Tempsensor Script, need Help
mastadook
Domoticz version: 2022.1
Post by mastadook »
Hi Friends,
I have a small Script, that in the first Step, should send me a Mail, when one of the Temp Sensors reach a hight Temperature:
	active = true,
	 on = { devices = { 'Tempsensor1',
	                    'Tempsensor2,
	                    'Tempsensor3',
	                    'Tempsensor4',
	                    'Tempsensor5',
	                    'Tempsensor6',
	                    'Tempsensor7',
	                    'Tempsensor8',
	                    'Tempsensor9,
	                    'Tempsensor10'}},
	execute = function(domoticz, device, email)
if
domoticz.devices('Tempsensor1').temperature >= 60
or
domoticz.devices('Tempsensor2').temperature >= 60
or
domoticz.devices('Tempsensor3').temperature >= 60
or
domoticz.devices('Tempsensor4').temperature >= 60
or
domoticz.devices('Tempsensor5').temperature >= 60
or
domoticz.devices('Tempsensor6').temperature >= 60
or
domoticz.devices('Tempsensor7').temperature >= 60
or
domoticz.devices('Tempsensor8').temperature >= 60
or
domoticz.devices('Tempsensor9').temperature >= 60
or
domoticz.devices('Tempsensor10').temperature >= 45
then domoticz.devices('Feueralarm').updateAlertSensor(domoticz.ALERTLEVEL_RED, 'Feueralarm!!! prüfen und evakuieren!')
     domoticz.email('Feueralarm Temperatursensoren', 'Achtung stark erhöhte Temperaturwerte von '  .. device.name .. '  '  .. device.temperature .. ' °C , es könnte auch ein Feuer sein, prüfen und evakuieren!', '[email protected]')
else domoticz.devices('Feueralarm').updateAlertSensor(domoticz.ALERTLEVEL_GREEN, 'alle Temperatursensoren im grünen Bereich, alles OK')
For Testing purposes I changed the Setting for one Sensor to 20°
Now all Sensors that are over 20° sends me a single Alarm Mail.
Why?
I just want to receive it only from the affected one.
Hope you understand what my Problem is and maybe you see my Error, I can't find it.
Please help
________________________________________________________________________
global chief of permanent lightning and strike detonator
Domoticz version: 2024.7
Re: Tempsensor Script, need Help
The email is showing device.name but that is in your case only the device that triggered the script because of it changed its temperature.
So if tempsensor9 is is triggered with temperature 15 but tempsensor10 > 20 the device.name will be tempsensor9
So you also have to store the device name if you would like to do it this way.
BUT much easier would be to change your long if statement with all devices in a simple device.temperature check:
If device.temperature >= 60 then
Kedi
Post by Kedi »
And use a '*' in the on section:
	 on = { devices = 'Tempsensor*' },
mastadook
Post by mastadook »
	active = true,
	 on = { devices = { 'Tempsensor*'}},
if
devices.temperature >= 60
So I now cleaned up the Code, this should be better?
It is
