Since this last update I get the above messages. I don't have any camera's installed at the moment.2023-06-01 23:12:13.626 Status: [WebServer] Depricated RType (cameras) for API request. Please use correct API Command!
2023-06-01 23:16:04.417 Status: [WebServer] Depricated RType (devices) for API request. Please use correct API Command!
15326 - [WebServer] Depricated RType Topic is solved
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Version: xxxx
Platform: xxxx
Description:
- EdwinK
- Domoticz version: BETA
- Domoticz version: 2024.7
Re: 15326 - [WebServer] Depricated RType
Is there something else running or accessing Domoticz on the same time? That would help debugging....
- EdwinK
No, nothing else running at the same time.
Same messages here.... (only about devices, not cameras)
2023-06-02 09:02:00.900 Status: [WebServer] Depricated RType (devices) for API request. Please use correct API Command!
2023-06-02 09:02:00.903 Status: [WebServer] Depricated RType (devices) for API request. Please use correct API Command!
2023-06-02 09:02:00.905 Status: [WebServer] Depricated RType (devices) for API request. Please use correct API Command!
2023-06-02 09:02:00.909 Status: [WebServer] Depricated RType (devices) for API request. Please use correct API Command!
2023-06-02 09:02:00.921 Status: [WebServer] Depricated RType (devices) for API request. Please use correct API Command!
2023-06-02 09:02:00.925 Status: [WebServer] Depricated RType (devices) for API request. Please use correct API Command!
2023-06-02 09:02:00.933 Status: [WebServer] Depricated RType (devices) for API request. Please use correct API Command!
2023-06-02 09:02:00.941 Status: [WebServer] Depricated RType (devices) for API request. Please use correct API Command!
2023-06-02 09:02:00.949 Status: [WebServer] Depricated RType (devices) for API request. Please use correct API Command!
2023-06-02 09:02:00.952 Status: [WebServer] Depricated RType (devices) for API request. Please use correct API Command!
2023-06-02 09:02:00.954 Status: [WebServer] Depricated RType (devices) for API request. Please use correct API Command!
2023-06-02 09:02:00.958 Status: [WebServer] Depricated RType (devices) for API request. Please use correct API Command!
2023-06-02 09:02:01.189 Status: [WebServer] Depricated RType (devices) for API request. Please use correct API Command!
2023-06-02 09:03:01.015 Status: [WebServer] Depricated RType (devices) for API request. Please use correct API Command!
2023-06-02 09:03:01.029 Status: [WebServer] Depricated RType (devices) for API request. Please use correct API Command!
2023-06-02 09:03:01.040 Status: [WebServer] Depricated RType (devices) for API request. Please use correct API Command!
2023-06-02 09:03:01.065 Status: [WebServer] Depricated RType (devices) for API request. Please use correct API Command!
2023-06-02 09:03:01.069 Status: [WebServer] Depricated RType (devices) for API request. Please use correct API Command!
2023-06-02 09:03:01.129 Status: [WebServer] Depricated RType (devices) for API request. Please use correct API Command!
2023-06-02 09:03:01.151 Status: [WebServer] Depricated RType (devices) for API request. Please use correct API Command!
2023-06-02 09:03:01.165 Status: [WebServer] Depricated RType (devices) for API request. Please use correct API Command!
2023-06-02 09:03:01.174 Status: [WebServer] Depricated RType (devices) for API request. Please use correct API Command!
2023-06-02 09:03:01.182 Status: [WebServer] Depricated RType (devices) for API request. Please use correct API Command!
2023-06-02 09:03:01.193 Status: [WebServer] Depricated RType (devices) for API request. Please use correct API Command!
2023-06-02 09:03:01.213 Status: [WebServer] Depricated RType (devices) for API request. Please use correct API Command!
2023-06-02 09:03:01.216 Status: [WebServer] Depricated RType (devices) for API request. Please use correct API Command!
Same error occurs here on build 15326 when doing a request on the API/JSON. In my case I'm doing a GET on the historic data: https://www.domoticz.com/wiki/Domoticz_ ... 7s#History
Be sure you cleared your browser cache as a lot of javascript files have been modified in this latest beta version!
I tested it by doing a GET-request with Postman, same error: [WebServer] Depricated RType (graph) for API request. Please use correct API Command!
I don't see that has anything to do with cache in my browser?
That is correct in your specific case, only to be sure browser cache is not the source of these log entries.
Also for the other users that have similar log entries but say not to use API calls (but do when using the browser).
In the change https://github.com/domoticz/domoticz/pull/5697/files I see the API call
/json.htm?type=graph&...
/json.htm?type=command¶m=graph&
- gizmocuz
For external API queries, RType queries have been replaced by normal queries.
We might need to update the wiki for these left overs.
The user interface commands (web gui) have been modified
I changed all my scripts (104):
/json.htm?type=devices
/json.htm?type=command¶m=getdevices
and
thanks!Joep123 wrote: ↑Friday 02 June 2023 19:55I changed all my scripts (104):
intoCode: Select all
and
The messages about "Depricated RType" don't appear anymoreCode: Select all
thanks! I updated the API Command, now it's working again.waltervl wrote: ↑Friday 02 June 2023 11:47In the change https://github.com/domoticz/domoticz/pull/5697/files I see the API callhas been changed toCode: Select all
In your case it looks to be a browser cache issue, please clear it. If it does not disappear it should be triggered to a User action. Please check what you are doing with Domoticz if the message appears.EdwinK wrote: ↑Thursday 01 June 2023 23:18Since this last update I get the above messages. I don't have any camera's installed at the moment.2023-06-01 23:12:13.626 Status: [WebServer] Depricated RType (cameras) for API request. Please use correct API Command!
- Domoticz version: 15330
I had such a problem after update 15326. In addition, both applications on the phone (old and new with an annual subscription) stopped working - they cannot connect - an error (Error getting http data!). For any request through the site or the site "controlicz"com" - I get errors in the logs described above in the posts. And there is the same error in the logs when I try to see the voltage or temperature graph in the application on the phone. At the same time, the graph does not appear on the phone (the page in the application just twitches to the side).
- EdwinK
Had cleared the browser cache, but still there. Even cleared out browsing history cached images with time range 'all time'. Treid switching browser, but still this
Still no luck. Giving up right now. It doesn't really hurt anything, just filling the logs with this error.
Also turned off all the events I had. So the only thing I could think of is the Open Meteo flow.2023-06-04 09:11:12.836 Status: [WebServer] Depricated RType (devices) for API request. Please use correct API Command!
2023-06-04 09:11:17.837 Status: [WebServer] Depricated RType (devices) for API request. Please use correct API Command!
2023-06-04 09:11:17.885 Status: [WebServer] Depricated RType (settings) for API request. Please use correct API Command!
2023-06-04 09:11:18.491 Status: [WebServer] Depricated RType (cameras) for API request. Please use correct API Command!
and
any idea whats new command for
/json.htm?type=schedules&filter=device
old one isnt working...
Just faced the same issue...
I'm using Monitor (https://github.com/vil1driver/monitor) as custom page , and was working fine until this damned beta update...
Why are they breaking this API ?
Is that a mistake or will it be it at final ?
My problem is on Devices and Scenes... if there is an easy way to fix Monitor I'm in !
- kiddigital
No mistake, matter of cleaning up old inconsistencies.
Should be easy to fix. Maybe ask the either the author to fix it for you or do it yourself.
Look for the API calls that do not start with `type=command`.
Example `type=devices` should become `type=command¶m=getdevices`
Could be your theme as some themes have Camera suppport added. Do you use a default theme or a custom one?EdwinK wrote: ↑Sunday 04 June 2023 8:48 Had cleared the browser cache, but still there. Even cleared out browsing history cached images with time range 'all time'. Treid switching browser, but still this
