dzVents Reboot Raspberry Pi
Piacco
Post by Piacco »
My raspberry has memory leakage, so I want to reboot my raspberry pi if the memory exceeds the 80%, is this possible with dzVents?
I tried this, but this is not working.
 if memory.percentage > 80 then
     dz.openURL(
                url = "http://192.168.1.15:8181/json.htm?type=command&param=system_reboot",
                method = 'POST',
2023-06-11 14:30:00.241 Error: Error opening url: http://192.168.1.15:8181/json.htm?type=command&param=system_reboot
I know that i have to solve the memory leakage ;)
Number8
Domoticz version: 2022.1
Re: dzVents Reboot Raspberry Pi
Post by Number8 »
Either you are not using the async http method and the code should be
dz.openURL("http://192.168.1.15:8181/json.htm?type=command&param=system_reboot")
or is you want to use the async way then you should set a callback
See doc https://www.domoticz.com/wiki/DzVents:_ ... _scripting
If you go the async way, use GET in that case (no POST data is needed)
Are you sure you web server port is set on 8181?
Debian buster on NUC and three RPi with buster.
Piacco
Post by Piacco »
Yes Domoticz Port is on 8181 :D
I get the same error with the dz.openURL command.
2023-06-11 20:37:00.447 Error: Error opening url: http://192.168.1.15:8181/json.htm?type= ... tem_reboot
willemd
Domoticz version: 2024.1
Post by willemd »
A guess: Maybe user domoticz is not allowed to do the reboot? You need to be superuser?
heggink
Domoticz version: 12451
Post by heggink »
Use monit. It's really good at monitoring domoticz in all aspects. There should be a wiki
DASHTICZ 🙃
P1 meter & solar panel
Kedi
Post by Kedi »
Perhaps use:
 dz.openURL("http://127.0.0.1:8181/json.htm?type=command&param=system_reboot")
and make sure that 127.0.0.1 is set in "Thrusted Network" in Setup -> Settings -> Security
