Change Alert Icon set
athoopen
Domoticz version: 2025.2
Post by athoopen »
All,
I created a pollen, migraine and rheumatism device. I use 3 Alert virtual devices for this. This Alert device has 5 levels (0...4) with associated Icons. I like to create a specific icon set for the pollen, migraine and rheumatism devices. I created the icons (0...4) and the general one, created the icon.txt file, put it in a zip and uploaded. However, after I push the Upload button, I get the error: "No icon definition file found."
I created successfully many On/Off icon sets, but what is the syntax for the icon.txt file in case of an "Alert". Currently, it is:
Migraine;Migraine;Migraine;Migraine;Migraine;Migraine
Which was my best guess (name for all the states (0..4) plus the general name).
Anybody knows the syntax of the icon.txt file incase it's not On/Off
TIA!!!
Cheers,
Arjan
Rp3 Using : RFXCom, LaCrosse, KNMI, Remeha, TinyTuya, zigbee and a few others
athoopen
Re: Change Alert Icon set
Post by athoopen »
I debugged the database and found that the table customimages holds all the custom images you uploaded. It shows that there are only two states, On and OFF. Therefore, I conclude that I cannot create Icon sets which holds more than two states ..... that's a pity.
I'm stuck, I think I will enter a change request, or do you have other options/ideas ...
Cheers,
Arjan
Jan Jansen
Domoticz version: Stable
Post by Jan Jansen »
athoopen wrote: Sunday 14 May 2023 19:28
I am interested in a pollen device. Will you explain to me how you achieved that? Do you want to share the script used?
Thanks in advance.
athoopen
Post by athoopen »
No Problem Jan!!
First create a dummy virtual switch and create there a virutal switch of type "Warning" (Waarschuwing) with an approrpiate name (Hooikoorts???)
On the pi create the follwoing scirpt in /usr/local/bin:
# Naslag:
# https://www.domoticz.com/forum/viewtopic.php?t=33518
# https://pon.fr/dzvents-alerte-pollens/
# https://www.pollens.fr/
# vars to be changed
JSONFile='/tmp/HooikoortsJSONFile.json' # change to full qualified filename
domoticzPort=8080                       # change to your domoticz port number
domoticzIP=127.0.0.1                    # change to domoticz IP (keep 127.0.0.1 if local)
# Keep this the same as the trigger of the dzVents script
customEvent=JSONHooikoortsFileReady
# Vars needed for weeronline.nl
CONTINENT=Europa
COUNTRY=Nederland
CITY=Almere
WTFNUMBER=4058927
HOOIKOORTSURL=https://www.weeronline.nl/${CONTINENT}/${COUNTRY}/${CITY}/${WTFNUMBER}/hooikoorts
PAGESOURCEFULL=/tmp/hooikoortsfullpage$$
PAGESOURCE=/tmp/hooikoortspage$$
# Make no changes below this point!
# get the page
lynx -dump ${HOOIKOORTSURL} > ${PAGESOURCEFULL}
# Strip all data we don't need
sed -e '1,20d' \
    -e '155,$d' \
    -e 's/^   //' \
    -e 's/^Grote kans op klachten als je gevoelig bent voor: //' \
    -e '/^zo$/d' \
    -e '/^ma$/d' \
    -e '/^di$/d' \
    -e '/^wo$/d' \
    -e '/^do$/d' \
    -e '/^vr$/d' \
    -e '/^za$/d' \
    -e 's/health_hayfever_//' \
    -e 's/Zeer klein/0/' \
    -e 's/Klein/1/' \
    -e 's/Matig/2/' \
    -e 's/Groot/3/' \
    -e 's/Zeer groot/4/' \
    ${PAGESOURCEFULL} > ${PAGESOURCE}
# The json  file has a more or less fixed header
JSONHEADER="{\"countyName\":\"${CITY}\",\"countyNumber\":\"0\",\"risks\":["
# The jsone end can already be computed
GENERALRISKLEVEL=$(sed -e '1!d' ${PAGESOURCE})
GENERALRISKTEXT=$(sed -e '2!d' ${PAGESOURCE})
JSONEND="],\"riskLevel\":${GENERALRISKLEVEL}}"
# Write the header
echo -n ${JSONHEADER} > ${JSONFile}
# Process the captured page
while read LINE
do
  case "${LINE}" in
	  "Bomen")
		  # This is the first we process, therefore it does not start with a comma
		  JSONTEXT="{\"pollenName\":\"${LINE}\",\"level\":"
		  read VALUE
		  JSONTEXT2="${VALUE}}"
		  # read the values for the next 4 days. Currenly not used
		  read DUMMY; read DUMMY ; read DUMMY ; read DUMMY
	  "Grassen en kruiden"| "Ambrosia"| "Grassen"| "Bijvoet"| "Brandnetel"| "Weegbree"| "Rogge"| "Zuring"|\
	  "Els"| "Es"| "Beuk"| "Berk"| "Cipres"| "Iep"| "Hazelaar"| "Eik"| "Populier"| "Tamme Kastanje"| "Wilg")
		  # This is NOT the first we process, therefore it DOES start with a comma
		  JSONTEXT=",{\"pollenName\":\"${LINE}\",\"level\":"
		  read VALUE
          *) echo WTF what is ${LINE} >>/dev/null
		  # There is nothing to output
		  JSONTEXT=""
		  JSONTEXT2=""
  esac
  # Write out the data
  echo -n ${JSONTEXT}${JSONTEXT2} >> ${JSONFile}
done < ${PAGESOURCE}
# Write the footer
echo -n ${JSONEND} >> ${JSONFile}
# Clean up
rm -f ${PAGESOURCEFULL} ${PAGESOURCE}
# signal Domoticz (dzVents)
#echo curl "http://$domoticzIP:$domoticzPort/json.htm?type=command&param=customevent&event=$customEvent&data=$JSONFile"
curl "http://$domoticzIP:$domoticzPort/json.htm?type=command&param=customevent&event=$customEvent&data=$JSONFile" 2>/dev/null 1>/dev/null
exit 0
Add the following line to the crontab on your pi
03 * * * * /usr/local/bin/hooikoorts
In Domoticz create a dzEvents (Timer) script). Replace the content of this with the following:
    local scriptName = 'Hooikoorts'
    local scriptVersion = '1.0'
    local alert_device = 1921  -- naam of idx van het apparaat (virtueel-> waarschuwing)
    local risques = {
                    -- "Bomen", -- algemeen, niet gebruiken
                    "Els",
                    "Es",
                    "Beuk",
                    "Berk",
                    "Cipres",
                    "Iep",
                    "Hazelaar",
                    "Eik",
                    "Populier",
                    "Tamme Kastanje",
                    "Wilg",
                    -- "Grassen en kruiden", -- algemeen, niet gebruiken
                    "Ambrosia",
                    "Grassen",
                    "Bijvoet",
                    "Brandnetel",
                    "Weegbree",
                    "Rogge",
                    "Zuring",
    on =
        customEvents =
            'JSONHooikoortsFileReady',
    logging = {
                level  = domoticz.LOG_DEBUG, -- options: LOG_INFO, LOG_ERROR, LOG_MODULE_EXEC_INFO
                marker = scriptName..' v'..scriptVersion
    data = {alertePollens = {initial = {} }, -- Keep a copy of last json just in case
    local function readFile(f)
        local file = io.open (f, 'r') -- open file in read mode
        local data =  file:read('*a')  -- read all
        file:close()
        return data
    -- Read the file
    local json = domoticz.utils.fromJSON(readFile(item.data))
    -- Do we actually have data?
    if #item.data > 0 then
        domoticz.log("We have new accurate data.",domoticz.LOG_ERROR)
        domoticz.data.alertePollens = json
        rt = json
        domoticz.log("Problem with response from Pollens (no data) using data from earlier run",domoticz.LOG_ERROR)
        rt  = domoticz.data.alertePollens                        -- json empty. Get last valid from domoticz.data
        if #rt < 1 then                                         -- No valid data in domoticz.data either
            domoticz.log("No previous data. are Pollens url ok?",domoticz.LOG_ERROR)
            return false
    --Process the json file
    local niveau1, niveau2, niveau3, niveau4, niveau5, text = '', '', '', '', '', ''
    local riskLevel = rt.riskLevel -- this is the general risk level as given by weeronline
    for k, risque in pairs(risques) do
        for k, pollens in pairs(rt.risks) do
            if pollens.pollenName == risque and pollens.level == 4 then niveau5 = niveau5.. " ".. pollens.pollenName.."," end
            if pollens.pollenName == risque and pollens.level == 3 then niveau4 = niveau4.. " ".. pollens.pollenName.."," end
            if pollens.pollenName == risque and pollens.level == 2 then niveau3 = niveau3.. " ".. pollens.pollenName.."," end
            if pollens.pollenName == risque and pollens.level == 1 then niveau2 = niveau2.. " ".. pollens.pollenName.."," end
            if pollens.pollenName == risque and pollens.level == 0 then niveau1 = niveau1.. " ".. pollens.pollenName.."," end
    if          niveau5 ~= '' then text, riskLevel = niveau5, 4
        elseif  niveau4 ~= '' then text, riskLevel = niveau4, 3
        elseif  niveau3 ~= '' then text, riskLevel = niveau3, 2
        elseif  niveau2 ~= '' then text, riskLevel = niveau2, 1
        elseif  niveau1 ~= '' then text, riskLevel = niveau1, 1
        else                       text, riskLevel = "Geen Alert", 0
    text = string.gsub (text, ",$", "") -- remove the "," at the end
    local Kans
    if riskLevel == 4 then Kans="Zeer groot" end
    if riskLevel == 3 then Kans="Groot" end
    if riskLevel == 2 then Kans="Matig" end
    if riskLevel == 1 then Kans="Klein" end
    if riskLevel == 0 then Kans="Zeer klein" end
    MessageText = "Kans " .. Kans .. " bij " .. text
    if alert_device ~= nil then
        domoticz.devices(alert_device).updateAlertSensor(riskLevel, MessageText)
Save it and switch it on :D That should do the trick.
The script gets the info from the weeronline webpage. Creates a json file and sends it to Domoticz . Domoticz picks it up, processes the json file, and updates the virtual sensor. The code is bases on the code which you can find at https://pon.fr/dzvents-alerte-pollens/ I just made it work for weeronline.
Hope you will enjoy it as much as I do (thanks to our French friend).
PS: the implementation for migraine and rheumatism is more or less the same. If interested, let me know, happy to share the code.
Cheers,
Arjan
Domoticz version: 2025.1
Nice work!
Technically it should be possible with one dzvents script that reads the website and updates the Domoticz device(s).
Jan Jansen
Dear Arjan,
Thank you for sharing your script. I'm going to try to get it working on my system.
Jan
Jan Jansen
Dear Arjan,
It works, I'm happy!
However, it was necessary to install lynx and supplement the crontab with sudo bash
Regards,
Jan
athoopen
Post by athoopen »
Glad it works, enjoy!! Sorry that I didn't mention installing lynx and add a line to the cron.
Cheers,
Arjan
mvveelen
Post by mvveelen »
waltervl wrote: Thursday 25 May 2023 19:38 Nice work!
Thanks for sharing the script, although I prefer it to be a dzVents script or something like that. Not really a fan of using another directory like /usr/local/bin instead of the scripts folder and editing a cron separately to run it.
EdwinK
Post by EdwinK »
Thanks for sharing this. Was looking for something that alerts on pollen. Just hope that someone someday will create it with just one script, instead of going through the shell and crontab.
EdwinK
Post by EdwinK »
After this weekend, I'm going to take a look at why it doesn't work for me.
edit: Finally I got it. Had to use sh hooikoorts to get the data.
Kedi
Post by Kedi »
Jan Jansen wrote: Thursday 25 May 2023 13:26 I am interested in a pollen device. Will you explain to me how you achieved that? Do you want to share the script used?
There is a nice site with an API which spits out JSON which could be easy processed in dzVents
 https://docs.ambeedata.com/DeveloperTools/
You can signup and have 100 free requests per day.
There is also Air-quality, Weather and Forest fire to fetch. And even forecast.
Users browsing this forum: willemd and 1 guest
