Alexa voice control for Tasmota devices
Alexa, Google Home and Siri
MikeF
Domoticz version: V2022.2
Post by MikeF »
There is a simple way to achieve Alexa voice control of Tasmota-flashed devices, such as Sonoff and Shelly switches / plugs.
Within the web GUI for a Tasmota device, head to Configuration > Configuration Other, and select 'Belkin WeMo' under Emulation. Give the device a useful friendly name, e.g., 'Porch' in the example below, and click 'Save'.
Then ask Alexa to discover devices: 'Alexa, discover devices'. Once Alexa answers that she (it?) has discovered your device, you can then say (e.g.): 'Alexa, turn Porch on', or 'Alexa, turn Porch off'.
If your Tasmota device is linked to Domoticz, then its status will be updated in the Domoticz web GUI.
pizzulicchio
Re: Alexa voice control for Tasmota devices
Post by pizzulicchio »
all is working perfectly using your suggestion, but, if I'm using a sonoff TH with has temperature and humidity sensor, how i possible to query temp and humidity status to alexa. I think that it's possible only to add device with "switch or on/off " action. isn't true?
