Domoticz App
madpatrick
Domoticz version: 2025.1
Re: Domoticz App
Post by madpatrick »
I’m not sure if this app is still supported
Check out this link : viewtopic.php?p=61452#p61452
This is app 2.0 , but only for android :evil:
-= HP server GEN11 =- OZW -=- Toon2 (rooted) -=- Domoticz v2025.1 -=- Dashticz v3.14b on Tab8" =-
Anonymouse0104
Re: Domoticz App
Post by Anonymouse0104 »
Yeah the same app is for iOS, I’ve been using this for several years now. Works great, but for some reason it won’t connect to the domoticz from my friend. If I fill in my server settings on his phone it’s working..
madpatrick
Re: Domoticz App
Anonymouse0104 wrote: Sunday 19 March 2023 13:50 Yeah the same app is for iOS, I’ve been using this for several years now. Works great, but for some reason it won’t connect to the domoticz from my friend. If I fill in my server settings on his phone it’s working..
Which version of the IOS app are you using.
I’ve v1.75 and don’t see a newer or other version
Anonymouse0104
Re: Domoticz App
Same here, 1.75 on both iPhones
BurningTyre
Domoticz version: 2023.2
Re: Domoticz App
Post by BurningTyre »
It needs an update to handle blinds.
elzorrovega
Domoticz version: 2024.7
Re: Domoticz App
Post by elzorrovega »
Hello All,
Like anything application, if there is no maintenance it will also give issues. As madpatrick pointed out it's been left to itself for a long time. Notifications stopped working for me a long time ago .. I now use Pushover.
I have the following setup
Domoticz Version 2023.2
Domoticz iOS Client Ver 0.1.55 (latest version from Apple Store)
I just upgraded to version 2023.2 and two major things to keep in mind for iOS to work
Setup devices for user as per instruction viewtopic.php?f=47&t=40336
Allow iOS Domoticz to work viewtopic.php?t=40607
You need to enable API Protection on Settings, Security tab
I do not know if this helps you guys but I been playing with Nodered and I see some potential!
Domoticz and Nodered (remote) combined allow many possibilities. Once I have completed my own i Nodered/Domoticz interface I will share my flows to see if this helpful to you. Of course Nodered implies a little elbow grease from user but then again there is no such thing as s free lunch!
The solution to the problem changes the problem!
Rasberry Pi 4 Model B; Bullseye -64 bit OS 6.1.21-v8+ #1642
Domoticz Version: 2024.7
zwave-js-ui: 9.30.1.46a9eda
zwave-js: 14.3.8
home id: 3714679688
home hex: 0xdd698388*
