MQTT Understanding
For devices supporting the Auto Discovery feature. Like ZWaveJS2MQTT, Zigbee2MQTT.
harrykausl
Domoticz version: 2021.1
MQTT Understanding
Post by harrykausl »
I hope, I'm in the correct subforum. I have mqtt and mqtt autodiscovery installed. It works. Now I want to integrate evcc-wallbox software (has mqtt functionality). Autodiscover is for this not working. Where is the information and the rules of the devices found by autodiscovery stored, so I could manually add devices? Thanks.
Domoticz version: 2026.3
Re: MQTT Understanding
There is no such information yet, you need to redesign. Current implementation is based on ZwaveJS and Zigbee2mqtt so you could also look there.
Alternatively you can look at the MQTT mapper plugin: viewtopic.php?t=39279 and https://github.com/FlyingDomotic/domoti ... per-plugin
Also you can take a look at the shelly discovery teacher script that converts shelly MQTT into AD MQTT
https://github.com/enesbcs/shellyteacher4domo
harrykausl
Thanks, I'll try it.
There is also a wallbox plugin available https://github.com/lokonli/domoticz-wallbox Do not know if this is compatible with your device.
No need to go MQTT
harrykausl
I have already included it with http communication and json. But it would be easier to use mqtt. I'll check it, thanks.
FlyingDomotic
Post by FlyingDomotic »
You may also try using MqttMapper at https://github.com/FlyingDomotic/domoti ... per-plugin
It works with anything speaking MQTT, with a configuration file instead of Home Assistant discovery mechanism.
