Error with Open Weather Map
munipa
Domoticz version: 13051
Post by munipa »
Hi, I'm trying to use Open Weather map with domoticz but I receive this error and some devices are not updated:
2021-03-25 15:52:07.854 Status: OpenWeatherMap: Using specified location (City DolXXXX,ES)!
2021-03-25 15:52:08.402 Status: OpenWeatherMap: City (6XX440)-> Lat/Long = 3X.XXX,-0.XXXX
2021-03-25 15:52:08.403 Status: OpenWeatherMap: Started
2021-03-25 15:52:11.902 OpenWeatherMap: General/Text (Weather Description)
2021-03-25 15:52:11.905 OpenWeatherMap: Temp + Humidity + Baro (TempHumBaro)
2021-03-25 15:52:11.908 OpenWeatherMap: Temp (Feel Temperature)
2021-03-25 15:52:11.910 OpenWeatherMap: Wind (Wind)
2021-03-25 15:52:11.912 OpenWeatherMap: UV (UV Index)
2021-03-25 15:52:11.914 OpenWeatherMap: General/Visibility (Visibility)
2021-03-25 15:52:11.917 OpenWeatherMap: General/Percentage (Clouds %)
2021-03-25 15:52:11.919 OpenWeatherMap: Rain (Precipitation)
2021-03-25 15:52:11.921 OpenWeatherMap: Lighting 2 (Is it raining/snowing)
2021-03-25 15:52:12.840 OpenWeatherMap: Lighting 2 (Is it raining/snowing)
2021-03-25 15:52:12.107 Status: Warning: Expecting svalue with at least 4 elements separated by semicolon, 1 elements received ("22"), notification not sent (Hardware: 9 - Open Weather, ID: 1, Unit: 1, Type: 54 - Temp + Humidity + Baro, SubType: 16 - Weather Station)
2021-03-25 15:52:12.313 Status: Warning: Expecting svalue with at least 5 elements separated by semicolon, 1 elements received ("165"), notification not sent (Hardware: 9 - Open Weather, ID: 4, Unit: 0, Type: 56 - Wind, SubType: 4 - TFA)
2021-03-25 15:52:12.419 Status: Warning: Expecting svalue with at least 2 elements separated by semicolon, 1 elements received ("3"), notification not sent (Hardware: 9 - Open Weather, ID: 1281, Unit: 0, Type: 57 - UV, SubType: 1 - UVN128,UV138)
2021-03-25 15:52:12.737 Status: Warning: Expecting svalue with at least 2 elements separated by semicolon, 1 elements received ("0"), notification not sent (Hardware: 9 - Open Weather, ID: 8, Unit: 0, Type: 55 - Rain, SubType: 113 - RainByRate)
2021-03-25 15:52:23.735 Status: OpenWeatherMap: Worker stopped...
What can I do? Thanks.
kiddigital
Re: Error with Open Weather Map
Post by kiddigital »
What version are you using? I assume Beta? Do you have the latest Beta?
munipa
Post by munipa »
I'm sorry for the late response, yes I'm using the last beta (version 2020.2 build 13051), from time to time I do a "git pull" and recompile the binaries, but I have this problem since few months.
kiddigital
Run it with some debug flags turned on. Hardware, normal, received...
Maybe some returned data is different than expected.
Menno
Domoticz version: 2026.1
Post by Menno »
I am seeing this too, on the latest version of Domoticz.
2023-05-22 13:38:56.220 Status: Warning: Expecting svalue with at least 2 elements separated by semicolon, 1 elements received ("-51"), notification not sent (Hardware: 16 - Open Weather Map, ID: 120, Unit: 0, Type: 55 - Rain, SubType: 113 - RainByRate)
2023-05-22 13:40:56.339 Status: Warning: Expecting svalue with at least 2 elements separated by semicolon, 1 elements received ("-51"), notification not sent (Hardware: 16 - Open Weather Map, ID: 120, Unit: 0, Type: 55 - Rain, SubType: 113 - RainByRate)
2023-05-22 13:42:56.473 Status: Warning: Expecting svalue with at least 2 elements separated by semicolon, 1 elements received ("-51"), notification not sent (Hardware: 16 - Open Weather Map, ID: 120, Unit: 0, Type: 55 - Rain, SubType: 113 - RainByRate)
2023-05-22 13:44:56.596 Status: Warning: Expecting svalue with at least 2 elements separated by semicolon, 1 elements received ("-53"), notification not sent (Hardware: 16 - Open Weather Map, ID: 120, Unit: 0, Type: 55 - Rain, SubType: 113 - RainByRate)
2023-05-22 13:46:56.729 Status: Warning: Expecting svalue with at least 2 elements separated by semicolon, 1 elements received ("-50"), notification not sent (Hardware: 16 - Open Weather Map, ID: 120, Unit: 0, Type: 55 - Rain, SubType: 113 - RainByRate)
2023-05-22 13:48:56.861 Status: Warning: Expecting svalue with at least 2 elements separated by semicolon, 1 elements received ("-52"), notification not sent (Hardware: 16 - Open Weather Map, ID: 120, Unit: 0, Type: 55 - Rain, SubType: 113 - RainByRate)
Maybe a developer can look into this?
And I also would really appreciate it if Openweathermap's "Clouds %" and "Weather description" could be moved from the Utilities tab to the Weather tab, where they belong.
