container SSL only Topic is solved
pierrotori
Domoticz version: 2024.4
container SSL only
Post by pierrotori »
in the docker file compose you can put
-ENV WWW_PORT=8080 - Specify default HTTP port
or
-ENV SSL_PORT=443 - Specify default SSL port
But is it possible to disable the HTTP(WWW) port ?
rpi : Raspberry Pi 2 Model B Rev 1.1 / Modele : Cortex-A7 armv7l GNU/Linux / Os Name : bullseye
Docker/Domoticz/zwave-ui/homebridge/mosquitto/wireguard
Domoticz version: 2025.1
Re: container SSL only
Try WWW_PORT=0
pierrotori
thanks, with configuration, it's run correctly
- WWW_PORT=0 # Specify default HTTP port
- SSL_PORT=443 # Specify default SSL port
