been added by McKameel, see below for the new code:
- Quatt Script V2 Hardware and Types.png (9.72 KiB) Viewed 5009 times
- Quatt Script v2.txt
- (6.73 KiB) Downloaded 158 times
- galadril
Trumpske wrote: Monday 23 October 2023 9:20 Quatt Power in, Quatt Power Out and COP have been added by McKameel, see below for the new code:
Thanks for the notification, i've also adjusted the python plugin to have these new devices
- galadril
Updated the plugin with new flowRateFiltered device added
- galadril
FYI Posted a new version of the Domoticz Quatt Python plugin
Contains more devices / data
