15326 - [WebServer] Depricated RType Topic is solved
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Version: xxxx
Platform: xxxx
Description:
- a3vd
Re: 15326 - [WebServer] Depricated RType
I understand that its a depricated issue from Json, but which api is it ? i switched off all my hardware one by one but can't figure out
which one is giving the problem.
The message in the log is :
2023-06-07 09:36:19.629 Status: [WebServer] Depricated RType (devices) for API request. Please use correct API Command!
Version: 2023.1 (build 15335)
Build Hash: 83bfca4d7
Compile Date: 2023-06-07 08:24:29
dzVents Version: 3.1.8
Python Version: 3.9.2 (default, Mar 12 2021, 04:06:34) [GCC 10.2.1 20210110]
Raspberry 3+ / 4
P1 smartcable / RFXtrx433 FW 182 / Several 1 wire Temp Sensors /DHT12/Conbee2 (zigbee)
Several Kaku switches/ Weather Underground / Hue
- Domoticz version: 2024.7
You have to be sure you have cleared your browser cache. Using the normal Domoticz interface and hardware should not give issues.a3vd wrote: ↑Wednesday 07 June 2023 9:39 I understand that its a depricated issue from Json, but which api is it ? i switched off all my hardware one by one but can't figure out
So propably you use another interface like an app, dashticz etc. Or an external script that connects to domoticz.
- jvdz
- Domoticz version: 4.107
Maybe updating the console message to contain the remote ip address and username would help to determine the source?
Something like? (untested):
_log.Log(LOG_STATUS, "[WebServer] %s-%s: Depricated RType (%s) for API request. Please use correct API Command!", session.remote_host.c_str(), session.username.c_str(), rtype.c_str());
- heggink
- Domoticz version: 12451
That would be really helpful indeed. I managed to clear most of the messages except for one and I can't, for the life of me, figure out where it comes from...jvdz wrote: ↑Wednesday 07 June 2023 11:28 Maybe updating the console message to contain the remote ip address and username would help to determine the source?
Something like? (untested):Code: Select all
DASHTICZ 🙃
P1 meter & solar panel
DASHTICZ 🙃
- kiddigital
Just enable the `webserver` debug flag and you will see a lot more details from the webserver.heggink wrote:That would be really helpful indeed. I managed to clear most of the messages except for one and I can't, for the life of me, figure out where it comes from...jvdz wrote: ↑Wednesday 07 June 2023 11:28 Maybe updating the console message to contain the remote ip address and username would help to determine the source?
- heggink
Excellent so that helped. FOund the culprit which was unexpected: type=setused throws the warning but I didn';t see that mentioned in the wiki.kiddigital wrote: ↑Wednesday 07 June 2023 21:37Just enable the `webserver` debug flag and you will see a lot more details from the webserver.heggink wrote:That would be really helpful indeed. I managed to clear most of the messages except for one and I can't, for the life of me, figure out where it comes from...jvdz wrote: ↑Wednesday 07 June 2023 11:28 Maybe updating the console message to contain the remote ip address and username would help to determine the source?
What would be the correct syntax?
NVM, found it: type=command¶m=setused
Many thanks!!
DASHTICZ 🙃
DASHTICZ 🙃
- heggink
For those using the machinon theme, there are a couple of changes to be made in custom.js:heggink wrote: ↑Wednesday 07 June 2023 22:26Excellent so that helped. FOund the culprit which was unexpected: type=setused throws the warning but I didn';t see that mentioned in the wiki.kiddigital wrote: ↑Wednesday 07 June 2023 21:37Just enable the `webserver` debug flag and you will see a lot more details from the webserver.heggink wrote:
Many thanks!!
fetch('json.htm?type=command¶m=getsettings', {
if (settings.url.startsWith("json.htm?type=command¶m=getdevices") || settings.url.startsWith("json.htm?type=command¶m=getscenes")) {
} else if (settings.url.startsWith("json.htm?type=command¶m=switchscene")) {
DASHTICZ 🙃
DASHTICZ 🙃
- kiddigital
Beta 15342 contains a few small API ‘backwards’ compatibility changes. A few more old RTypes are now still working (scene/plan/graph).
See https://github.com/domoticz/domoticz/c ... 8b640a6ea3
Also the status message shows if (and via which command) it worked or was ignored and where the request came from (IP address).
- a3vd
[/quote]
[/quote]
Off course i cleared the cache, and domoticz is still working fine but with the latest beta (15342) i finally can see where the api problem is,
it is in de toon plugin. Now i have to dig in the source to find out where the problem is, and find some time for it
The log message is now much more clearer :
[WebServer] Depricated RType (devices) for API request. Handled via fallback (getdevices), please use correct API Command! (xxx.xxx.xxx.xxx)
[/quote]
Raspberry 3+ / 4
- EdwinK
- Domoticz version: BETA
It's. coming from my macBook. Updated the machinon and the machinon-beta theme to the latest version and it seems the errors are gone now.kiddigital wrote: ↑Thursday 08 June 2023 21:17
so… in my case after trying lots of the things suggested earlier in this post, on my rpi 4 with no luck, i decided to upgrade another domoticz server i have running on a pi zero to see if that displayed the same problem (as this is not running as many apps in the back ground as my rpi4 setup)
The pi zero server doesnt display the [WebServer] Depricated RType (devices) for API request error.
I started looking at the differences between the two devices and then remembered that the rpi4 has a touchscreen screen attached to it which runs a custom frontpage allowing me to control devices from that rather than the domoticz interface itself.
This is running as a different user, with the browser opening automatically on startup in kiosk mode.
Disabling this from automatically opening the browser, fixed the issue, so the custom front page is clearly using api calls that are no longer supported.
there are 3 commands in that page which could possibly be causing the issue.
If any one can see how to modify these to follow the new requirements, i would be grateful of any help.
var jurl=$.domoticzurl+"/json.htm?type=devices&plan="+$.roomplan+"&jsoncallback=?";
$(document).ready(function() {
$.roomplan=0; // define roomplan in Domoticz and create items below.
$.domoticzurl="http://192.168.1.x:8080";
//format: idx, value, label, description, [override css], [alarm value]
url: "http://192.168.1.x:8080/json.htm?type=c ... witchlight" + "&idx=" + idx + "&switchcmd=" + switchcmd + "&level=0"
I hope this is useful to some people to maybe at least to remind them to be conscious of other devices that maybe causing these issues..
thanks
Newpond
thanks
Newpond
- kiddigital
That one has to change ‘type=command¶m=getdevices’newpond wrote:…
thanks
Newpond
You can remove the ‘&jsoncallback=?’ as that is also not supported anymore.
The others should be ok
@kiddigital that worked perfectly thank you so much for the help (and the fast response).
much appreciated
Bedankt!!!!!
Newpond
much appreciated
Bedankt!!!!!
Newpond
Hello,kiddigital wrote: ↑Wednesday 07 June 2023 21:37Just enable the `webserver` debug flag and you will see a lot more details from the webserver.heggink wrote:That would be really helpful indeed. I managed to clear most of the messages except for one and I can't, for the life of me, figure out where it comes from...jvdz wrote: ↑Wednesday 07 June 2023 11:28 Maybe updating the console message to contain the remote ip address and username would help to determine the source?
How can I enable this debug flag ? Because I didn't find where come my errors....
Thanks a lot.
- wnaves
- Domoticz version: 2023.2
Just to add to this conversation as i did not find any references to this issue yet.
I'm running the Android mobile app version 0 . 2 . 358 (9328) and found that as the source device that generate these errors as well.
Any thoughts on the mobile version and if they could be affected ?
- jvdz
Any external App/Script/WebFrontend will use the standard API calls to retrieve the information from Domoticz so Yes, the android app will probably mostly still work but will trigger these warnings in the log each time it does one of the modified API calls.
- wnaves
And is the mobile app going to be updated as well to make use of these new api calling method's ?
The issue is brought to the attention of the app author https://github.com/domoticz/domoticz-android/issues/692
For now most likely the app should work, you only have these messages. The app will probably change only after the current beta is promoted to stable else the app will not work on current stable.
- jvdz
Which is an issue when there is no backward compatibility build into the APP since a hard cut change would mean everybody needs to upgrade Domoticz immediately when the app changes!
To avoid putting the burden onto the developers of APPS and other external processes and hard cutoffs, these "breaking change" really should be implemented over 2 releases:
- First release (now) the new and old format API should work without it triggering all these errors in the logfile and informing everyone of start making the changes to the APIs in their external APPs/Fornt-ends/Batch processes.
- Next release (Beta&Prod after current Beta went into production) the new and old format API should work, but now implement the errors in the logfile so people know this is really happening.
- 2nd Next release (Beta&Prod) stop support for old API format.
Just my 2 cents.
I agree (but have no influence on this)
