enphase envoy with (HTTP) interface
bldewit
- Domoticz version: Stable
Re: enphase envoy with (HTTP) interface
Hi, I added the hardware and checked that i have access to the production.json page, all ok. In my log i keep getting the No Session_id error:
Zonnepanelen platdak: Invalid data received! (no session_id)
Also tried a reboot after allowing Basic-auth, no effect.
What could be wrong?
Verstuurd vanaf mijn SM-T590 met Tapatalk
Running on rPi 3b (main) and rPi 2b (somfy), both RFLink
IthoRemote, Xiaomi Gateway, KAKU
TurboX
In the past, I have speak about watt production refresh interval issue (software D7).
I have set 60sec of interval request into the domoticz pluging, in the log all is ok (refresh value every 60sec).
The power consumption is well refresh every 60sec but not the power production (more 5-15min). The individual inverter is worst (min 15min).
In parallele I use Home Assistant which is connected to the same enphase gateway, the consumption and production are well refreshed every 60sec approx.
The graph below show the production from HA (lines) et Domoticz (dash). If i read https:/:IP/production.json, the watt production change very often. It seems that Domoticz doesn't read the correct variable or another .json. No?
Others things:
Why not reporting another values (like inline, voltage, ..) into Domoticz?
Moreover, I would prefer to have an additional device with only the watt of each individual inverter because it generates graphs ot the maximum power each days along a year (permit to detect an issue of production).
Others things:
- FireWizard
Hello @TurboX,
There has been a long discussion and I did several tests withe the Enphase Envoy_S.
Please read: https://github.com/domoticz/domoticz/issues/5377
If you can collect that data, you can easily create it yourself, either a script or Node-RED.
60 seconds is fine.In the past, I have speak about watt production refresh interval issue (software D7).
Obviously, you have the metered version of the Envoy. This data is available.The power consumption is well refresh every 60sec
Enphase says the following:but not the power production (more 5-15min)
So there is no need to poll the Envoy-S faster than every 5 minutesYour IQ Envoy polls your microinverters every 5 minutes and uploads those intervals to Enlighten every 15 minutes, give or take, depending on its WiFi connection speed and stability
Domoticz uses that URL.If i read https:/:IP/production.json, the watt production change very often. It seems that Domoticz doesn't read the correct variable or another .json. No?
What is "inline"? . What is the URL for "voltage"? I have never seen it.Why not reporting another values (like inline, voltage, ..) into Domoticz?
One device, containing the data of each individual inverter? This is not clear to me.Moreover, I would prefer to have an additional device with only the watt of each individual inverter because it generates graphs ot the maximum power each days along a year (permit to detect an issue of production).
TurboX
Hello @FireWizard and thank for your answer.
I have read the discussion of your link. I still don't understand why I can't have the production every 60sec. The gateway produce the data and 60sec is fine to avoid too many request and then reboot. If the plugin read the production.json every 60sec, I don't understand why the domoticz value of the power production (watt) is updated only every 10/15min.
My production.json is the following:
Under "production" wNow is the value which is not updated into domoticz (and Home Assistant yes).
Regarding the Voltage, I mean the rmsVoltage and by "Inline" to check if the system respond (detect system down or reboot).
About the additionals domoticz devices, I mean to associate a power device to each energy inverter. This is what I use from HA to send via MQTT autodiscovery which generates 2 device into domoticz : Energy and power (and automatiquely related, the same power is display on both domoticz device). One example: Type:Usage,electric
I don't know how to collect that data, the use of token is completely out of my capabilities (and perhaps I am not alone, why not add these power devices "just" by an option of the plugin?).
production
0
type "inverters"
activeCount 3
readingTime 1686766425
wNow 133
whLifetime 514857
1
type "eim"
activeCount 1
measurementType "production"
readingTime 1686766878
wNow 114.652
whLifetime 497523.002
varhLeadLifetime 2.012
varhLagLifetime 255499.637
vahLifetime 641277.6
rmsCurrent 0.641
rmsVoltage 232.009
reactPwr 49.412
apprntPwr 148.472
pwrFactor 0.71
whToday 3000.002
whLastSevenDays 24187.002
vahToday 3451.6
varhLeadToday 0.012
varhLagToday 1030.637
consumption
0
type "eim"
activeCount 1
measurementType "total-consumption"
wNow 195.001
whLifetime 3634871.996
varhLeadLifetime 1074997.624
varhLagLifetime 416938.662
vahLifetime 4146976.574
rmsCurrent 1.779
rmsVoltage 232.015
reactPwr -200.16
apprntPwr 412.696
pwrFactor 0.47
whToday 4841.996
whLastSevenDays 56647.996
vahToday 5493.574
varhLeadToday 2763.624
varhLagToday 1079.662
1
type "eim"
activeCount 1
measurementType "net-consumption"
wNow 80.349
whLifetime 3140830.161
varhLeadLifetime 1074995.612
varhLagLifetime 161439.025
rmsCurrent 1.137
rmsVoltage 232.022
reactPwr -150.748
apprntPwr 263.209
pwrFactor 0.33
whToday 0
whLastSevenDays 0
vahToday 0
varhLeadToday 0
varhLagToday 0
storage
0
type "acb"
activeCount 0
readingTime 0
wNow 0
whNow 0
state "idle"Regarding the Voltage, I mean the rmsVoltage and by "Inline" to check if the system respond (detect system down or reboot).
TurboX
I am not coder but I read this on the source code on Github (line 578):
I guess it read wNow into production/0 (inverter type) and not production/1 (eim type). Right?
If yes, my issue is here because under production/0 the wNow production is not real time refreshed while under production/1 the wNow is in real time.
Is it possible for me to change the domoticz code (where is located the .cpp file), juste for a test? I have a docker version just for testing, it would be perfect if I can change this value.
Json::Value reading = root["production"][0];
int musage = reading["wNow"].asInt();If yes, my issue is here because under production/0 the wNow production is not real time refreshed while under production/1 the wNow is in real time.
- gizmocuz
I have no production/1
Sure you are able to tweak the source / compile and test
https://www.domoticz.com/wiki/Build_Dom ... rom_source
"production": [
"type": "inverters",
"activeCount": 13,
"readingTime": 1687252655,
"wNow": 2817,
"whLifetime": 860793
"storage": [
"type": "acb",
"activeCount": 0,
"readingTime": 0,
"wNow": 0,
"whNow": 0,
"state": "idle"
}https://www.domoticz.com/wiki/Build_Dom ... rom_source
- gizmocuz
TurboX
Hello Gizmocuz,
Your production.json file is very light compare to mine. The plugin is based on your file?
I have read your link to compile by myself but this is too complicated for me (and require another raspberry).
- gizmocuz
You can compile on any system (debian/ubuntu or windows)
Can you post your production.json here?
TurboX
My production.json:
My production.json:
"production":[
"type":"inverters",
"activeCount":3,
"readingTime":1687238955,
"wNow":23,
"whLifetime":531878
"type":"eim",
"activeCount":1,
"measurementType":"production",
"readingTime":1687239239,
"wNow":28.008,
"whLifetime":514118.081,
"varhLeadLifetime":2.012,
"varhLagLifetime":262155.23,
"vahLifetime":661558.741,
"rmsCurrent":0.284,
"rmsVoltage":233.224,
"reactPwr":52.541,
"apprntPwr":66.08,
"pwrFactor":0.45,
"whToday":3.081,
"whLastSevenDays":23159.081,
"vahToday":324.741,
"varhLeadToday":0.012,
"varhLagToday":392.23,
"lines":[
"wNow":28.008,
"rmsCurrent":0.284,
"reactPwr":52.541,
"apprntPwr":66.08,
"pwrFactor":0.45,
"whToday":3.081,
"vahToday":324.741,
"consumption":[
"type":"eim",
"activeCount":1,
"measurementType":"total-consumption",
"wNow":234.095,
"whLifetime":3677800.427,
"varhLeadLifetime":1092887.378,
"varhLagLifetime":425695.606,
"vahLifetime":4194992.577,
"rmsCurrent":1.714,
"rmsVoltage":233.33,"reactPwr":-205.665,
"apprntPwr":399.928,
"pwrFactor":0.59,
"whToday":1487.427,
"whLastSevenDays":52403.427,
"vahToday":2499.577,
"varhLeadToday":1252.378,
"varhLagToday":394.606,
"lines":[
"wNow":234.095,
"rmsCurrent":1.714,
"pwrFactor":0.59,
"whToday":1487.427,
"type":"eim",
"activeCount":1,
"measurementType":"net-consumption",
"wNow":206.087,
"whLifetime":3167301.465,
"varhLeadLifetime":1092885.365,
"varhLagLifetime":163540.377,
"rmsCurrent":1.43,
"rmsVoltage":233.435,"reactPwr":-153.124,
"apprntPwr":332.636,
"pwrFactor":0.61,
"whToday":0,
"whLastSevenDays":0,
"vahToday":0,
"varhLeadToday":0,
"varhLagToday":0,
"lines":[
"wNow":206.087,
"rmsCurrent":1.43,
"pwrFactor":0.61,
"whToday":0,
"vahToday":0,
"varhLeadToday":0,
"varhLagToday":0
"storage":[
"type":"acb",
"activeCount":0,
"readingTime":0,
"wNow":0,
"whNow":0,
"state":"idle"
- FireWizard
Hello @TurboX and @gizmocuz.
The difference in production.json is caused by the fact that @gizmocuz has a Enphase Envoy S and @TurboX has a Enphse Envoy S metered.
This last version gives you also information about the consumed energy, taken from the grid
I have exactly the same as @gizmocuz. I do not need a metered version, as I get that data from my P1 Smartmeter
TurboX
Hello @FireWizard,
Yes, you are right, I have the metered version.
I was thinking that only the Envoy S metered was able to measure production/consumption and report it.
- gizmocuz
I am more than happy to check if it's a metered version.
But, I noticed that the value for 'whLifetime' is also different... how is this possible?
production[0] = "whLifetime":531878
production[1] = "whLifetime":514118.081
So it is quite a lot lower....
Do we pick the one from production[0] ? or if there is a production[1] we use this one?
- FireWizard
Hello @gizmocuz,
You asked:
https://enphase.com/en-ph/download/ct-b ... ices-en-au
If I read the data from @TurboX, I guess that @TurboX has 3 Enphase inverters installed in a Single Phase system.
@TurboX: Can you confirm?
You can either connect a CT in the "Production" circuits or in the "Consumption" circuits or both.
Data is given as a total and in an array of object line for all 3 phases, L1, L2 and L3.
I do not know where the characters eim stands for. Someone?
Inverters is clear and as far as I understand "acb" stands for AC Battery. (Although AC batteries technically do not exist)
Consumption is presented as both "total-consumption" and "net-consumption".
I do not know the difference between those two. Is it a matter of connections or configuration?
But perhaps @turboX can answer.
It is quite easy to check, whether you have an Envoy-S or an Envoy-S metered, by looking to the Envoy and see if you have CT's installed.
If so, then http://IP-address/production.json will give you the details.
If you have the following:
Then you have the standard version, what I expect.
You asked:
The data, indicated by "eim" is the data from the CT (Current Transformer) devices. It depends on how they are connected.Do we pick the one from production[0] ? or if there is a production[1] we use this one?
production
0
type "inverters"
activeCount 22
readingTime 1687876481
wNow 2884
whLifetime 8985367
storage
0
type "acb"
activeCount 0
readingTime 0
wNow 0
whNow 0
state "idle"Regards
TurboX
Yes I confirm, I have 3 Enphase micro inverter (IQ7A) with 2 Current Transformer on total production and the other on the net consumption (from Enedis, my energy provider). My total consumption is the whole of energy consumed by the house (produced and imported).
@gizmocuz I don't know why there is a difference between production[0] = "whLifetime":531878 and production[1] = "whLifetime":514118.081 but Home Assitant send to domoticz the production[1] value to Domoticz and I have Domoticz-Linky plugin (official data from my energy provider) and I match perfectly. Perhaps production[0] is an estimation from micro-inverter and production[1] is more real?
In parallele I have compiled domoticz from source (very new for me using virtual debian on synology, not so easy but very interesting) and I have juste modify the line 578 with production[1] and now the production seems updated following pooling rate
. I will make more longer test to confirm that.
If it works, can we add a parameter into the plugin in order to chose to Envoy gateway (metered or not) or check if production[1] is available and if yes use it? (and why not add voltage RMS value?)
TurboX
It definitely works with the modification.
Line: data from actual Domoticz plugin with 30s polling rate
Dash: data from Home Assistant plugin (polling rate not configurable)
Dot: data from modified Domoticz plugin with 30s polling rate
- gizmocuz
Great that you can compile now!
Could you replace the parseProduction function with:
This should automatically detect if you have a metered envoy and that it is also measuring (maybe you can install the metered version without CT clamps?)
I think the value from root["production"][0] should be accurate.... hope so, as I don't have the metered version)
void EnphaseAPI::parseProduction(const Json::Value& root)
if (!IsItSunny())
m_sql.safe_query(
"UPDATE DeviceStatus SET LastUpdate='%s' WHERE (HardwareID==%d)", TimeToString(nullptr, TF_DateTime).c_str(), m_HwdID);
return;
if (root["production"].empty() == true)
//No production details available
return;
size_t sproduction = root["production"].size();
bool bIsMeteredVersion = (sproduction > 1);
if (bIsMeteredVersion)
bIsMeteredVersion = root["production"][1]["whLifetime"].asInt() != 0;
Json::Value reading = (bIsMeteredVersion) ? root["production"][1] : root["production"][0];
int mtotal = reading["whLifetime"].asInt();
SendKwhMeter(m_HwdID, 1, 255, musage, mtotal / 1000.0, "Enphase kWh Production");
TurboX
I don't know if it's my paste the cause:
<pre>[ 17%] <span style="color:#26A269">Building CXX object CMakeFiles/domoticz.dir/hardware/EnphaseAPI.cpp.o</span>
<b>c++:</b> <span style="color:#C01C28"><b>fatal error: </b></span>Processus arrêté signal terminated program cc1plus
compilation terminated.
make[2]: *** [CMakeFiles/domoticz.dir/build.make:1437 : CMakeFiles/domoticz.dir/hardware/EnphaseAPI.cpp.o] Erreur 1
make[1]: *** [CMakeFiles/Makefile2:384 : CMakeFiles/domoticz.dir/all] Erreur 2
make: *** [Makefile:156 : all] Erreur 2
</pre>-
TurboX
Sorry, it was probably me the problem
. I succeed to compile again.
It works but is it sure that the old domoticz.sh is erase and rewrited by the "make" command ? Or to be sure, it is better to restart from scratch (remove dev-domoticz folder)?
- gizmocuz
Thanks for verifying. I will make the patch/commit/beta
domoticz.sh is not overwritten bij de make command
