BUVA QStream 2, with webservice (wifi module)
elmardam
Post by elmardam »
hopefully some of you can help me out, since i dont have any scipting skills.. and im really struggling..
So, i have a Buva Qstream 2 (mechanical ventilation), which has a wifi module and running a webservice. mainly for the app for my phone (the buva qstream app)
You can control airflow with the app, add schedules etc. It also measures air quality.
I want to create a new graph for the airquality, when i browse to: <ipadres.\AQI i get:
"Value": "5"
in response.. But what ever i try... i can't get this into a graph.. i would really appreciate it, if one of you can put me in the right directions.
If any of you also have this mechanical ventilation, you might be ingerested in this node red implementation:
https://flows.nodered.org/flow/8b17644c ... 3422f48071
Kind Regards, Elmar
elmardam
Re: BUVA QStream 2, with webservice (wifi module)
Post by elmardam »
import requests
url_website = 'http://192.168.1.229/AQI' # URL van de website die de waarde bevat
url_domoticz = 'http://192.168.1.100:81/json.htm' # URL van Domoticz API
response = requests.get(url_website)
if response.status_code == 200:
value = response.json()['Value'] # Pas dit aan op basis van de werkelijke JSON-structuur
parameters = {
'type': 'command',
'param': 'udevice',
'idx': '1248',
'nvalue': 0,
'svalue': str(value)
response_domoticz = requests.get(url_domoticz, params=parameters)
if response_domoticz.status_code == 200:
print("Waarde succesvol toegevoegd aan de Domoticz-grafiek.")
else:
print("Er is een probleem opgetreden bij het toevoegen van de waarde aan de Domoticz-grafiek.")
else:
print("Kan de waarde niet ophalen van de website.")
