Python Plugin: Domoticz-TinyTUYA-Plugin (Cloud)
- heggink
- Domoticz version: 12451
Re: Python Plugin: Domoticz-TinyTUYA-Plugin (Cloud)
Didn't that throw a bunch of errors? Now nothing gets back even though the tinytuya command stuff works....
ps: I noticed there is a rudimentary tinytuya2mqtt thing out there. Would be interesting to see if that may prove to be a good basis combined with the MQTT autodiscovery. I am not a big fan of python plugins doing all sorts of internet requests as it hogs domoticz when the response is challenged (unless the async framework is used which tinytuya does not).
DASHTICZ 🙃
P1 meter & solar panel
DASHTICZ 🙃
- Domoticz version: 2024.7
No errors, just a blank list of devices. Must be a server issue?
- heggink
Unlikely since the tinytuya command line works...
DASHTICZ 🙃
DASHTICZ 🙃
Just tried again:
python3 -m tinytuya wizard
and
debug_discovery.py
Both give "list of devices" as [ ]
Just logged into my iot platform account and all the devices are there. Most odd that tinytuya is not picking them up at the moment.
and
debug_discovery.py
- Xenomes
The plugin is fixed, pull version 1.5.0 is compatible with Tinytuya 1.12.3 library.
HP T630 (256GB SSD/8GB Mem) - Ubuntu 24.04.2 LTS (64Bit) - Domoticz 2024.7 (Docker) Machinon theme - RFLink - KaKu - Sonoff - Tasmota - Shelly - MQTT2Zigbee - OpenTherm Gateway - Tinytuya - IR Blaster - P1 Smart Meter - NPN Watermeter - Google Assistant
- heggink
Just updated and everything is back again! Thx!!!
DASHTICZ 🙃
DASHTICZ 🙃
and
debug_discovery.py
still do not show my devices (tinytuya 1.12.3)?
and
debug_discovery.py
- Xenomes
Good to hear!
- Xenomes
What message do you get with 'python3 -m tinytuya wizard'?
Just updated the debug_discover.py code and I get this error:
No device data returnd for Tuya. Trying again!
The wizard gives me:
Device Listing
>> Saving list to devices.json
0 registered devices saved
>> Saving raw TuyaPlatform response to tuya-raw.json
The raw file contains:
Yet my tinytuya is updated to 1.12.3
"result": [],
"success": true,
"t": 1681325388142,
"tid": "xxxxxx",
"fetches": 1,
"total": 0,
"file": {
"name": "tuya-raw.json",
"description": "Full raw list of Tuya devices.",
"account": "xxxxxxx",
"date": "2023-04-12T19:49:48.177489",
"tinytuya": "1.11.0"
- Xenomes
Did you update with or without sudo? Domoticz runs as root so with most systems sudo is needed except docker.dgilbert2 wrote: ↑Wednesday 12 April 2023 20:53Yet my tinytuya is updated to 1.12.3Code: Select all
I updated with sudo pip3 install tinytuya -U
Is that right?
Is that right?
- Xenomes
Oops, for Domoticz that is correct. But for the debug script and tinytuya python command is run on user
or run script with sudo of update also without sudo.
- Xenomes
Good to hear!
- Varazir
Hi I keep getting this
The plugin works as I can turn of a fan I have that uses TUYA.
2023-05-04 15:29:18.605 TinyTUYA: Update devices in Domoticz
2023-05-04 15:29:18.608 Error: TinyTUYA: Device read failed: bfd6bda7f3a84e2064d97h
Raspberry PI 2 with RaZberry Controller 2016 ZWave+ and CC2531(zigbee)
Several IKEA devices/z-wave devices
- Xenomes
Can you put the plugin on debug all, then the plugin will give a line where the error condors.
- heggink
Question: is anyone running this plugin in a docker environment? I am considering moving my entire environment to docker so interested to see whether there are any issues with that.
DASHTICZ 🙃
DASHTICZ 🙃
- Xenomes
The plugin does work in docker but there is a small catch. In the docker environment of Domoticz the install guide needs to installed. So if the docker is renewed for a update, the install guide need to be reinstalled in the docker environment.
