I have a brandnew 4-channel Touch Panel Switch (MCO Home MH-S314).
Including as Z-Wave Device was easy (even if seems to be an unknown Device to Domoticz)
I also found the respectice 4 Switches in "New Devices and included them.
The 4 switches work perfekt, when operating them remotely from Domoticz.
When operating local touch switches I have the following strange behaviour:
Switching on and off Switch 1: Everything fine locally and in Domoticz.
Switching on Switch 2: Local Switch Indicator 2 shows on, Domoticz show Switch 2 AND Switch 1 on.
Then Switching off Switch 2: Local Switch Indicator 2 shows off, Domoticz shows Switch 2 off BUT Switch 1 stays on.
Switching on and off Switch 3: Everything fine locally and in Domoticz.
Switching on Switch 4: Only Local Switch Indicator 4 shows on, Domoticz show Switch 4 AND Switch 3 on.
Then Switching off Switch 4: Local Switch Indicator 4 shows off, Domoticz shows Switch 4 off BUT Switch 3 stays on.
The problem with this is, that I have event scripts reacting to the switches in Domoticz,
which obviously creates fault reactions with above behaviour.
There no event scripts triggering the switches.
Any Idea for the root cause of this problem or how to solve it ?
Touch Panel Switch: Strange behaviour
- cbartetzko
- Domoticz version: 2023.1
- Domoticz version: 2026.3
Re: Touch Panel Switch: Strange behaviour
OpenZwave or ZwaveJSUI over MQTT Autodiscover?
The first is deprecated so not supported anymore.
