Add HomeWizard WiFi watermeter in Domoticz
Not sure this is the right place but I want to share my successfull addition of HomeWizard Watermeter in Domoticz.
First start by looking up the IP address the Watermeter is using.
Then add hardware type HTTP/HTTPS poller in domoticz using the url with IP address including the API:
http://your-ip/api/v1/data
The name for the hardware can be WaterMeter, but is arbitrary
Be sure to select GET as Methode
Use water.lua as command.
Now create two virtual sensors
Water - WaterFlow
WaterTotaal - Custom - axis label: m3
Note the IDX value of both virtual sensors
water.lua
Next you must create the script called water.lua (name is arbitrary, but use the same name everywhere)
Connect to your domoticz via Putty and and go to the directory where domoticz is installed.
Go to the subfolder .../domoticz/scripts/lua_parsers
create the file water.lua with sudo privileges.
Insert the following:
-- Read API values
s = request['content'];
-- Watermeter
local idWater = use the idx for the water sensor
local a = domoticz_applyJsonPath(s,'.active_liter_lpm')
domoticz_updateDevice(idWater,'',a*1000)
local idWaterTotaal = use the idx for the WaterTotaal sensor
local b = domoticz_applyJsonPath(s,'.total_liter_m3')
domoticz_updateDevice(idWaterTotaal,'',b*1000)
Save the file, goto Domoticz and watch until values appear in the sensors.
Success!
Water - WaterFlow
water.lua
-- Read API values
-- Watermeter
Success!
Re: Add HomeWizard WiFi watermeter in Domoticz
Thanks for this.
i have only 2 questions.
1. Why multiplying active_liter_lpm by 1000? It's already in liters so no need to multiply
2. Why multiplying total_liter_m3 by 1000? if i compare it with the app the value that is pushed to domoticz is in m3 so it doesn't need to be multiplied. ("waterToaal" has the label m3 as you stated)
You are right. I also realized this later. I will change it. Thanks
- FireWizard
Hello @AdAd and @Broomer23,
I wonder, if the conclusion, you made, is correct.
The API of the HomeWizard water meter provides the following data:
@AdAd wrote:
The water flow is presented in l/min and in the JSON response you can see that it is a value of "active_liter_lpm".
So there is no need for a multiplication factor.
@AdAd also wrote:
If you push the value of total_liter_m3 to Domoticz, which is in my case 0.494 m3 (= 494 liter), your total usage is correctly updated with the value added to the Offset. But the daily value (in the upper right corner) stays at 0 (zero).
In order to get a correct indication on your device, you have to multiply the value of total_liter_m3 *1000, so that you do not send m3, but liter.
In order to correct this, go to Setup > Settings > Meters/Counters and under "RFXMeter/Counter Dividers:" under "Water" insert 1000 as divider.
It looks strange to multiply it first and then correct it again by dividing the value. But if you don't do that, it will show in the upper right corner always 0 Liter.
If everything is correct, it has to look as follows:
In my case the Offset has been 1472.405 m3.
Now you get your daily, monthly, etc, logging.
{"wifi_ssid":"Name",
"wifi_strength":100,
"total_liter_m3":0.494,
"active_liter_lpm":0}
I think this is correct, at least if you use a virtual sensor of the type General, Waterflow (See below)i have only 2 questions.
@AdAd also wrote:
This looks correct, but is not.2. Why multiplying total_liter_m3 by 1000? if i compare it with the app the value that is pushed to domoticz is in m3 so it doesn't need to be multiplied. ("waterToaal" has the label m3 as you stated)
Last edited by FireWizard on Thursday 20 October 2022 22:14, edited 1 time in total.
- gizmocuz
Interesting device... I made myself a meter with a Proximity sensor (NPN) and a ESP8266, total costs about 10-15 euro. It outputs MQTT
Had to print a holder for the meter, so this seems like a nice and easy system that everyone can use
I understand you can connect a USB cable to this device. Does this mean you can power it from the USB? (No need for bateries)
Can you connect the USB to your computer and receive data as well
Do you have to enable API mode in the meter via the App like described below?
Enabling the API
To access the data from an Energy device, you have to enable the API. You can do this in the HomeWizard Energy app (version 1.5.0 or higher). Go to Settings > Meters > Your meter, and turn on Local API.
- Domoticz version: 2021.1
Very nice,
I also have one, but have problems with the wifi,
Its in the meterput and there is isolation in it and around it with silver foil. I need to somehow extend the wifi antenna.
But dont no how.
But dont no how.
- FireWizard
Hello @gizmocuz.
I had already the idea, to create something myself as well The costs of this device is higher than yours 10-15 Euro, but it fits nice and you can install it in a few minutes. Other nice thing is you can remove it easily, if an employee of the water company want to read the meter. It is pity that there is no MQTT, so you have to poll the device.
For a complete review (in Dutch), see: https://www.iculture.nl/reviews/homewiz ... er-review/
If you do not use the USB power supply, you do not have (almost) real-time monitoring and also the API is not available.
With batteries it updates the app a couple of times/day. And indeed you have to enable the API. Disabled by default.
I believe most users will not use the API, except guys like you and me. The API is very simple. see: https://homewizard-energy-api.readthedo ... oints.html
@edwin1234.
I do not have that problem as I have an access point at about 2 m in the meter cabinet.
Wifi_strength is always at 100.
Yes, in the delivery, you will find a USB power supply (like for a smartphone), together with a fairly long USB cable (about 2m)I understand you can connect a USB cable to this device. Does this mean you can power it from the USB? (No need for bateries)
Not that I'm aware of. I think it it is only for the power supply. At least I use it with the power supply, that has been delivered with the device.Can you connect the USB to your computer and receive data as well
@edwin1234.
- gizmocuz
You are totally right. The total value does indeed need a multiply by 1000. When i changed it i got the bars in the graph for the daily hourly usage. Thank you verry much.FireWizard wrote: ↑Monday 17 October 2022 21:33 Hello @AdAd and @Broomer23,
How did you get the offset in there?
- Domoticz version: 2024.7
Should be an option in device widget button Edit
- FireWizard
Hello @Hesmink
Go to your Watermeter widget and click "Edit".
The "Configuration" screen will open and insert the desired value.
Insert the desired "Meter Offset" and click "Update".
Got it. As per OP, I used the custom sensor, and you cannot add the offset there. I now updated it to a counter of type water. Issue solved, thanks.FireWizard wrote: ↑Friday 30 December 2022 15:06 Hello @Hesmink
If someone is interested you can combine the p1 meter and water meter together in one script see: viewtopic.php?p=297035#p297035
Also voltage reading through telegram is possible.
- mvveelen
I've added the watermeter as described in the OP and it works. I think. When I open the watertap, I see the flow but it's like:
Seems not correct, how can I change this?
RPi3b+/RFXCOM rfxtrx433E/Shelly/Xiaomi Gateway/Philips HUE Lights/Atag Zone One/2 SunnyBoy inverters/AirconWithMe/P1 smartmeter/Domoticz latest Beta
- Domoticz version: 2024.4
OLD
domoticz_updateDevice(idWater,'',a*1)
rpi4 - zigbee2mqtt - roborock - espeasy - rfxcom - homewizard p1 - otgw - homebridge - surveillance station - egardia - goodwe - open weather map - wol - BBQ detection - rsync backup
- mvveelen
Ah, OK. That should do the trick.
I now face another issue. I followed the instructions in the OP and also followed the instructions to NOT use a custom sensor but a counter, but the first is useless because I can't adjust the offset and the second remains zero.
I'd like to change the offset so the current amount reflects what is on the meter itself. Any ideas?
- FireWizard
Hello @mvveelen,
You wrote:
It looks like you mixed the "total_liter_m3" with "active_liter_lpm".
How do you send the data to Domoticz?
Can you share the script or in case, you use Node-Red, the contents of the Function node?
You wrote:
What do you mean with OP? Original Poster?I've added the watermeter as described in the OP and it works. I think. When I open the watertap, I see the flow but it's like:
- mvveelen
OP = Opening post
LUA script I've uploaded:
2101 Watermeter Waterverbruik RFXMeter RFXMeter counter 234.263 m3
2100 Watermeter WaterTotaal General Custom Sensor 66 L
2099 Watermeter Stroomsnelheid water General Waterflow 0 l/min
Where did I go wrong you think?
-- Read API values
-- Watermeter
local idWater = 2099
local idWaterTotaal = 2100
local idWaterVerbruik = 2101
local c = domoticz_applyJsonPath(s,'.total_liter_m3')
domoticz_updateDevice(idWaterVerbruik,'',c*1000)
- FireWizard
Hello @mvveelen,
I have never worked with lua, but as far as I do understand this, it is allright.
Just a Question.
What is your setting in Setup >> Settings >> Meters/Counters for Water. This should be 1000.
And what is your setting in the "Water" widget if you press "Edit". See Counter Divider.
This should be 0 (zero). If this contains also 1000, then I understand your 1,000.000.
Just a Question.
